Old 10-25-2011, 07:52 AM   #1551
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
same set-up... new car car
carl s. is offline   Reply With Quote
Old 10-25-2011, 09:13 AM   #1552
kmook
Member#: 146168
2015 Impreza
Originally Posted by scby rex View Post
Clearance with the alt is why Im pretty sure. full race makes a spacer plate so the tb fits sidways.
From the pictures i've seen in the thread it looks like most everyone with a DBW TB rotated it with the motor on top. Did anyone try it with it in the stock position... If so what were the issues encountered?
I have an 05' and from the previous post back in this thread it looks like the 04-05' have a TB that if rotated will not mate up correctly and have a leak. Does anyone know if just the TB can be changed to a newer one and rotated, or does both the intake and TB have to be a newer model for the TB to be rotated?
Thanks,
Ken
kmook is offline   Reply With Quote
Old 10-25-2011, 10:39 AM   #1553
AREA1320
Member#: 112508
Ken, if you run it the factory way the harness/plug hits the alt bracket
AREA1320 is offline   Reply With Quote
Old 10-25-2011, 10:45 AM   #1554
kmook
Member#: 146168
2015 Impreza
Thanks for the answer!
Old 10-25-2011, 11:05 AM   #1555
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
i prefer the motor on the left so the butterfly plate still opens top and bottom. something about the butterfly plate opening and favoring the drivers side doesnt sit well with me.
synolimit is offline   Reply With Quote
Old 10-25-2011, 11:24 AM   #1556
AREA1320
Member#: 112508
Old 10-25-2011, 12:50 PM   #1557
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Looks really nice Carl. Ken the plate fullrace makes fixes the leak and clearance problem.
scby rex is offline   Reply With Quote
Old 10-25-2011, 01:22 PM   #1558
kmook
Member#: 146168
2015 Impreza
Thanks I called them but the spacer is really expensive. I saw engineerx rotated his 180*, I wonder why people didnt do that and went with rotating it 90*?
Old 10-25-2011, 03:10 PM   #1559
scby rex
Member#: 104878
02 wrxbastardchild
He made his own spacer to do that I think.
Old 10-25-2011, 08:54 PM   #1560
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
I made my own spacer for my 04 throttle as well. rotated 90 degrees
Old 10-25-2011, 10:28 PM   #1561
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Not if you use tall enough manifold spacers.
Token-Negro is offline   Reply With Quote
Old 10-25-2011, 11:18 PM   #1562
scby rex
Member#: 104878
02 wrxbastardchild
why do you have one stock strut top and one pillow ball one?? In the middle of something?
Old 10-26-2011, 12:25 AM   #1563
synolimit
Member#: 225225
11 WRX
my contribution so far.
JDM long runner mani. i have GS 8mm spacers, 865mm belt and clocked the power to the alternator. so far i had to make an adaptor because the mani uses 12mm bolts and there spaced out different from the 10mm TB i have (08+ wrx). i used 6061 3/8 plate and hole sawed the big holes , cheap and easy. the 12mm are just holes while the 10mm are drilled and tapped. i also put an angle on the pipe so my TB wouldnt face the hood. i made and mocked everything to fit like the GS 3-port, 3.5 bar MAP, parallel fuel lines, and was able to use one OEM JDM rail and 1 USA rail. the USA rail needed an extention adaptor made also. the brake boost was blocked off and i drilled and tapped a new spot on the drivers side. should be ready to install soon as a get a limp map finished for the 20 items all going on the car at the same time.
Old 10-26-2011, 12:50 PM   #1564
scby rex
Member#: 104878
02 wrxbastardchild
So your flopping the alt to the ac spot then too. Pretty sure that tb adapter isnt going to clear over the alt.
Old 10-26-2011, 01:40 PM   #1565
synolimit
Member#: 225225
11 WRX
It has plenty of room. The spacers raise the mani and the alternator is lowered enough. In fact I'll have more room then just guys that use an adapter which kicked there TB out 1/2".
Old 10-26-2011, 02:28 PM   #1566
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
one of my 4 way RS&SPs (solid mount) was getting rebuilt so I had a 1 way RS&SP (group n mount) in so I could drive it around.
Old 10-26-2011, 03:12 PM   #1567
scby rex
Member#: 104878
02 wrxbastardchild
Will the hood close still?
Old 10-27-2011, 09:45 AM   #1568
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
bhhamblin is offline   Reply With Quote
Old 10-27-2011, 10:00 AM   #1569
02RexWI
Member#: 165141
^What car is that? Japan gets all the cool stuff.
02RexWI is offline   Reply With Quote
Old 10-27-2011, 10:42 AM   #1570
synolimit
Member#: 225225
11 WRX
why wouldnt it? no one else has a porblem. just because my TB is more forward it doesnt mean the height is higher. my TB hose will almost touch the alternator so it will be even lower than this.
Old 10-27-2011, 03:14 PM   #1571
scby rex
Member#: 104878
02 wrxbastardchild
Originally Posted by bhhamblin View Post
New impreza motor? Oil filter is on top like the 2012
Old 10-29-2011, 10:04 PM   #1572
06stidude89
Member#: 279181
2006 Impreza WRX STI
WR Blue
This mod is something I've been wanting to embark on for about 3 months now ever since I saw it for the first time. My question it this; Where do you run the pipe coming from the cold side or compressor side to the FMIC?
06stidude89 is offline   Reply With Quote
Old 10-29-2011, 10:09 PM   #1573
Mechie3
Member#: 120152
BRZ/FT86/FRS/Subiyota/Toyobaru
It was the car that raced recently at the Nurburgring.
Mechie3 is offline   Reply With Quote
Old 10-29-2011, 10:57 PM   #1574
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Not to be mean, however, if you have that question, you are not ready for this modification...
bue car is offline   Reply With Quote
Old 10-30-2011, 01:26 AM   #1575
06stidude89
Member#: 279181
WR Blue
Never said I was ready I said I wanted to embark on it. Now can someone actually answer the question. I haven't seen it say where the piping runs.
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
