Old 07-14-2005, 05:48 PM   #1
TrickNipple
moon moon
Member#: 86213
Default 2.2 oil pump replacement
Has anyone here replaced the oil pump on a 2.2l? I found out yesterday mine is leaking a little bit. Its not a bad leak so it can wait but I was hoping to do this myself instead of having to pay the shop to do it.
TrickNipple is offline   Reply With Quote
Old 07-14-2005, 06:08 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Not that hard, just tedious. You have to pull the timing belt. Then there are 2 seals. One on the rear between the block and the pump. And one up front on the crank. When you re-attach it, you use liquid gasket all the way around. 4-5 hour job for most shade trees...
Old 07-14-2005, 07:17 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
pics of my t-belt job as well as oil seals & oil pump o-ring.
http://www.main.experiencetherave.co...ges/timingbelt
Legacy777 is offline   Reply With Quote
Old 07-14-2005, 07:36 PM   #4
TrickNipple
moon moon
Member#: 86213
Legacy777 thanks for the link to the pictures.
2 (TWO) 2.5L oil pumps, one has 22K other one has 25k ronzogonzo Engine/Power/Exhaust 0 05-20-2010 12:37 AM
2.0 S/B Replacment with upgraded oil pump CHEWY911 Built Motor Discussion 1 02-20-2009 07:19 PM
New in box 2.5RS oil pump Genuine Subaru OEM oldhat Engine/Power/Exhaust 49 10-31-2008 03:06 PM
EJ20G oil pump replacement oldhat Pre-2002 Factory Turbo Powertrain 9 01-16-2008 01:06 PM
Oil Pump Replacement? teh Phil 'Old School' Subaru Forum 5 10-30-2004 06:35 AM
