Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-15-2005, 03:42 PM   #1
Lawsonmh15
Member#: 86815
Question Things that make you go; Hmmmmm...
Well, in my never-ending quest for knowledge of my 99 Legacy SUS; I found something quite odd. I was looking for the Driver Door Power Window relay, (where is that sucker?) but instead, I found an unconnected wire below my dash. So... Yeah. Obviously I hooked that sucker up to see what happened, and the end result was a blinking CEL. ***?!!! This is also accompanied by weird clicking noise with they key in and turned to acc. ( as far as I can go without cranking). So, I turned it off and disconnected the wire which obviously solved the problem. Today I was at a local Checker grabbin' a fuel filter, and I figured I'd have them throw a code reader on.
Without the wire connected, no codes came back.
With the wire connected I get a PO130 (O2 sensor).
Here are my questions. The wire I found is two conductor with a small green spade connector. (Initially I thought the wire went to the seatbelt sensor due to the identical connectors.) Does the wire more than likely go to the O2 sensor? If so, what's its flow? (i.e. O2 -> ECU -> OBD port)? Also, with that wire not connected, am I basically bypassing the O2 sensor? If so, why isn't it negatively affecting me? If not, what gremlin is causing the PO130?
Judging by the weird relay type of click when connected, I'm inclined to believe that the wire is shorted at some point. If not, please explain.
Thanks in advance,
Matt.
Lawsonmh15 is offline   Reply With Quote
Old 07-15-2005, 05:23 PM   #2
Dash_Martino
Member#: 78728
04 STi
oddly i don't think you're the first person to experience the exact same thing
Dash_Martino is offline   Reply With Quote
Old 07-15-2005, 07:05 PM   #3
Lawsonmh15
Member#: 86815
Wow! So we have an engineering feat of mystery. Hopefully one of those people reads this thread.
Old 07-15-2005, 07:07 PM   #4
b00st3d
Member#: 9891
2015 RC-F
Ultra White
check this thread out...
http://forums.nasioc.com/forums/showthread.php?t=797403
probably the same plug.
b00st3d is offline   Reply With Quote
Old 07-15-2005, 07:22 PM   #5
Lawsonmh15
Member#: 86815
That's the one. Kinda weak they don't disclose that stuff... but whatever. Thanks for the expeditious replies. I still don't understand why it causes a CEL with a PO130, but as long as it's not a problem.
Things that make you go hmmmmm..... trevman2 Alaskan Impreza Club Forum -- AKIC 15 03-14-2005 05:45 PM
Things that make you re-examin your life MattSEG Off-Topic 29 07-22-2003 01:10 AM
Things that make you ask, 'What were they thinking?' Kinsbane Off-Topic 26 06-04-2003 03:29 PM
Silver WRX sighting and things that make you go "Hmmm" Coati Southern California Impreza Club Forum -- SCIC 4 12-24-2001 04:20 AM
