Old 07-13-2005, 07:48 PM   #1
LegacySTI
Member#: 86621
95 If it brakes
Mod it
Legacy Engine thoughts
So I'm going to do an engine swap and depending on which route I go it could be next summer at the earliest or a few years down the road. So here are my thoughts. Should I buy an STI short block for like 1500$ and build it up so when I do put it in I will have mad power. Thats the long way. Or do I buy an AQUA tuned EJ20 for 5000$ next summer and be faster than a wrx but slower than an STI. Which do you guys think would be cheaper in the long run? I'm going to be at school too so if I do get the STI short block I wont be able to work on it all the time (not that I really know what I would be doing). But I think if I get the shortblock I'd be able to get the low comp pistons right away and a bigger turbo, somehow get a front mount intercooler and hopefully have somewhere around 600HP when its all said and done for a little more than the AQUA EJ20. You guys are the experts, what would you do?
LegacySTI is offline   Reply With Quote
Old 07-14-2005, 10:12 AM   #2
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
If you knew what you were doing, I'd suggest getting the STi Shortblock if you could find one and building it up if you wish to do so (I'd be happy with some basic mods like UP/DP, Catback, FMIC, and an ECU). With 600hp though, you're also going to need a driveline swap in all likelyhood. I don't believe the stock 5mt will hold NEAR that (I'd be worried if RA gears would even hold it), and I'm not sure about the 4EAT.
Either way, you're going to be looking at a lot of wiring, or need for a good engine management system.
Perdue is offline   Reply With Quote
Old 07-14-2005, 10:17 AM   #3
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
you mention "faster than this" "slower than that".
are you racing or something? what kind? best not be on the street.
Perdue has some good ideas to start. I guess you should evaluate what you want to do with the car before you start.
iamrazor is offline   Reply With Quote
Old 07-14-2005, 10:31 AM   #4
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Have to agree with that. Street, track or autox? Daily driven?
Remember that once it's done, you will have maintenance to consider and reliability issues.
Personally if you want a turn key solution, go with a professional install that includes the factory ECU for reliability. Then you can tune it as if it's an STi.
Are there major differences with the WRX and STi blocks? If you're going for mad power, a closed block is your only option. Pistons etc can all be swapped, but the block is your foundation.
Huffer is offline   Reply With Quote
Old 07-14-2005, 07:20 PM   #5
LegacySTI
Member#: 86621
95 If it brakes
Mod it
Daily driver is the plan but I want to be able to take it out to the track for some drags, I dont street race...that's illegal... I dont know if there are any differences between the STI and WRX blocks, I still have alot of research to do. I dont want to end up buying a full front clip if I'm just going to rip it apart to build something better.
Old 07-14-2005, 07:49 PM   #6
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I would wait to do anything until you get done with school. So what are you going to do with the STI block? Are you going to get a turbo kit? Are you going to be running an STI trany? Even then it will have trouble with 600 hp.
Have you driven an STI? Or even a WRX? 200 whp is nice, 600 is just stupid for a daily driver. I would look into getting a stock STI motor installed. Have a shop that has done the swap do it. Make sure to research the shop that is going to do all the work.
subiekid is offline   Reply With Quote
Old 07-14-2005, 07:51 PM   #7
tora
Member#: 5851
09 Forester XT
+ NA Miata
Being a student I would recommend you stick with the 2.0 litre block. My reasoning for this is that a turbo 2.5 chuggs gas and it will add up quickly. If you can find a reasonably priced EJ207 or like engine I think that would be ideal.
tora is offline   Reply With Quote
Old 07-14-2005, 08:10 PM   #8
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
The WRX's and STi's are mad fast factory, and the legacy's only weigh about a 100lb's more, so you will only be slightly slower than the stock imprezas. Like others have said, reliability and maintenance are cost factors to consider. Remember, a 600hp motor can break easy, and when they do, its expensive parts.
You will have to upgrade your brakes too. Going fast is great, but when it comes time to slow down, you better have the gear to do that too.
Plays_With_toys is offline   Reply With Quote
Old 07-14-2005, 09:06 PM   #9
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
600hp in that old chassis - it'd rip the car apart. Literally. I would concentrate on around 250-280whp, which is the point it'll become damned dangerous without significant suspension and brake upgrades. 250whp in that older car with the lighter body will do significant damage to most vehicles on the road, and won't grenade whatever transmission you put into it instantly.
600hp is also going to be laggy as hell, and not something I would consider driveable on the street, though I know there are die-hards that try. Ross at AVO has his old GC8 STi wagon with a 2.0 making 570hp, and it's an absolute beast. Fun at the dragstrip, though. It's handling that much power with a hand-cut dogbox that costs much more than your initial engine budget, and even that breaks fairly often...
Cheers,
Paul Hansen
www.sevenphotos.com
www.scoobymag.com
AVOjapan is offline   Reply With Quote
Old 07-14-2005, 11:33 PM   #10
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Definately would need a tranny/gear upgrade. I broke 2nd gear in a 1990 wagon only putting down 150ish whp.
Old 07-15-2005, 07:22 AM   #11
Kraziken
Member#: 38629
1999 Legacy GT (STI)
What is an AQUA EJ20?
I'm debating the same thing, except I already have a very low mileage USDM EJ20, but I'm wondering if I should buy a STI block and swap the internals.
Or buy a whole STI setup and sell my EJ20.
Part of it is I'd like to have more torque, and the other part is silly I guess. My car badge says 2.5 GT, and I think I'd like to swap a 2.5 for a 2.5.
Kraziken is offline   Reply With Quote
Old 07-15-2005, 09:00 AM   #12
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
The USDM STi EJ25 block is a semi-closed deck design, while the USDM WRX EJ20 block is an open deck design.
The USDM '91-'94 Legacy Turbo EJ22 block is a fully closed deck
IronMonkeyL255 is offline   Reply With Quote
Old 07-15-2005, 09:57 AM   #13
LegacySTI
Member#: 86621
95 If it brakes
Mod it
[quote=Kraziken]What is an AQUA EJ20?
AUQA is a company in japan that just does subaru stuff. They have an EJ20 that they have tuned, they gave it better rods, pistons, turbo, intercooler and ecu. I puts out 265 and its as expensive as an STI motor.
Old 07-15-2005, 05:28 PM   #14
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
I'd say, turn your car into a Subaru version of the 3000 GT with an H6 and twin turbo setup.
Chi_San is offline   Reply With Quote
Old 07-15-2005, 09:06 PM   #15
subiekid
Member#: 25516
Why not get the Tommy K motor, if you are going to get some over priced motor. At least it is a 2.2.
Old 07-15-2005, 10:36 PM   #16
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
The tK *kit* is about 10k, installed. That is on top of the original motor price. Plus it is just a stroker kit, really. For half the money (of the tK kit) you can get a Forester/STi 2.5 shortblock and have it built up, giving you something to make 400hp out of reliably. AVO is doing just that for Super Autobacs (which *owns* tommy kaira) for just that reason.
Cheers,
Paul Hansen
www.sevenphotos.com
www.scoobymag.com
Old 07-15-2005, 10:39 PM   #17
MitchGT
Member#: 73684
2012 4Runner
PHATsuby is already working on that one
MitchGT is online now   Reply With Quote
Old 07-15-2005, 11:36 PM   #18
subiekid
Member#: 25516
I was just kidding, I think the TK motor is way over priced.
Old 07-16-2005, 12:33 AM   #19
Diabolical1 CC
Member#: 59897
600HP on the cheap??? Your best bet is two 150HP Nitrous systems and a STi engine. Just don't expect it to last more than a race.
Daily Driver?
hahaha
How about a 3.6L Twin Turbo H6 Porsche 500HP or if it needs to be a Subie a 3.3L Twin Turbo or if your really good make a H8 5.0L and turbo or twin turbo it.
But you won't get a daily driver with 600HP without nitrous on the cheap.
Diabolical1 CC is offline   Reply With Quote
Old 07-16-2005, 01:06 AM   #20
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
Ah, well, completey agree on that!
Besides, I've driven some of the tK's, and the standard 2.0's with a little good tuning make more power...
Cheers,
Paul Hansen
www.sevenphotos.com
www.scoobymag.com
Old 07-16-2005, 05:39 AM   #21
LegacySTI
Member#: 86621
95 If it brakes
Mod it
I never said cheap, I know this is going to take some money to do. And I dont believe in Nitrous, its not worth the damage it does. AVO, tell me more about this engine you're doing. Is it possible to put a Porsche engine into a subaru? That could be an interesting conversion... a Legacy 911
ej257 engine feeler C-DAY Engine/Power/Exhaust 38 06-12-2010 02:18 PM
H6 3.0 L engine thoughts kleggo Normally Aspirated Powertrain 3 02-10-2006 05:36 PM
Just a thought (concerning engine stalls) MattDell Normally Aspirated Powertrain 0 12-09-2002 05:20 PM
random thoughts on high compression turbo engines HamFist Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-23-2002 01:16 AM
My thoughts on STi engine mounts. supermarkus Car Part Reviews 25 08-01-2002 06:38 PM
