Old 07-15-2005, 02:29 PM   #1
MrStiGuyy
Member#: 90634
'06 STI
Flat Blk Sleepin'
Default Best Sti Brake Pads
hey, im trying to determine which are the best type of replacement pads for the sti. im on my second set of stock pads, and the problem is they generate too much dust on the rims, i literally clean them daily. i just put on new rotors so i know its the pads. i was considering the project mu pads, but i've read mixed reviews on them, they grab well, but are more dustier than the stock sti's. does anyone know anything more about the hawk, axxis, or carbotech? some help here would be appreciated.
MrStiGuyy is offline   Reply With Quote
Old 07-15-2005, 02:45 PM   #2
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
RaceComp Engineering is offline   Reply With Quote
Old 07-15-2005, 02:48 PM   #3
boxered
Member#: 61884
1. Did you search through this forum?
2. There isn't a "best" pad for the STi..some dust less by they still dust more than average.
3. You can help reduce dust build-up on the rims by applying a coat of wax on them.
boxered is offline   Reply With Quote
Old 07-15-2005, 06:57 PM   #4
MrStiGuyy
Member#: 90634
'06 STI
Flat Blk Sleepin'
yes i did a search, but i hear so many mixed reviews on them. as for my plans, i plan on a mixture of street and track
Old 07-15-2005, 07:32 PM   #5
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
For tracks, it's usually better to have a dedicated street pad...and also consider dedicated track rotors as well.
eltrouble is offline   Reply With Quote
Old 07-15-2005, 08:27 PM   #6
stiwrx
Member#: 7253
Endless
stiwrx is offline   Reply With Quote
Old 07-15-2005, 11:02 PM   #7
cboggess
Member#: 30804
87 Yugo
Red
While you're going to get tons of opinions on what to get I'll give you probably the only one on what not to get.
Do NOT get porterfield R4S pads for it. Do a search on my name and porterfield on just about any subaru board and you will find my story.
cboggess is offline   Reply With Quote
Old 07-16-2005, 01:36 AM   #8
gregr01
Member#: 49333
04 STi
java pearl black
I use Carbotech Bobcats for street, no squeal and minimal dusting.
For track, I use their XP8s (XP9 if you use race tires). Lots of squeal, lots of dust, super fade resistance and compatible with the Bobcats for swapping back and forth.
gregr01 is offline   Reply With Quote
Old 07-16-2005, 05:19 PM   #9
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
http://forums.nasioc.com/forums/show...97#post8367297
In particular "my pads make too much dust/noise"
I am happy with the Bobcats but they are not a track pad and they definitely dust more than the OEM WRX pads (not sure about head-to-head dust vs. stock STi pads)
When you say "some track" what does that mean? What is your experience level? Are you willing to swap pads before events?
06 sti brake pads will 05 and lower pads fit? freshpl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-18-2007 01:27 PM
STi Brake Pads / SS Brake Lines / Brake Fluid TicketsForMePlease Private 'Wanted' Classifieds 4 11-30-2006 10:47 AM
Best cheap brake pads? Uncle Scotty Brakes, Steering & Suspension 22 06-22-2005 10:01 AM
What's the best improved brake pad for everyday use? dfritz Brakes, Steering & Suspension 66 02-19-2004 05:30 PM
Best of Brake Pads DARTH SkyyWALLker Brakes, Steering & Suspension 29 02-15-2002 10:45 AM
