Old 05-13-2010, 09:50 PM   #1251
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Originally Posted by 1fly05sti View Post
^^looks like a pt6262..where did you get the line for the power steering
You talking to me? I was asking cunningham what turbo he had.
The turbo on mine is a new pt&e 5557 billet. I made the p/s lines myself.
scby rex is offline   Reply With Quote
Old 05-14-2010, 07:47 PM   #1252
1fly05sti
Member#: 151009
05 STI OBP
under construction
lol didn't realize it was the same person i like the way the line came pretty cool
1fly05sti is offline   Reply With Quote
Old 05-14-2010, 11:26 PM   #1253
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
I am running the new BorWarner S259 twin scroll. I love it power comes on arond 3,000 RPM all the way to red line. At 18 PSI I made 360WHP and at 22 PSI i made 424WHP. The turbo was very happy @ 22 PSI but the cluch didn't want to hear it. It can run up to 35Psi no propb!
CUNNINGHAM is offline   Reply With Quote
Old 05-15-2010, 07:50 PM   #1254
scby rex
Member#: 104878
02 wrxbastardchild
hhaha, very nive, Im excited to see what this little PT&E turbo will do on my stock ej205. Thanks 1fly, it cost a little more than I wanted to spend but is exactly how I wanted it.
Old 05-16-2010, 01:37 AM   #1255
starcraft227
Member#: 193773
2004 WRX
JBP
Hi, I try to look for pics with the PCV system on the reverse manifold. Can anyone he out with that?
starcraft227 is offline   Reply With Quote
Old 05-17-2010, 06:32 AM   #1256
Corsa Veloce
Member#: 164634
Does a reversed reverse mount manifold count?
apparently 1100hp at the engine.
Corsa Veloce is offline   Reply With Quote
Old 05-17-2010, 08:27 AM   #1257
25rsti
Member#: 166324
nice turbo/headlight!!!
Old 05-18-2010, 02:15 AM   #1258
subypal
Member#: 218185
2002 SubyPAL.com WRX
here's the latest of my reversed setup, completed.
subypal is offline   Reply With Quote
Old 05-18-2010, 08:08 AM   #1259
BoostbyU06
Member#: 156340
2007 STI
Default Official Reversed Intake Manifold / TB Thread
Looks like you kept a/c as well. What size spacers are you running?
BoostbyU06 is offline   Reply With Quote
Old 05-18-2010, 10:21 AM   #1260
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Nice quote of all the pics...
wcbjr is offline   Reply With Quote
Old 05-18-2010, 01:16 PM   #1261
BoostbyU06
Member#: 156340
2007 STI
Oh thank you that's what I was going for
Old 05-18-2010, 02:45 PM   #1262
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
at least go back and edit the post..
Old 05-18-2010, 08:52 PM   #1263
scby rex
Member#: 104878
02 wrxbastardchild
8mm are usually the size used to keep the ac.
Old 05-18-2010, 11:09 PM   #1264
Adrenalin Rush
Member#: 76729
2004 WRB WRX 2.7L
S400SX3, PPG, AEM, 701whp
Gotta love that Borg Warner!!
Adrenalin Rush is offline   Reply With Quote
Old 05-19-2010, 03:05 PM   #1265
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I'm planning on reversing a 2.5i manifold off a 2005 impreza on my 04 sti. Phil from element used this but not reversed. He used 15mm spacers to clear the avcs solenoids. In my case will I still need spacers since it's reversed it may clear the solenoids? Anyone reverse this manifold? I tried a search in this thread but results didn't show anything. I also want to retain a/c.
For reference here's a pic of the 2.5i manifold not reversed:
methaddict is offline   Reply With Quote
Old 05-20-2010, 09:49 PM   #1266
scby rex
Member#: 104878
02 wrxbastardchild
Nope, no-one has revesed one, Im pretty sure its too tall. Id just set it on your motor and see what clears before you dive in IE. HOOD clearance. 100% sure the alt will need to be flipped to the ac location. Take some pics and post it up when the manifold is placed, that way it will be in this thread.
Old 05-21-2010, 07:21 PM   #1267
starcraft227
Member#: 193773
2004 WRX
JBP
Hi, I was able to reverse my manifold without using the spacer, just lower the alternator and still keep the AC. I have to extend all the black hoses that connect to the manifold( I suppose everyone have to do that right???). However, I have trouble clean up all those hose( just to make engine bay less complicated). I will post pic up later.
Hood clearance isn't issue at all, I cut the section of the hood that rub the intercooler hose and it fit perfectly.
Old 05-22-2010, 02:51 PM   #1268
scby rex
Member#: 104878
02 wrxbastardchild
No spacers? What size belt was used, what size i/c piping and what year car? Thanks.
Old 05-22-2010, 08:04 PM   #1269
starcraft227
Member#: 193773
2004 WRX
JBP
It's 04 wrx. I used 34.5 in belt or something( i will update later). 2.5 hot/2.75 cold pipe. I have to grind something in order to make it fit( not much of grinding anyway). I will post pic soon
Old 05-23-2010, 02:09 AM   #1270
methaddict
Member#: 159738
2004 WRB STi
So you reversed the 2.5i intake manifold? You have a wrx which doesn't have avcs solenoids to have to clear. So in my case I would need spacers.
Old 05-26-2010, 02:06 PM   #1271
starcraft227
Member#: 193773
2004 WRX
JBP
I reverse my stock manifold, from 04 wrx( not 2.5i manifold). I dun know avcs solenoid is but all I do is grind down the alternator a bit so my pipe not touch it.
I also thought since the purpose of reversing manifold is to shorten the fmic pipe, so I also reroute my piping to make it even shorter. I save about 5-6 ft of pipe length, and it def spoon faster.
here is some pics, engine bay is messy though.
Old 05-27-2010, 06:13 PM   #1272
scby rex
Member#: 104878
02 wrxbastardchild
Does your hood close? You need to do the coolant bypass mod too. I also wouldnt run hoses between the tb and alt.
Old 05-28-2010, 12:17 AM   #1273
starcraft227
Member#: 193773
2004 WRX
JBP
Yeah I will have to fix that hose b/t the TB and Alt. Thanks
Yes. My hood closes perfectly. I cut the section of the hood, but i didn't take pic of it though.
I'm researching coolant bypass mod now.
Old 05-28-2010, 12:19 AM   #1274
starcraft227
Member#: 193773
2004 WRX
JBP
All right, seem like the search function didn't help at all. can any1 give me a hint? Thanks lot
Old 05-28-2010, 09:40 AM   #1275
xxscaxx
Member#: 86459
2013 BRZ
http://forums.nasioc.com/forums/show...8&postcount=33
there ya go man. also, dont need to use that barb fitting. just use the existing hose line. one is long enough to reach both points. (so you have to remove one line and then just attach the other line to that side).
very simple.
xxscaxx is offline   Reply With Quote
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
