Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 07-14-2005, 12:49 AM   #1
NorCal11.7
Member#: 55879
2000 Impreza 2.5 rst
Blue Ridge Pearl
Default Aftermarket RS Injectors!
Ok, now is there some company that makes aftermarlet Injectors for RS's, prefferably for a 2000? Ive looked and looked, but maybe im missing something!?! Or do i just have to rig something up? This is like my 4th time posting a thread like this, but noone replies! any help this time?!?!
NorCal11.7 is offline   Reply With Quote
Old 07-14-2005, 07:56 AM   #2
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
you can make regular top feeds fit. You will need a hodgepog of different Orings, but they will work. a .5 in spacer is needed on the rail bolts as well.
Hitokiri is offline   Reply With Quote
Old 07-14-2005, 08:40 AM   #3
Imprezha
Member#: 6818
2004 STI 02 NSX
2010 Gen Cpe,03 CL Type S
I'm not sure what size injectors your looking for but RC Engineering makes injectors for our cars. I believe the ones I had were RC440's for my 2001 RS-T. Give them a call.
Imprezha is offline   Reply With Quote
Old 07-14-2005, 09:02 AM   #4
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
I use these Delphi 500cc injectors. Haven't had a problem with them. No leaks, nothing... http://www.racetronix.com/17113738FM.html
maxiav is offline   Reply With Quote
Old 07-14-2005, 10:31 AM   #5
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
www.rceng.com
You'll need to solder new clips in. That takes like 20 minutes and it's easy as pie. You will also need spacers under your fuel rails since the injectors are bigger. They can send you both the clips and spacers for your MY if you ask.
I have the SL4-440cc injectors and love them. Customer service is also A+ at RC.
-Brett
ExecNav is offline   Reply With Quote
Old 07-14-2005, 12:29 PM   #6
blaznc
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
I have heard that RC stopped makeing injectors for our cars.
blaznc is offline   Reply With Quote
Old 07-14-2005, 01:14 PM   #7
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
No. Technically they never even made injectors for our cars. They were selling injectors that someone decided fit the EJ25 okay, to RS owners. For one reason or another they kept telling RS owners that they should fit no problem blah blah blah even though people were calling in saying the injectors didn't fit inside the manifold very well, which is true. A few people sent RC their intake manifolds to have the injectors custom fitted while some just dealt with the funky seating, like me.
The issue more specifically was this. Here's a picture I threw together:
The RC injectors would sit ontop of the hole instead of inside the hole like the stock injector. The fuel rails were the only thing securing the injector in place. Once bolted down, the rails did hold the injector in place and were perfectly alligned. Some were okay with this (like me) and some weren't.
I guess RC finally decided it was time to actually test fit the injector. They themselves were not satisfied with the fitment of the injector and decided it was time to stop selling them to RS owners. I'm sure they still make them but it's up to you whether or not you want to buy them. RC won't claim any responsibility if you aren't satisfied with the fitment.
I've had mine in for over a year and 15,000 miles. I've had no problems. They rock my socks.
-Brett
Old 07-14-2005, 01:26 PM   #8
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
One more thing. The O ring that goes in between the fuel rails and the STOCK injector, the big one... I put that on the tip of the RC injectors in between the injector and the manifold. It fits perfectly around the area that actually makes contact with the manifold so it seals the hole. Works great.
-Brett
Old 07-15-2005, 01:53 AM   #9
NorCal11.7
Member#: 55879
Blue Ridge Pearl
So basically noone makes any direct replacements. Does RC not check their e-mail? or would it be better to just call? ive been trying to get ahold of them via e-mail, but never a response back.
Thanks ScoobaruRS for the diagram, thats exactly what i thought would happen with aftermarket injectors that werent made for my intake manifold. Would anyone know how much it would run for a machine shop to enlarge the injector ports? i'd do it myself, but no tools, and not much time.
One more thing...
If i was to get some injectors from RC... would they plug right up to my injector harness? or do i have to do some more modifications there?
Thanks
Old 07-15-2005, 03:31 AM   #10
kaos200
Member#: 2692
My friend has injectors that fit his RS just fine? He's selling them also, they're 550cc's
kaos200 is offline   Reply With Quote
Old 07-15-2005, 02:29 PM   #11
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
The problem is the Air Assist manifold that requires a long narrow nozzle from the look of things - none of the bigger injectors are like the stock one so they wouldn't go all the way down. For me, the downside is that the injectors are further up and thus wouldn't have the optimal spray pattern seeing that it might hit the sidewalls of the injector hole. Probably not bad enough to cause a concern though - I will leave it to the guys who have ran bigger injectors like this to speak up.
kgb is offline   Reply With Quote
Old 07-19-2005, 01:01 AM   #12
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
not tryin to hijack but ive got some 650s for sale <non air assist>
375 shipped
alex
WTT(ILL) aftermarket FUEL INjecTors 07 STI eng4280 MWSOC Private Classifieds 0 01-28-2010 11:56 AM
FS:Stock STI parts and some aftermarket WTB:Inlet,Injectors,Fuel Pump... BlackSTI2006 NESIC Private Classifieds 14 04-13-2007 09:52 PM
WTB: aftermarket STi injectors Autopilot747 Private 'Wanted' Classifieds 4 01-08-2007 09:27 PM
Aftermarket RS Parts jeffsnyder Private 'For Sale' Classifieds 13 02-15-2004 12:50 PM
2.5 RS injector/WRX injector specs? STi - IMPREZA Newbies & FAQs 1 09-24-2003 11:54 AM
