Old 07-19-2005, 09:59 AM   #26
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
We managed to make piping on a friend's car without removing the AC. Just running the alternator as low as possible, and squeezing between there with a tube worked ok. The alternator sat against the underside of the hose on the TB, and the pipe sat about a finger thickness from the hood.
The tape is holding together the sections that are to be welded. They moved slightly when welded, and we had to make a slight clearance in the hood skeleton, but it still fits and works well.
http://www.projectwrx.com/8Complex/p...m-MVC-401F.JPG
http://www.projectwrx.com/8Complex/p...m-MVC-400F.JPG
Old 07-19-2005, 10:24 AM   #27
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Iíve seen some throttle body forward setups where a non-standard IC (tilted setup ala WRC) was used. It seem to eliminate about 80% of the piping length compared to the off the shelf ICs (Perrin/TurboXS/APS/Ijen/ARC/Ö). This would be a significant gain as it would be striking the balance between having a big core like a FM but the piping length more like a TM.
How many feet of piping did this save you vs. the original Perrin setup? Does it make a significant difference over the standard Perrin setup?
Beyond the performance aspect, I do like the bling factor it creates in the engine bay. I looks like top notch craftsmanship.
StiDreams is offline   Reply With Quote
Old 07-19-2005, 10:55 AM   #28
wgknestrick
Member#: 32576
04 STI
If you read the 1st post, it says I saved 2.5ft of tubing over the Perrin. This is just from the one side. A V-mount would surely save a TON of tubing, but I had to draw the line somewhere. It's enough work as it is. You forget that all this has to work when you are done with it.
I am still tracking down leaks.
A word of the wise to people looking to powdercoat tubing, do not use textured tubing. This stuff is giving me a tough time trying to seal it.
wgknestrick is offline   Reply With Quote
Old 07-19-2005, 11:01 AM   #29
wrex03
Member#: 29963
04 sti
Nice job.... Interested in hearing driving impressions once you have the leaks fixed.
wrex03 is offline   Reply With Quote
Old 07-19-2005, 04:22 PM   #30
GeorgeRex
Member#: 51695
2004 STi
Did you put a bead on the end of the pipes ? See picture below for porfessional solution. Shadetree fix is to weld a bead on the pipe. It works (29 psi on my Lancer...)
GeorgeRex is offline   Reply With Quote
Old 07-19-2005, 05:07 PM   #31
wgknestrick
Member#: 32576
04 STI
It's not that the couplers are popping off which the bead rollers fix, it's just that they are tough to get to seal. I think I have most of the leaks fixed, but the damn blow thru MAF is still leaking.
Old 07-19-2005, 05:11 PM   #32
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Just mark the pipe and grind off the finish up to 1/4" or so of the end of the hoses, that way it looks like it's coated all the way, but it can fully seal on the bare ends of the piping.
Old 07-20-2005, 02:30 AM   #33
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
wow... show car.
great werks my man
BREWPUBEAVER is offline   Reply With Quote
Old 07-20-2005, 02:46 AM   #34
InfamousDX
Member#: 25413
Originally Posted by BREWPUBEAVER
wow... show car.
great werks my man
damn... if you think that's a show car you're nuts. hydra standalone.. big turbo... what a show car
Anyway, that engine bay is looking BEAUTIFUL man. 2.5' of piping... now that's something worthwhile. Great job!
Old 07-20-2005, 03:04 AM   #35
bosaleh
Member#: 56885
2000 IMPREZA Ra Blue
[email protected] bar
Did you drive your Scooby I need your first impression and did this changed in the performance what about the lag dose reduced like 500rbm or moor?
ITS ONLY MY00
http://spaces.msn.com/members/bosaleh/
bosaleh is offline   Reply With Quote
Old 07-20-2005, 07:13 AM   #36
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Originally Posted by offset
Looks awesome!! But why didn't you paint the oil cap, dip stick, and coolant cap like the rest of the stuff (actually I would just find some ricey sticker to recover the coolant cap)? What paint did you use for the rest?
TIA,
offset
He used black powder coating.
Looks awesome Bill. Good job on this custom setup.
SilverSurfer04STi is offline   Reply With Quote
Old 07-20-2005, 03:52 PM   #37
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
nice work.
Old 07-20-2005, 08:18 PM   #38
T3RMIN4L
Member#: 37434
any luck with that blow through Bill?
T3RMIN4L is offline   Reply With Quote
Old 07-20-2005, 09:14 PM   #39
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Very very impressed. I would love to do this on my car when I switch to FMIC. I think the APS routes the pipes the opposite way, though.
Nixlimited is offline   Reply With Quote
Old 07-20-2005, 09:33 PM   #40
wgknestrick
Member#: 32576
04 STI
I am having problems with leaks right now. I still have one intake leak with it leaking at the MAF sensor and multiple exaust leaks due to poor fitment of the Godspeed kit.
So far I have been having problems with most of the Godspeed Spec 650R pieces. The MAF hole is about .010" smaller than stock which causes the O-ring to bind up and not seal. And the EWG pipe fitment is poor causing a leak at the V-band flange because it is not square. Dan claimed that blow thru was the answer, but I cannot get the car to even idle with the MAF sensor plugged in on the stock ECU. I also have a ODB2 inspection in Dec! I am truely screwed. I will try to sort this out when I get back from vacation next week, but I am having problems.
At least it looks nice.....
Old 07-20-2005, 10:18 PM   #41
bosaleh
Member#: 56885
Thumbs up
Wishing you all the best luck to finish what you started and all pray for you too
I like the talent people doing the hard work and go over the limits
Hope to see every thing ok in the short future
ITS ONLY MY00
Old 07-20-2005, 10:35 PM   #42
wgknestrick
Member#: 32576
04 STI
wow... show car.
great werks my man
Actually thanks for the compliment, but you couldn't be further from the truth. Everything in my car is for go, not show.
I seriously understand where you are coming from and thank you for the compliment again (I know you have good intent), but please don't call a STI with this much engine in engine mods, WRX wing, WRX scoop, WRX side skirts, only one STI badge in front, no STI seats, no PS2, no Xbox, no LCD screens, etc a show car. I built this car for one reason, to scare the **** out of me any anyone who may happen to be in the passenger seat. I made the engine bay look nice to represent how much work went into it that is all. If you saw my car on the street, you think "hey who's the poser that put the STI badge on the WRX?". You surely wouldn't ask "why does that guy have LCD screens in his fender well?"
I really think it is a shame where "show" cars have gone, but not to get this thread off track.
Are there any other questions about this mod that is still left in the air? I tried to share all problems I came across, but I could have left some out. Once I get these problems solved, I will polish and post on scoobymods.
Old 07-20-2005, 11:23 PM   #43
SpaldingSpeed
Member#: 83640
2005 Impreza WRX STi
World Rally Blue Pearl
incredible looking engine bay sir, can't say I agree with all the "de-badging" and wing changing, but that's just me, I am currently working on a intake manifold project with hydra standalone....just wondering why you are using the MAF......doesnt hydra alow for speed density, elimnating a MAF altogether?
SpaldingSpeed is offline   Reply With Quote
Old 07-21-2005, 07:05 AM   #44
wgknestrick
Member#: 32576
04 STI
ODB2 Inspection here in PA. I swap in the stock ECU a week before I have to be inspected
Old 07-21-2005, 08:22 AM   #45
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you need to find a "friendly" shop...
Old 07-21-2005, 01:48 PM   #46
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Actually what I was wondering about was the red paint. Any info on what brand/color was used for the red bits?
offset
offset is offline   Reply With Quote
Old 07-21-2005, 03:47 PM   #47
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Originally Posted by Alleggerita
So I am curious about the one person that managed to keep their AC with the reversed manifold - I'd love to see what they did. That would be something a vendor should offer as a commercial kit, that is a reverse manifold set-up that allows to keep the AC.
A local guy did it and I think he has/will sell a kit. PM me if you want his contact info.
Old 07-25-2005, 07:00 AM   #48
kidatari
Member#: 10441
(insert big honking turbo pic here)
Holy... crap!~ Any more info on that setup?
kidatari is offline   Reply With Quote
Old 07-25-2005, 09:47 AM   #49
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I think its a 2.35 block, T-62 turbo, 200 shot of NOS, and he uses MoTeC for engine management. It's quite fast though hasn't been at the track in awhile.
Old 07-25-2005, 10:14 AM   #50
TheMadScientist
Member#: 23717
2005 Big red
You still need the IAT.
TMS
TheMadScientist is offline   Reply With Quote
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
