Old 07-15-2005, 02:59 AM   #1
tru_to_the_ru
Member#: 89726
2005 WRX
CGM
Default Rims Rubbing?
Im not sure if im going to have this problem, but i bought an 02 wrx and was thinking about getting some rims for it but i dont want them to rub. I used to have a 97 suby and i put 17's on it and they rubbed like a bastard. Any help is greatly appreciated. Also whats the deal with the offset of the rims?
tru_to_the_ru is offline   Reply With Quote
Old 07-15-2005, 03:03 AM   #2
sonicsuby
Member#: 34162
2005 WRX wgn, 01 RS
White, White
offset I believe is +48. I was running 235/40/17 Azenis ST-115 on my sedan no problem. Now I have them on my '05 wagon and only had to remove the rear fender liner
sonicsuby is offline   Reply With Quote
Old 07-15-2005, 11:14 AM   #3
living4surf
Member#: 85216
i have 225/40/18 on my 2002 wrx and no problems with them rubbing but it will depend on if you are going to lower your car
living4surf is offline   Reply With Quote
Old 07-15-2005, 01:44 PM   #4
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
as long as you dont drop your car you wont have a problem runing big rims/tire combo
snowman4us is offline   Reply With Quote
Old 07-15-2005, 01:44 PM   #5
Styley1
Member#: 32566
1999 911 C2
XBL GT: Fenrick
I'm running 17" P1s on my wagon and had 215/45 for several years without any issues. When I replaced my tires this year I bumped up to 225/45's and had some rubbing issues.
Fixed by removing the rubber fender liner as mentioned above. I am assuming you have a sedan, so you will have fewer issues due to the wider fender wells.
I am assuming you checked this sticky:
http://forums.nasioc.com/forums/show...l+offset+guide
Rich
Styley1 is offline   Reply With Quote
on an '08 sti, what is the best FIT rim i can get on 265/ 35ZR/18 tires ? m_pun Tire & Wheel 7 06-03-2010 01:06 AM
Help,Rim Rubbing Coilover Perch E85 WRX Brakes, Steering & Suspension 5 02-08-2010 09:28 AM
Will 18" stock subie tires/rims rub on my 2002 WRX wagon? mespinola Tire & Wheel 9 11-14-2009 09:22 AM
215 tire on 8 inch wide rim? rubbing? pearl Tire & Wheel 5 05-09-2007 01:29 AM
Will these two rims rub on the WRX? eurospec Tire & Wheel 1 01-18-2005 08:48 AM
