Old 04-02-2006, 07:41 PM   #126
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
awesome, thanks for the info Tim.
So, just dropping the alternator down I am assuming a new belt is still needed...hmm I'll have to find out about that.
when you say I will have to mess with the fuel lines and harness you are just talking about the couple bolts that hold the hardlines and the plastic plugs that hold the harness right?
also, just to be clear it can be done with no hood clearance issues, one person told me it couldnt be done without cutting a hole in the hood pretty much(maybe skeleton I am not sure).
thanks again.
Ben
Old 04-02-2006, 08:46 PM   #127
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
Here is a picture of the dentsport time attack car we built this summer, also featuring a reverse mounted manifold we fabricated in house.
You can check out the specs of the motor at our site www.dentsport.com
-Nate
dentsport is offline   Reply With Quote
Old 04-03-2006, 12:10 AM   #128
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Originally Posted by PHATsuby
So are people saying that you ABSOLUTELY cannot reverse the STi manifold without removing A/C and flipping the alternator over, or can it be done going over the alternator with it lowered?
I have seen it done but I think that was on wrx setups and not STi's.
thanks for the Help!
Ben
Ben ive done it (or actually my workshop did) have a look at my build. on an 04 STI.
topic:
"Progressive pictures of GT35R custom rotated mount"
tino is offline   Reply With Quote
Old 04-03-2006, 12:12 AM   #129
tino
Top Scoob 019
Member#: 43630
thanks again.
Ben
Yes u will also need a new belt. With the fuel lines u cant just flip them around. My workshop went for braided lines to remove the headache of the hardlines.
It fits under the hood perfectly, with more room to move. using 2.5" pipe asfaik
Old 04-03-2006, 01:03 AM   #130
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
thanks again.
Ben
No problem!
You are correct, just unbolt the fuel lines and harness from the manifold and then switch it around. Unfortunately nothing really "bolts" up to the manifold after that. We opted for the Perrin fuel rails to get those out of the way instead of messing with the stock rails. Then on the wiring harness, we removed all the plastic pieces that hold the harness to the manifold. That way it became more plyable and easier to move around. Then all of the vacuum lines become a major issue and have to be rerouted because nothing is where it used to be.
As for hood clearance, I have a couple inches at least, but I have the 45* coupler coming right off the throttle body to get the pipe down....no alternator to go over. But I've seen pictures of different setups with people getting over the alternator without problems. Just don't know about hood clearance.
SloRice is offline   Reply With Quote
Old 04-03-2006, 01:29 AM   #131
PHATsuby
Member#: 13617
2001 Legacy GT back
awesome, thanks for the great info guys!
hmm, I will be using 3" piping into the TB since this will be a blow through setup, hopefully that extra 1/8" each way wont be my end, haha may need to make some aerodynamic "indents" jk, it should be doable, will just need to mock up carefully and triple check clearances.
thanks again, more questions may be on the way, actually I guess one right now, is where are people sourcing their belts, does a place like napa have that large of a selection to just choose from?
Ben
Old 04-03-2006, 01:50 AM   #132
SloRice
Member#: 44351
2004 Mitsubishi Evo
I got my belts from Advanced Auto. We're regulars there and the workers let us hunt around for stuff we need behind the desk.
Old 04-03-2006, 06:07 PM   #133
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
I would LOVE to see before and after dynos. Even my lowly VF39 can pressurize my FMIC rather quickly. I can't image 2.5' being measureable (and fwiw, my setup spools the same, it's the throttle response from vacume to full boost that changed).
Nice writeup, this should be in a FAQ! Great job.
TypeC is offline   Reply With Quote
Old 04-03-2006, 07:44 PM   #134
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Ben
Here's mine with all accessories in place. We used a Legacy manifold to get around said issues.
Check out my Journal for more info.
Nixlimited is offline   Reply With Quote
Old 04-03-2006, 07:54 PM   #135
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
WOW! That's a great idea! And the best part is you only need to fabricate 1 pipe! It's perfect for blowthrough too it looks like
Capt Crunch is offline   Reply With Quote
Old 04-03-2006, 07:57 PM   #136
Capt Crunch
Member#: 10852
oh no, ,I just realized, this will onyl work on USDM stis, because you guys use DBW throttle.
dammit!
Old 04-03-2006, 08:20 PM   #137
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Yup, and it is blowthrough. Look at the bottom of the straight pipe and you will see the MAF sensor.
Old 04-03-2006, 08:36 PM   #138
PHATsuby
Member#: 13617
2001 Legacy GT back
Yea, Jarrad and I did that on his GT(I think we were the first) I suggested this would be the nicest and easiest route but the friend I am doing it for doesnt like the idea of "plastic" for a manifold or the black color and fears more restriction. Personally none of these would be issues for me nor do I think its more of a restriction at all, but it is not my car so I must do what I am asked Congrats on that setup, it looks nice. I have those saved, haha.
Ben
Old 04-03-2006, 08:47 PM   #139
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Ben
Forgive my ignorance, but if you work for/at PDX, then yes, the credit is yours. This idea was based off seeing the PDX LGT with reversed manifold at SEMA, though I think I may be the first STi with such a setup. I think it solves lots of problems and the black manifold actually looks good in my engine bay with everything else changed.
Old 04-03-2006, 09:49 PM   #140
PHATsuby
Member#: 13617
2001 Legacy GT back
haha, no need for forgiveness, its no big deal. Your's is the first STi i know of to do this, and its smart too, I am surprised others have not done it as well good job for being the pioneer!
I do work at PDX but am currently not there, hence why i do not have a STi at my disposal, haha.
thanks for the help.
Ben
Old 04-03-2006, 10:19 PM   #141
STI_FFY
Member#: 37519
2004 STi JBP/Gold
Helix DP, SMC, Cobb AP
It looks as though the piping is not significantly shorter than if you had not reversed the manifold.
Do you know what length of piping was actually eliminated via this reversal?
STI_FFY is offline   Reply With Quote
Old 04-04-2006, 12:12 AM   #142
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Probably about 2' or so. However, the length of piping is not as big a concern as the number of bends. By doing it this way, we cut out another 180 degrees of bends. Overall, though the power gained specifically due to this setup may be minimal, I think the engine bay looks way nicer and frankly I wanted to do something original.
Old 04-04-2006, 12:20 AM   #143
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
nice work. looks great!
wrxtremeWGN is offline   Reply With Quote
Old 04-04-2006, 12:42 AM   #144
NattiRex
Member#: 96738
96 Talon
New guy here so i don;t need a detailed answer: Whats the benifit of the reverse manifold, reversing it alone cannot make more power can it, is it simply for FMICs to shorted the amnount of tubing nessecary and thus redcue lag and acheive better spool and throttle response?
NattiRex is offline   Reply With Quote
Old 04-04-2006, 01:04 AM   #145
STI_FFY
Member#: 37519
2004 STi JBP/Gold
I have no problem at all with "doing it for the art".
Old 04-04-2006, 02:50 AM   #146
Bolster
Member#: 22290
2002 WRB WRX Wagon
The LGT manifold looks like a great solution, but won't work for turbos in the stock location for obvious reasons. Can you attach a drive by cable throttle body to one of those manifolds?
Bolster is offline   Reply With Quote
Old 04-04-2006, 09:32 AM   #147
PHATsuby
Member#: 13617
2001 Legacy GT back
not without an adapter, the bolt spacing is different than the cable TB's.
Ben
Old 04-04-2006, 12:25 PM   #148
M3GTR
Member#: 21965
V-mounted 40R...what
It's not a reversed manifold. This is the official reversed manifold thread haha.
M3GTR is offline   Reply With Quote
Old 04-04-2006, 12:46 PM   #149
dream
Member#: 37003
2015 WRX
Great thread, lots of awesome info!
dream is online now   Reply With Quote
Old 04-04-2006, 01:12 PM   #150
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
No a cable driven throttle body will not work with the LGT manifold. The throttle body mounts underneath the runners on one side.
-Matt
ShaggyGT is offline   Reply With Quote
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 02:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 06:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 03:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 09:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 11:58 AM
