Old 11-14-2011, 10:06 AM   #1601
02RexWI
Member#: 165141
Originally Posted by .Stichris. View Post
My MAff is blow thru and it's right behind the radi and my bov is in my pass finder And I used a push fan seance the stock fan didn't work with how I have the pipe ran and the fan I got has a 1300cfm and I wired it into a toggle switch so I can turn it off when I'm driving and turn it on at stop lights and stop and go traffic
U can kinda see my blow thru here and also u can see where I did my brake booster vacuum lol
Be careful on just having it on a toggle switch. I have seen at least 3 people I know personally forget to turn their fans on at some point and over heat their engines... One with a Supra forgot for so long that his radiator core expanded!
His engine was toast after that.
I'd suggest wiring it into the stock wiring so that the ECU can control it. Or at least put a thermostatic switch in the circuit and leave the switch on at most times!
I ran my piping through the front of the car, near the headlights. I don't have any pics on my photobucket, but I can explain to you how it was ran if you're curious.
02RexWI is offline   Reply With Quote
Old 11-14-2011, 12:05 PM   #1602
.Stichris.
Member#: 243141
2004 UNRIVALED BUILT
Hey man thanks do the heads I'm going to re wire it into the stock system ahha
.Stichris. is offline   Reply With Quote
Old 11-14-2011, 12:54 PM   #1603
thescooby05
Member#: 191563
2005 STI Protuned
This is what im planing on doing, back dooring the innercooler, i know how to get it past/by the headlights just dont know how i want the hot side piping to run also, where to put the PS reservoir and the BOV i was thinking on the IC its self, can you post some pics or send some in a PM if you want to not show the world.
thescooby05 is offline   Reply With Quote
Old 11-14-2011, 01:57 PM   #1604
02RexWI
Member#: 165141
There are pics of it in a different thread... I'm not concerned with people seeing it. I'll post some up later today if I get some time.
I re located the PS reservoir to where the stock BCS solenoid sits, and ran the pipes right next to the ABS module between it and the cylinder head.
Old 11-14-2011, 07:48 PM   #1605
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Originally Posted by synolimit View Post
cooper rtv on couplers and maf. That doesnt seam like it will last long or fix whatever problem your having there.
**** maf, SD all the way, no silly blow through or "big maf " bull****.
mine wont be looking like this anymore its in the middle of a upgrade, makeover.
To the guy asking about what to cut on the hood its all going to depend on what chassis you have, how your piping is ran and how big it is. trim and necessary.
scby rex is offline   Reply With Quote
Old 11-15-2011, 03:41 AM   #1606
thescooby05
Member#: 191563
2005 STI Protuned
right i totaly understand that just wanted to see so i could get an idea i guess, but ill just leave it in to the hands of my fabracator.
Old 11-15-2011, 03:49 AM   #1607
thescooby05
Member#: 191563
2005 STI Protuned
this is exactally what i was thinking of doing as well, thats crazy, would love to see some pics of it. so i can get i visual on how it will all come out. what PS reservoir did you use? i was thinking of a new year as thats where they are mounted and would make it look more OEM i guess you would say since the 05 sti one just doesnt look right to me when placed where the stock BCS is. also do you have any pics of where it goes behind the head lights as far as how much has to be trimmed , im running 2 1/2" pipes on both sides and it looks like its going to need some triming in these areas. i guess some good pics of everything would really help out!
Old 11-15-2011, 08:39 AM   #1608
02RexWI
Member#: 165141
I used a plasma cutter to make the holes. Same size piping- 2.5".
I used stainless charge pipes because I was worried about rubbing issues around the holes, but I put some thick silicone hose around the pipes where it goes through the metal to protect it just in case.
I used the stock reservoir can just cut a slot into the BCS bracket to hold it like stock. The cover still fits over it, so it looks fairly stock besides the long hose running from the reservoir to the pump.
I'll put some pics up in a second if I can find them...
Old 11-15-2011, 08:43 AM   #1609
02RexWI
Member#: 165141
No close up pics of the holes, but you get the idea. I was going to flip the IC core but I was rushed. If you're in WI you can swing by and see it.
Old 11-15-2011, 09:24 PM   #1610
scby rex
Member#: 104878
02 wrxbastardchild
yeah flipping the core would have helped, but also created a place for oil to pool.
Old 11-15-2011, 11:26 PM   #1611
02RexWI
Member#: 165141
If you're that worried about it just put a drain hole in the core.
Old 11-16-2011, 02:47 PM   #1612
.Stichris.
Member#: 243141
ahahha
Old 11-25-2011, 07:41 PM   #1613
25rsti
Member#: 166324
Old 11-26-2011, 09:44 AM   #1614
meat_WRX
Member#: 96919
2004 sti
black
cant wait to start mine.
meat_WRX is offline   Reply With Quote
Old 11-28-2011, 06:58 PM   #1615
OB2
Member#: 51500
1999 impreza rs-t
sylver
Originally Posted by 25rsti View Post
I am going to do the same setup than this with my 2.5i intake om my RSTI, do you have more pics and can you give me some int???
Thanks in advance!!!
OB2 is offline   Reply With Quote
Old 12-02-2011, 08:38 AM   #1616
vicious_fishes
Member#: 158864
2003 SOHC destroker
i know this has probably already been posted but whatever happened to the OP's pictures? do we have the same ones or equivalents?
vicious_fishes is offline   Reply With Quote
Old 12-02-2011, 06:20 PM   #1617
scby rex
Member#: 104878
02 wrxbastardchild
those are old as hell.
Old 12-02-2011, 09:08 PM   #1618
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Here's my ugly setup. Works good tho lol
Id recommend wrapping the intercooler pipe with thermal tape. All that heat comming of the radiator just defeats the purpose of the intercooler.
wrxsubiemod is offline   Reply With Quote
Old 12-03-2011, 01:16 AM   #1619
reid-o
Member#: 103631
2004 STI
Here's mine in progress
Just bought the full race spacer kit and made a new cold side. It looks like it'll all fit
reid-o is offline   Reply With Quote
Old 12-04-2011, 12:07 AM   #1620
vicious_fishes
Member#: 158864
2003 SOHC destroker
i also plan on doing this exact setup. was there anything that stopped the 2.5i manifold fitting a cable throttle other than the cable stays?
Old 12-05-2011, 12:20 AM   #1621
johnt2k7
Member#: 194151
2008 WRX 5 Door
RED
have to whore a couple photos from my build. its not done but hopefully will be up and running by friday. with a Holset HX35
sry for the phone quality pics
johnt2k7 is offline   Reply With Quote
Old 12-06-2011, 10:35 AM   #1622
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
^^^ looking good.
gotsugg is offline   Reply With Quote
Old 12-06-2011, 08:42 PM   #1623
scby rex
Member#: 104878
02 wrxbastardchild
probaly the only way a leggy/ plastic manifold would have any shorter piping.
Old 12-15-2011, 04:38 AM   #1624
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
subscribed
armyssoldierboy is offline   Reply With Quote
Old 12-16-2011, 08:46 AM   #1625
vicious_fishes
Member#: 158864
2003 SOHC destroker
plastic manifold might save a nice chunk of weight too, anyone got weights?
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
