Old 07-15-2005, 05:19 PM   #1
dunk
Member#: 15359
Default P0130 and P0171
Throwing the following check engine lights, car has only been turboed for about two tanks of gas. I've looked through all the threads relating to these codes, and have checked the following
Vehicle is a 2002 Forester with a MAP sensor.
Vortech FMU with J&S Safeguard
Vacuum line to FPR is secure, with no leaks.
Checked O2 sensor harness, all secure
Will throw both codes within 15 minutes of driving.
Vehicle has had the ECU refalshed last year before turbo, don't think they replaced the front O2. Invoice doesn't mention the DTC that it threw, however I know it was related to front o2. Could have been the same code.
Heard from reading that P0171 doesn't usually come up if the sensor is bad, and the fact that it happened right after the turbo was put on makes me suspicious of a bad sensor.
I throw myself upon the mercy of your greater knowledge.
thanks
Duncan
dunk is offline   Reply With Quote
Old 07-15-2005, 05:40 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
well the P0171 is fuel trim malfunction, A/F too lean, which yea, you put a turbo on and the 02 sensor is getting too lean of readings, i wonder why
the p0130 is also related to the front 02 recieving too lean of readings.
Ben
Old 07-15-2005, 05:48 PM   #3
dunk
Member#: 15359
o2 sensor is installed in the downpipe. Lots of people have this setup. Do you have any suggestions?
Duncan
Old 07-15-2005, 05:56 PM   #4
PHATsuby
Member#: 13617
2001 Legacy GT back
are you still using your stock ecu for fuel control with just a RRFPR? If it is still controlling fuel and it says you are lean, you may want to turn down the boost until you figure it out because you may in fact be lean. did you ever install the 02 and not hook it up so that it wasnt getting heat?
do you have a voltage clamp on the MAP sensor?
Ben
Old 07-15-2005, 09:41 PM   #5
dunk
Member#: 15359
J&S has a built in map sensor. Using stock ECU and RRFPR. Boost is only at 3psi right now. O2 is hooked up.
Duncan
New Engine with cel... P1092 and P0171 Boxer4h Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-04-2010 08:11 PM
Rough idle and p0171, leak? Jons_uurx Newbies & FAQs 24 02-02-2009 11:45 AM
Lumpy idle at start and p0171?? Ctracer911 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-03-2007 09:53 PM
P0171 and P0136 (too lean and rear o2 sensor) on stock 2.2L impreza - any ideas EZar Normally Aspirated Powertrain 8 05-15-2004 10:53 PM
P0171 engine code after removing boost gauge and TXS Unichip Gcbinc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-21-2003 02:23 PM
