Old 07-15-2005, 08:36 PM   #1
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
Default burnt hole in PS line. need help.
i have an UR uppipe with tial 38, and evidently one of the PS lines was leaning against the flange and melted a hole in it.
it is the outermost line, closest to the firewall.
the one that runs from the top of the pump to the underside of the car and connects to a hard line.
how do i go about replacing this line as it seems the rubber line crimps directly onto the hard lines.
do i have to replace the whole setup from the pump to the underside of the car?
hoping to find some help since it's friday night and the dealer won't be open til monday.
thanks
chrisfranklin is offline   Reply With Quote
Old 07-15-2005, 08:44 PM   #2
thesmokingman
Member#: 17751
Don't drive it. I'd just order a new if possible and time willing.
Which line is it? Check this link here on pg 6.
Here
thesmokingman is offline   Reply With Quote
Old 07-15-2005, 09:04 PM   #3
fourdegrees
Member#: 49662
2005 FEALing fine
fourdegrees is offline   Reply With Quote
Old 07-15-2005, 09:30 PM   #4
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
on ps-4 of that link, it looks like line #8
Old 07-15-2005, 09:42 PM   #5
thesmokingman
Member#: 17751
Eew. That's not a typical leaky line. Ya just cooked it huh. You could cut the line and slap on some AN fittings and use ss line. Any domestic shops near you?
Old 07-15-2005, 10:14 PM   #6
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
do you mean cut the hard line?
or cut the hose?
it's funny that the inner line has a protective piece of metal type loom over it, but the one that runs nearer the downpipe is open.
i'll get under it tomorrow i guess
Old 07-16-2005, 01:01 AM   #7
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Between you two guys, this makes me paranoid, better check to see if all my lines are in order!
Arnie is offline   Reply With Quote
Old 07-16-2005, 01:23 AM   #8
bottlediger
Member#: 47958
CBRD is making new SS brake lines! Pm him
but on another note dont drive your car, it will burn to the ground
bottlediger is offline   Reply With Quote
Old 07-16-2005, 01:43 AM   #9
Javier
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
I burned a hole in that line with my UR ewg uppipe. I had it replaced at the dealer (mistake $$$$). I had them slip a covering over it that has held up for now. I'm gonne get some thermotec wire insolators to cover the wires better and find some way to swing them out of the way.
Javier is offline   Reply With Quote
Old 07-16-2005, 01:46 AM   #10
thesmokingman
Member#: 17751
Man fou you ewg guys, checking your line clearance seems rather important. The extra insulation sounds like a good idea too.
Old 07-16-2005, 01:49 AM   #11
Javier
Member#: 19346
2003 MBP WRX
When I installed the ewg the line was out of the way. After a while it shifted over. It only blew after a 15-20min hard run where I was pretty much boosting the whole time...
Old 07-16-2005, 10:48 AM   #12
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
javier-
did they have to replace the whole setup? hardline and all?
or just the rubber line?
Old 07-16-2005, 03:21 PM   #13
Javier
Member#: 19346
2003 MBP WRX
javier-
They had to replace the whole thing. When you get the new part, call the dealer and have them look it up by VIN. They changed the design a little a few years and they don't all fit the same.
Old 07-17-2005, 01:25 AM   #14
maestro
Member#: 53021
'04 Forester - sold
'72 Datsun 240Z
+1 I'm checking my lines tomorrow. Good luck to the both of you.
maestro is offline   Reply With Quote
Old 07-18-2005, 12:33 PM   #15
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
replacement part from subaru: $270.00
includes both lines. i guess they do not sell separately.
getting steel braided line done locally instead
high fuel pressure problem, blew a hole in fuel line blowbyu24 Built Motor Discussion 12 07-17-2008 08:09 PM
Stupid Question? Hole in the intake... Need help asap! Boostmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-16-2007 06:48 PM
hole in ac line from upgraded intercooler warpspeedwrx Service & Maintenance 7 03-12-2007 09:31 PM
Hole in AC line, Subaru charging too much TheShadowWRX Service & Maintenance 13 04-22-2004 04:25 AM
Hole in AC Line TheShadowWRX Service & Maintenance 3 02-23-2004 01:15 PM
