Old 07-13-2005, 06:06 PM   #1
Kraziken
Member#: 38629
1999 Legacy GT (STI)
Default Cobb pads
How long do front rotors typically last?
I had the cobb stage 1 brake kit, which are cryo treated rotors and their semi-metallic pads (SS brake lines etc) , but I just found that the brakes had eaten them to the point where I need new rotors.
I think I've been running this setup for around 35k or 40k. This seems to be a short life, but I'm not positive.
Kraziken is offline   Reply With Quote
Old 07-13-2005, 07:57 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I had the Cobb pads with stock WRX front rotors on the old wagon for maybe 12k miles, though i never thought to check on them. I was under the impression that the pads were relatively soft, for better rotor wear.
Have you looked on the Cobb forum for any info?
DLC is offline   Reply With Quote
Old 07-13-2005, 10:09 PM   #3
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
DLC: how did you like the WRX front setup?
considering the same setup for myself.
iamrazor is offline   Reply With Quote
Old 07-14-2005, 12:17 PM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I purchased a used set of rotors, calipers, pads and brackets with 30k on them, give or take, for something like $120.
Compared to the OE sized x-drilled Brembos (10.7"), with Axxis Ultimate pads, the initial bite was diminished, but the overall braking performance was identical when i got into them. My reasons for upgrading were that the Brembos were being completely threashed by the Axxis pads and had a few thousand miles left, at best. The other was that i'm planning on getting cryo'd rotors and pads from Cobb in the future, and the brackets are as expensive, new, as a whole used kit from a WRX owner.
Because i'm interested in a similar setup to Kraziken, i'm also eager to hear feedback from those using thsi combination.
Old 07-14-2005, 12:43 PM   #5
Teh Legacy
Member#: 9853
to keep your mouth
shut.
You can cryo pads also? I didn't know that.
Teh Legacy is offline   Reply With Quote
Old 07-14-2005, 01:22 PM   #6
Kraziken
Member#: 38629
I loved the brake feel with the Cobb setup, but the pads dusted like crazy, and I think probably ate the rotors, just not sure.
If I were to do it again, I'd probably get the Cryo rotors and an organic pad of some sort.
I needed something to replace them now, so I just replaced them with OEM like rotors from a local NAPA store.
cobb pad help Hbomb440 Brakes, Steering & Suspension 4 10-30-2008 07:52 PM
Cobb pads and rotor problems STill_WRXed Brakes, Steering & Suspension 0 08-21-2007 11:41 PM
Cobb pads =??? hystikal Brakes, Steering & Suspension 0 03-13-2006 12:08 PM
Gauging Interest: '05 Legacy GT front rotors/calipers with Cobb pads/lines PGT MAIC Private Classifieds 5 02-02-2006 06:55 PM
Grillcraft, Hotchkis Links, COBB pads pleue Private 'For Sale' Classifieds 2 08-16-2005 04:42 AM
