Old 07-15-2005, 09:21 AM   #1
83Rabbit
Member#: 5050
Default My Y Pipe is smoking???!!!!
Ok Ive got a 94 L AWD and my Ypipe/cat are smoking! anyone had a problem like this? It seems as if its burning oil off of it (smells like it too) but it happens all the time after being fully warmed up. No oil drops on the ground though so I cant spot a leak difinitively I look under my car and see the pipe where it goes under the engine and trans, literally smoking.... Ive never seen anything like this. Engine temp and whatnot are normal... everything is except this.
83Rabbit is offline   Reply With Quote
Old 07-15-2005, 09:43 AM   #2
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
so thats where you hide your weed...
seriously, maybe there is just a tiny bit of oil dripping on it just enough to smoke. does it ever stop smoking like once you get to work or something? are all your fluids topped off? change your oil recently? maybe you spilled some.
iamrazor is offline   Reply With Quote
Old 07-15-2005, 09:44 AM   #3
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
POST WHORE:
place a piece of clean cardboard under your car tonight. then check it in the morning. thats a good way to see if you have anything leaking.
Old 07-15-2005, 09:46 AM   #4
83Rabbit
Member#: 5050
all fluids look good. It doesnt seem to be a tiny bit because its the legnth that spans uner the trans and engine, its not one spot smoking..... And the oil is a bit full, maybe 1/3 Qt over the full line.
Ill try the cardboard, good call
Old 07-15-2005, 12:34 PM   #5
OBS Fan
Member#: 9751
I bet your front seal is slightly leaking - my EJ22 started doing this at about 120K. Never left any drops of oil on the ground (that I noticed). Oil leaks from the front seal when you're driving and gets blown back onto the Y-pipe and burns. Doesn't take much oil to produce a good stink & visible smoke.
If you have a dealer or other mechanic replace the seal, do the timing belt at the same time (they'll have it off anyway). Search these forums for do-it-yourself. Dealer repaired mine - roughly the cost of replacing the timing belt.
-OBS Fan
OBS Fan is offline   Reply With Quote
Old 07-15-2005, 01:52 PM   #6
83Rabbit
Member#: 5050
belt just got replaced 1k ago lol. Ugh. I guess Ill be watching the timing belt install video in the forum lol. I was guessing thats what was happening but wasnt sure if there was even a seal or something back there that woul make it possible. First things first, i gotta get the siezing pass side caliper replaced. Then onto this debauchery.
Old 07-16-2005, 09:18 AM   #7
kheff46
Member#: 66739
2002 WRX wagon
ding ding ding! front main seal is the correct answer. mine did the mystery smoke, and had the smell(worse when parked). i got a seal and timinig belt and did both in an hour. mine didn't leak at all because when parked there's no pressure in engine, so it won't leak until driving! so you might never see a leak. i noticed low oil(almost no oil) and suspected something. mine had 150k, so it's about time for both!
this is an easy repair, should take you 1-2 hours even if you've never doone one before. i just replied to a post that had this exact info on it. do a search if you need more info! or pm me! there's pics avail. but not sure of video. hope all goes well!
kheff46 is offline   Reply With Quote
Old 07-17-2005, 08:34 AM   #8
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
both my old and new subie had the same issue at a point in time... front seal or oil pan was the concern. (both were front seal AND oil pan issues!) lol. but anyhow, yeah... front seal man.
JonofScio is offline   Reply With Quote
Old 07-17-2005, 11:24 AM   #9
kheff46
Member#: 66739
2002 WRX wagon
i thought my oil pan was leaking also, it was just the three quarts that leaked out i guess! glad i found it in time!
although i did kinda wonder how long i could go with no oil at all!
My turbo blanket is smoking like crazy, is this normal dexterous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 06-10-2009 12:17 PM
help...my 02 wrx is smoking dimpster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-18-2007 11:49 AM
My track pipe is in! CrazyMike13 South East Region Forum 7 01-03-2005 06:26 PM
Help! My up pipe is leaking!! In NC NYguyinNC South East Region Forum 45 12-19-2004 11:20 AM
how can I tell if my up-pipe is leaking? S-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-13-2003 04:18 PM
