Old 07-13-2005, 01:04 PM   #1
sparco
Member#: 4977
01 2.5 RS
Default Wastegate
If I used a stock wrx turbo on my little 2.5na project motor, would I need an extra waste gate to keep the boost at 5 or 6 psi.
Or is there another way to reliably control the turbo to give me a low psi?
Thanks
Danny
sparco is offline   Reply With Quote
Old 07-14-2005, 12:44 PM   #2
sparco
Member#: 4977
01 2.5 RS
No thought on the matter?
Or should I run with no extra wastegate and hope it won't over boost?
Danny
Old 07-14-2005, 06:31 PM   #3
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
you can weld the td04 wastegate shut and use the external wastegate to control your boost...
cRayZee is offline   Reply With Quote
Is it easy to swap the stock wastegate with another stock wastegate? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-23-2005 07:19 PM
wot wastegate spring for external wastegate tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-25-2004 12:16 AM
FS: PE separative wastegate actuator clamp kit, and 19psi wastegate spring. jigga Private 'For Sale' Classifieds 5 02-19-2004 08:54 PM
PE wastegate seperator for IHI wastegates IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-30-2003 09:47 PM
advantages of external wastegate over internal wastegate? petawabit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-04-2003 02:54 AM
