Old 08-15-2008, 03:49 PM   #551
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Originally Posted by engineerx View Post
Yeah , I'm willing to bet you would not get any perfomance difference with either. - Just touch the AL pipe after the engine has been running hard for 20 min, compare it to SS pipe = OUCH !! they both will burn the F out of your hand ! the key property is conductivity and the key reason to use either is wich one you can fab up easier. If you have someone who can weld AL then that's the better and cheaper choice - SS prices have skyrocketed thanks to China & India heavy demands
I would ceramic coat what ever pipe I use anyways so there
CoolRex is offline   Reply With Quote
Old 08-15-2008, 04:00 PM   #552
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Perfect solution and exactly my plans for the IC pipes...
HPC coatings - in black = sexy !
engineerx is offline   Reply With Quote
Old 08-15-2008, 04:01 PM   #553
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
What does HPC stand for? It a DIY coating? If so linky?
Old 08-15-2008, 06:27 PM   #554
engineerx
Member#: 42614
0405 WRX STi/S2000
their price is fairly reasonable for their Hipercoat
Semi-gloss black is what I'll go with but if you want some bling you can use the polished aluminum or flat red colors
http://www.hpcoatings.com/am/product...hipercoat.aspx
There are alot of companies that do ceramic coatings. I've used HPC and have liked their Hipercoat coatings
Old 08-15-2008, 07:14 PM   #555
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I'd rather do a DIY. I'm thinking of using Techline coatings.
Old 08-15-2008, 07:53 PM   #556
dub c
Member#: 145069
Keep It Sleazy
is it possible to reverse the jdm spec c intake manifold (eliminated tgv's...goes all the way down to the heads.)?
im just wondering because i like the fact that the spec c mani completely eliminates the tgvs and im definitely going to do the reverse mani.
dub c is offline   Reply With Quote
Old 08-16-2008, 11:49 AM   #557
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
yes45
skate enjoi is offline   Reply With Quote
Old 08-16-2008, 07:29 PM   #558
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
yes, eclip5e is doing one right now.
scby rex is offline   Reply With Quote
Old 08-17-2008, 12:17 AM   #559
vtboost
Member#: 155580
2002 w/ 04 front end
& STi drivetrain
love his car can't wait to see the finish product of that
vtboost is offline   Reply With Quote
Old 08-17-2008, 04:02 PM   #560
dub c
Member#: 145069
Keep It Sleazy
ah great!
...eclip5se be sure to post that up!!!
Old 08-17-2008, 04:36 PM   #561
scby rex
Member#: 104878
02 wrxbastardchild
Yeah, hes having troubles getting his motor back together, so Im hoping in the next few weeks he'll have it running. BTW I dont know him personally, just follow his build.
Old 08-18-2008, 04:54 AM   #562
engineerx
Member#: 42614
0405 WRX STi/S2000
Here's some pics - 2.5" pipe from turbo outlet to APS IC hose
Old 08-18-2008, 06:26 AM   #563
Calitri-Boost
Member#: 109090
08 IS-F
WFC Mbr # 004
Nice set up ^^^ looks like u still have your AC too? any pics showing how close the charge pipe is to your Koyo?
Calitri-Boost is offline   Reply With Quote
Old 08-18-2008, 08:58 AM   #564
xxscaxx
Member#: 86459
2013 BRZ
egineerx - thank you so much for that picture. im going to order the same stuff you got. see my aps piping comes up almost right to the top of the fender, so it wont be too much of that 90 degree piping going down there.
xxscaxx is offline   Reply With Quote
Old 08-18-2008, 12:47 PM   #565
engineerx
Member#: 42614
0405 WRX STi/S2000
no prob....
As I mentioned before - if you want to use the 90* 2.5" OD elbow make sure it's a 3-inch bend radius - get the 20-gauge (0.035" thickness) it's just as light as AL pipe.
I did have to make the fender opening larger.... I used a hammer to make it larger to allow using the straight pipe & 90*. Because it comes out of the fender at an angle, you need more room to line up to the turbo outlet. I sprayed it with paint to inhibit any rusting since the bending messes up the paint around the edge. Then I used rubber trim around the edge. The larger opening makes fabbing the pipes alot easier as you don't need to use two bends - like the APS silicone hose coupler.I tried to use as few bends as possible.
The turbo kit I have is an Ultimate Racing kit. The turbo outlet and the 90* elbow from the outlet line up nicely with the pipe. Others kits line up differently as the turbos are tilted / rotated differently.
Calitri: Yes, I kept the AC. The pipe does come very close to the Fluidyne rad. I still need to weld a bracket to the throttle side pipe to firmly locate it and fasten it to the engine. The IC rubber hose that it couples to will take care of engine movement, so no need for hump couplers.
Here's pic, shows pipe/rad clearances
My previous setup was OK, I just didn't like the look of the pipe going across to the fender. I'll probably put those pipes up for sale. They're nicely welded SS pipes.
http://forums.nasioc.com/forums/show...&postcount=272
Old 08-18-2008, 01:55 PM   #566
xxscaxx
Member#: 86459
2013 BRZ
engineerx - i shot ya a pm.
Old 08-18-2008, 02:13 PM   #567
skate enjoi
Member#: 120716
2002 psm ver7 wrx
yeah I was planning on running the hotside pipe under the intake manifold but it looks like you save a lot of piping just clocking the turbo and running it straight to the fender
Old 08-18-2008, 02:25 PM   #568
xxscaxx
Member#: 86459
2013 BRZ
it also looks a ton better running it to the fender
Old 08-18-2008, 02:42 PM   #569
xxscaxx
Member#: 86459
2013 BRZ
engineerx - your pm box is full
Old 08-18-2008, 03:18 PM   #570
engineerx
Member#: 42614
0405 WRX STi/S2000
yeah.. got a barrage of PM's just know -
I cleared some old PM's
yeah- it looks better running under the intake and you do save some lenght of pipe.
Old 08-18-2008, 03:27 PM   #571
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
edit: wrong thread
wcbjr is offline   Reply With Quote
Old 08-18-2008, 07:39 PM   #572
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Wow the new piping looks awesome Roland! When are you coming up here to get your race gas tune?
-Dan
suby_dude is offline   Reply With Quote
Old 08-19-2008, 11:31 AM   #573
engineerx
Member#: 42614
0405 WRX STi/S2000
-Dan
Thanks Dan!
Hopefully soon.
I want to finally get the Alky Injection installed. Already ran the tubing- just need to connect the electronics and get it to work with the Hydra 2.6
Everything is working well so far. New build is good. Just gotta make some time to head up to Speed Element and get it tuned.
Old 08-19-2008, 11:54 PM   #574
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
What did you guys do with new line re-routing, specifically regarding the ones in the area of the stock positioning of the alternator?
007WRX is offline   Reply With Quote
Old 08-20-2008, 12:10 AM   #575
mannslayer
Member#: 94978
how to place the alternator in the stock location without kinking these lines?
mannslayer is offline   Reply With Quote
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
