Old 07-14-2005, 01:01 PM   #1
DaveFan782
Member#: 90249
2006 WRX Ltd.
SGM
Default Heat Shield??
So naturally....
I have this noise coming from somewhere underneath my car whenever I am sitting inside and close the door. It seems to happen more once the underside of the car has cooled (cold = metal contracting, thus loosening whatever the hell is floating around!)
I don't hear it when I'm driving- only when I'm in the car with the ignition off and shut the door.
Naturally, the dealer can't replicate it.
It's a hollow metallic sound...
Any advice??
Thanks!
DaveFan782 is offline   Reply With Quote
Old 07-14-2005, 10:42 PM   #2
sha_zapple
Member#: 41012
1998 Legacy L
I dont quite understand, there shouldnt be any soundas after shutdown. The only sound I can think of is the cooling of the exaust, which is normal. It should sound like pinging metal
sha_zapple is offline   Reply With Quote
Old 07-14-2005, 10:49 PM   #3
Handsdown
Member#: 29355
yeah if it's from vibration(like slamming the door) and it's under the car, i'm sure the header's heat shields are a worthy culprit. wrap them in header tape! hahaha
Handsdown is offline   Reply With Quote
Old 07-15-2005, 12:52 AM   #4
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
^ yes that is prolly it. The old school impreza's and legacy's have a pantented exhuast sheild rattle.
99subi is offline   Reply With Quote
Old 07-15-2005, 01:56 AM   #5
darkwaterz
Member#: 65165
97 OBS
i miss my RS...
"i before e except after c"!!
z.
darkwaterz is offline   Reply With Quote
Old 07-15-2005, 02:08 PM   #6
abosworth
Member#: 53856
2012 Speed3
Red Mica
z.
Well if were going to get technical about spelling we might as well go all the way and correct YOUR punctuation. When you write with quatation marks all punctuation marks must be inside the quotations. You should have put the exclamation marks inside the quotes. Nexd time keep yer toooo sents ta yer self.
abosworth is offline   Reply With Quote
FS: 6 cd stock radio,stock catted uppipes doodie Tri-State Area Private Classifieds 17 06-10-2010 05:14 PM
FS : 02-07 turbo heat shield un-cut $10 hybrid gti 2 SCIC Private Classifieds 5 06-04-2010 01:44 PM
Lot of part vf39 injector cf exhaust heat shield cusco heat shield Ect ppericfe Tri-State Area Private Classifieds 14 02-28-2009 09:08 AM
WRX Up pipe, stock heat shields, COBB heat shield... racerX_244 Engine/Power/Exhaust 5 06-02-2008 10:18 AM
Factory 03 up pipe. 2 Factory heat shields and mic factory heat shielding. 03twrx Private 'For Sale' Classifieds 8 07-27-2006 08:19 PM
