Old 07-15-2005, 11:08 AM   #1
gc8impreza00
Member#: 81107
2000 2.5rs
silverthorn/Carbon Fiber
Default Internal wastegate question...
Well Im going to install a turbo kit but I was hoping to have it tuned before I boost my engine...I have heard that it would be possible to take off the wastegate actuator so that the exhaust bypasses the turbine (obviously). anyway, I have the old legacy VF11 turbo and im tryin to figure out how to keep that wastegate open for a 4 hour drive to the tuner. Takin off the actuator doesnt seem like it would help. I understand the idea but I dont know how to keep it open since the spring closes the wastegate... How could I keep that thing open without having to hit max boost?! Anyone have any ideas for this?
or maybe someone teach me how to tune my engine myself...
gc8impreza00 is offline   Reply With Quote
Old 07-15-2005, 12:20 PM   #2
Freon
Member#: 88322
2009 BMW 135i
The actuator is what holds the wastegate shut. If you take it off, the flapper on the wastegate will just stay open, letting exhaust gas bypass the turbine.
The spring is in that little pod do-hickie part of the actuator. If you take off the actuator, the spring is gone as well. Maybe I'm missing something here...
Freon is offline   Reply With Quote
Old 07-15-2005, 12:24 PM   #3
gc8impreza00
Member#: 81107
2000 2.5rs
ur a genius. im a moron. Thanks man
Old 07-15-2005, 01:01 PM   #4
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Even with the actuator arm disconnected and the wastegate held open, you're still going to get some extra air. Perhaps if you kept the revs down and a light foot, you would be fine. Instead of trying to bypass the turbine, why not remove the intercooler and just stick a filter on the throttlebody for the drive?
What kind of EM are you going to be using? You don't have a base map or anything?
ExecNav is offline   Reply With Quote
Old 07-15-2005, 02:01 PM   #5
gc8impreza00
Member#: 81107
2000 2.5rs
wont i still need to do something about the wastegate since the exhaust is runnin through the turbo or no? and yeah im not plannin on drivin over 65mph.
im running the Perfectpower piggyback ECU.
Old 07-15-2005, 02:36 PM   #6
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
The turbo is going to spool up and blow garbage loads of air into your engine bay but as long as nothing is in the way, it won't hurt anything. Probably sound pretty cool too.
I would definitely remove the wastegate arm and wire the wastegate open. I don't imagine that thing needs to be spinning up too much. Or if you want, go ahead and tap your vac lines and hook up the wastegate actuator. Either way works I suppose.
-Brett
Old 07-15-2005, 02:40 PM   #7
gc8impreza00
Member#: 81107
2000 2.5rs
i'll hook up the wire to hold open the wastegate and take off the IC. Listen to the turbo spoolin like a mofo all the way to rallitek might be kinda fun. lol
Old 07-15-2005, 02:44 PM   #8
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Get a boost gauge in and watch your foot - even with my GT28R, I can keep it below boost with the foot on the flat planes - if you do need to go uphill on your way, then it's going to be really tough.
kgb is offline   Reply With Quote
Old 07-15-2005, 02:48 PM   #9
gc8impreza00
Member#: 81107
2000 2.5rs
im going to have to go up and down hills... anyone know of a good cheap boost gauge?
Internal wastegate bracket question Stames_wiltz Factory 2.5L Turbo Powertrain 4 01-28-2009 04:36 PM
internal wastegate questions 2.5rsDOHC Normally Aspirated with bolt-on Forced Induction Powertrain 4 08-10-2007 11:31 AM
Internal wastegate question Depeche Factory 2.0L Turbo Powertrain 6 01-14-2004 03:09 PM
WRX Internal Wastegate question... OKRS25 Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-07-2003 09:40 AM
WRX Turbo Internal Wastegate Question seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 12 08-29-2002 12:56 AM
Message Board Statistics All times are GMT -4. The time now is 06:16 PM.
