Old 07-14-2005, 08:39 PM   #1
kevinsUBARU
Member#: 2263
2012 Impreza Sport
Default Swaybar Installation Questions - 2001 Legacy
Hi all! I did some rough measurements and came to the conclusion that my old 18mm swaybar from my 95 Impreza MIGHT fit, so I was trying to take off the 2001 BH wussy bar to see. Bushing brackets were no problem, but I could not get the endlink bolts off. So I came here in mid-installation, did a search, and found a very cryptic ascii drawing in an old thread describing an allen key hole that you use to hold the nut still. Anyhow, does anyone have a better description/picture of said allen key hole?
If the Impreza bar does not work, I am going to get an IPD anyhow. IPD said their customers reuse the stockers and they have had no problems...so there must be a way to get them off!! I sincerely appreciate any help!
Kevin
kevinsUBARU is offline   Reply With Quote
Old 07-14-2005, 10:00 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Found my cryptic drawing, eh?
Yeah, you just need to stick an allen key/wrench into the end of the bolt. The bolt is hollow and using the key will hold it in place while you use a box end to undo the bolt.
Good luck.
fibuz
fibuz is offline   Reply With Quote
Old 07-15-2005, 12:09 AM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
Your 95 bar will NOT work.
tora is offline   Reply With Quote
Old 07-15-2005, 07:35 AM   #4
kevinsUBARU
Member#: 2263
2012 Impreza Sport
Thanks fibuz and tora!
Old 07-15-2005, 07:56 AM   #5
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
they're both right. before I knew of that drawing, I used a hacksaw to get mine out
oh well, I had whiteline endlinks going in anyways.
FWIW, a cheap upgrade is to find an outback swaybar. thats 18mm, IIRC...
I have the older whiteline 20-22-24mm RSB and have it set on 22mm. IMHO, 18mm would be no where near enough.
iamrazor is offline   Reply With Quote
Old 07-15-2005, 01:34 PM   #6
AKSubie
Member#: 6214
01.5 Audi S4
www.motorsportsalaska.com
Correct, although a 90-94 one will work correct? I recall the whiteline number being the same for mine and a BC. This might have ben the front bar however.
AKSubie is offline   Reply With Quote
Old 07-15-2005, 02:57 PM   #7
tora
Member#: 5851
09 Forester XT
+ NA Miata
2000-on
Legacy
(BE-BH)
(Legacy, 2000-on)
Non Adjustable BSF14 *1 20 $165.00 BSR12 *1 18 $165.00
(Legacy, 2000-on)
Heavy Duty Non Adjustable BSF14X 22 $165.00 BSR12X *1 20 $165.00
(Legacy, 2000-on)
Adjustable BSR12XZ 20-24 $185.00
1994-1999
Legacy
(BD-BG)
(Legacy, 1999)
Non Adjustable BSF14 *1 20 $165.00 BSR19 18 $165.00
(Legacy, 1999)
Heacy Duty Non Adjustable BSF14X 22 $165.00 BSR19X 20 $165.00
(Legacy, 1994-1998)
Non Adjustable BSF19 20 $165.00 BSR19 18 $165.00
(Legacy, 1994-1998)
Heavy Duty Non Adjustable BSF19X 22 $165.00 BSR19X 20 $165.00
(Legacy, 1994-1999)
Adjustable BSR19XZ 18-22 $165.00
1990-1993
Legacy
(BC-BF)
(Legacy, 1990-1993)
Non Adjustable BSF19 20 $165.00 BSR17 18 $165.00
(Legacy, 1990-1993)
Heavy Duty Non Adjustable BSF19X 22 $165.00 BSR17X *1 20 $165.00
(Legacy, 1990-1993)
Adjustable BSR17XZ 20-24 $185.00
No....90-94 will not fit.
Old 07-15-2005, 03:06 PM   #8
AKSubie
Member#: 6214
01.5 Audi S4
Weird, I guess I am wrong, Could've sworn when I bought mine it shared one of the bars (front or rear) with an earlier legacy. Hmm, must've been smokin that day.
Oh well.
Old 07-15-2005, 03:41 PM   #9
tora
Member#: 5851
09 Forester XT
+ NA Miata
It has the same front bar according to above (pdm) as the 1999 BD/BG front bars. (Although I think that is a mistake as the 1999 in Australia is the 2000 here.)
Old 07-15-2005, 06:53 PM   #10
kevinsUBARU
Member#: 2263
2012 Impreza Sport
Before I crawl under it again, does anyone remember what size allen key was used?
Old 09-16-2005, 12:53 AM   #11
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
[quote=tora]2000-on Legacy (BE-BH)
(Legacy, 2000-on)
Non Adjustable
BSF14 *1 20 $165.00
BSR12 *1 18 $165.00
(Legacy, 2000-on)
BSF14X 22 $165.00
(Legacy, 2000-on)
Adjustable
[quote]
Tora, will the front Whiteline bars fit? Since the U.S. didn't have a turbo Legacy and I doubt the Baja-T is the same as a JDM Legacy turbo.
FRONT:
Non turbo
BSF14 22mm fixed
BSF14Z 22mm adj
Turbo
BSF15 22mm fixed
BSF15Z 22mm adj
These are the P/Ns I was given recently rears:
Rear (ALL)
BSR12 18mm fixed
BSR12X 20mm fixed
BSR12XZ 20mm adj
02_Forester is offline   Reply With Quote
Basic swaybar install question CBoldman Brakes, Steering & Suspension 2 01-15-2004 07:39 PM
Cusco rear swaybar install question... Sandkicker Brakes, Steering & Suspension 3 05-31-2003 12:09 PM
Swaybar install Question IwantONE Brakes, Steering & Suspension 4 10-20-2002 12:42 PM
front swaybar install question jmott Brakes, Steering & Suspension 6 09-23-2001 01:19 PM
swaybar install question, "don't lift the car" why? Keith Technical Forum Archive 9 05-16-2000 01:10 AM
