Old 10-02-2005, 01:01 AM   #101
subalou1
Member#: 57966
2002 wrx Sedona Red
[email protected], best trap 131
I want to start by saying everyones set up is quite nice. I was wondering if any work have to be done to the intake manifold or can it just be flipped?
subalou1 is offline   Reply With Quote
Old 10-04-2005, 06:30 PM   #102
metoo
Member#: 4764
2004 STi sold :(
forizzle
From what I hear, it fits both ways. The creativity comes when trying to make room for the throttle body. You can lower the alternator, or ditch the A/C and move the alternator to that location, or raise the intake manifold.
metoo is offline   Reply With Quote
Old 11-02-2005, 05:25 PM   #103
bboy
Member#: 56468
04 Improved STI
Dirty White
Originally Posted by metoo
Okay, I borrowed an impact wrench. It worked like a charm. I lowered the Alt as far as the tensioner slot would allow. I put the new NAPA/Gate Micro-V 050340 on the StPump and crank pulleys, then on the removed Alt pulley. The I tried to force the pulley back on to the shaft. Not cloe enough to even force into place.
Plan B
Broke out this baby and my Craftsman rotary tool and extended the tensioner slot to access the threaded hole in the Alt when it was at its lowest posible point with the screw out.
I tried to put the pulley on and was just able to force the pulley over the first 2 threads of the shaft by hand power. Then I used a block of wood and a hammer to put it all the way on. Needless to say, there wasn't much tensioning that had to be done. The Alt can be absolutely no lower. Now I ust have to actually reverse the manifold and see if I have the same luck as Joker13, and not need spacers. I have and STi, so the TB may fit differently.
OK, I'm in the thick of this right now. One trick I found was to remove one of the alternator case screws temporarily. This allows you to drop the altenator down below where the screw slot permits. I'm hoping that this will aid in fitting the belt. Then pull up on the altenator to slip the case screw back in--I'll report back to see if this permits install of the belt without removing the altenator pulley or perhaps makes it easier to re-install the pulley if it is removed.
Taking the case screw out drops the altenator about another 1/4-1/2 of a inch.
Old 11-02-2005, 06:19 PM   #104
suberboy
Member#: 1531
2008 GRB
Red
here is another nice reverse manifold set up on an 04/05 STi
http://www.cockpit.co.jp/new/topics/...gdb/index.html
suberboy is offline   Reply With Quote
Old 11-02-2005, 07:07 PM   #105
bboy
Member#: 56468
04 Improved STI
Dirty White
My favorite is member Alan G's set up below. Very short intercooler piping for responsiveness.
I ordered the 34 inch and a 34.5 inch Gatorback 5 rib belts. We'll see if the screw trick does the trick. I'm still worried about tensioning the belt and hitting the throttle body, but there's always spacer work between the TVG/manifold to fix that.
Old 11-02-2005, 07:13 PM   #106
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
wow that cockpit setup is really nice!
wrxtremeWGN is offline   Reply With Quote
Old 01-10-2006, 06:04 PM   #107
ezparts
Member#: 10555
2004 STi
bboy: any more pic and info on Alan G's setup?
ezparts is offline   Reply With Quote
Old 01-10-2006, 07:18 PM   #108
bboy
Member#: 56468
04 Improved STI
Dirty White
I left it with Lateral Performance to find out if their rad-IC combo would fit the GDB compartment. I'll write to Mark again and ask if he's tried installing one yet.
I've also seen a set up like Alan's that instead of running under the manifold it runs over it (no coolant reservoir).
I need to post a pick of my car. It's about 1/2 of Alan's set up. I lost about 3 feet of tubing.
Old 01-24-2006, 10:37 PM   #109
jimtweet
Member#: 52225
2004 wrx 1966 stang
1973 porsche
some more pics before tear down
manifold is being powdercoated wrinkle black and the piping in a dark silver
cant say enough good stuff about HILL and ANNIE over at AGILE, awesome people and awesome customer service
jimtweet is offline   Reply With Quote
Old 01-24-2006, 10:44 PM   #110
03twrx
Member#: 73737
I've travled 500 mil
es to give you my seed
Can I ask why we're spinning intakes here?
03twrx is offline   Reply With Quote
Old 01-24-2006, 10:46 PM   #111
jimtweet
Member#: 52225
2004 wrx 1966 stang
1973 porsche
shorter piping for fmic means less lag
Old 01-24-2006, 10:52 PM   #112
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
my version, in progress
Ben
Old 01-24-2006, 11:20 PM   #113
wgknestrick
Member#: 32576
04 STI
That is pretty crazy stuff. You have a ton of stones to try a 6cyl swap.
wgknestrick is offline   Reply With Quote
Old 01-24-2006, 11:21 PM   #114
Peeblesmx445
Member#: 92202
^Dude, just what in gods name is that??? HAHA JK. H6 EZ30 I pressume?
Peeblesmx445 is offline   Reply With Quote
Old 01-24-2006, 11:25 PM   #115
03twrx
Member#: 73737
That's the only reason? Hmmmm.... I'd like to see befor and after plots
Old 01-24-2006, 11:33 PM   #116
9vapors
Member#: 92582
Well here is the guy from SunAsia, a shop in Taiwan. His setup is sweet!
And another:
9vapors is offline   Reply With Quote
Old 01-24-2006, 11:58 PM   #117
PHATsuby
Member#: 13617
2001 Legacy GT back
wgknestrick-haha, yea I am a bit crazy or so I am told
peebles-you are almost correct, it is a H6 EZ30R getting ready for boost
one thing I am curious about, how did people move their Alternators over to the one side? Do you have a custom bracket made for the far right hand side(looking at motor) or how is it secured? It doesnt look like my H6 accessories will do that but maybe I can use an EJ setup So i dont need to offset the TB.
Any info on that would be awesome, thanks!
Ben
Old 01-25-2006, 12:32 AM   #118
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
I have a thread in AFI now for a picture request of people running reverse manifolds on the GC platform.
If you guys have any, or know of anyone who has done this please let me know, or post in the AFI thread.
Thanks
Alex
Old 01-25-2006, 07:42 AM   #119
AlanG
Member#: 22677
Have sent you a PM with Email Alex.
AlanG is offline   Reply With Quote
Old 01-25-2006, 01:42 PM   #120
bboy
Member#: 56468
04 Improved STI
Dirty White
AlanG has the THE set up from Lateral Performance.
Old 04-01-2006, 12:54 PM   #121
2004stiwrb
Member#: 70613
i'm @ the dragstrip
with over 600awhp!!!!!!!!
hey wgknestrick, thanks for the step by step info. i've been thinking about doing this and i've been searching for pics of different setups and i stummbeled across this and was like WOW. awsome job man.
2004stiwrb is offline   Reply With Quote
Old 04-01-2006, 04:32 PM   #122
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
^^^Here is my setup. I followed wgknestrick's setup for the most part.
http://forums.nasioc.com/forums/showthread.php?t=952557
SloRice is offline   Reply With Quote
Old 04-02-2006, 03:52 PM   #123
PHATsuby
Member#: 13617
2001 Legacy GT back
So are people saying that you ABSOLUTELY cannot reverse the STi manifold without removing A/C and flipping the alternator over, or can it be done going over the alternator with it lowered?
I have seen it done but I think that was on wrx setups and not STi's.
thanks for the Help!
Ben
Old 04-02-2006, 03:59 PM   #124
PHATsuby
Member#: 13617
2001 Legacy GT back
one other thing, the bolt spacing appears to be symmetrical for the manifold, can you not just take off the manifold and leave the TGV's in place and flip it and not have to deal with the fuel or injectors at all?
Sorry don't have a STi to look at trying to gather info for someone else I will be helping do this.
thanks.
Ben
Old 04-02-2006, 06:09 PM   #125
SloRice
Member#: 44351
2004 Mitsubishi Evo
^^You can do it without removing the AC. Some people have done it. I just chose to remove it due to weight savings.
Also, yes, you just remove the manifold. The TGV's stay where they are at. You will have to mess with the fuel lines and engine harness though as they are bolted to the underside in the manifold.
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
