Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 05-07-2012, 08:28 PM   #1701
arisking
Member#: 245282
04 JBP STi
All done!!!
arisking is offline   Reply With Quote
Old 05-07-2012, 09:26 PM   #1702
scby rex
Member#: 104878
02 wrxbastardchild
aw, 1,000,000 whp 2 aw tq
ebay i/c? Not where I would mount the bov, maybe on the i/c core so you have some more room.
scby rex is online now   Reply With Quote
Old 05-07-2012, 10:23 PM   #1703
arisking
Member#: 245282
04 JBP STi
Process West V-Mount. Nothing rubs...
I'd like to mount it on the core one day.
Does it matter what side of the core I have the BOV on? Because the driver's side is tight with the coolant overflow tank there...
Old 05-08-2012, 04:58 PM   #1704
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
onesicksoob is offline   Reply With Quote
Old 05-09-2012, 12:11 AM   #1705
johnt2k7
Member#: 194151
2008 WRX 5 Door
RED
^ had to thow the stash jar on the tool box for the pic lol
johnt2k7 is offline   Reply With Quote
Old 05-09-2012, 12:14 AM   #1706
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
fat sac lol
bue car is offline   Reply With Quote
Old 05-09-2012, 02:42 PM   #1707
wrxsubiemod
Member#: 165104
E85 bug-i sti swap
Phatron tuned
Does anyone know of a replacement throttle cable that's shorter for reverse manifolds. I found one awhile ago but lost the link
wrxsubiemod is offline   Reply With Quote
Old 05-09-2012, 05:52 PM   #1708
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
I didn't mean for that to make it in the picture.
I got the manifold mostly shaved last night, trimmed the alternator bracket, and made a usdm wrx throttle body fit on the v5/6 manifold. I still have a few more holes to weld shut and another spot or two on the manifold to shave.
Old 05-10-2012, 08:06 PM   #1709
monkiboy
Member#: 202958
2008 wrx
mostly done...
monkiboy is offline   Reply With Quote
Old 05-10-2012, 08:45 PM   #1710
wrxsubiemod
Member#: 165104
E85 bug-i sti swap
Phatron tuned
Damn marcos I love the build. The green looks way better than the polished manifold.
Old 05-10-2012, 08:48 PM   #1711
monkiboy
Member#: 202958
2008 wrx
thank you, sir!
and thanks to you the inside looks just as sweet as the outside
Old 05-10-2012, 09:51 PM   #1712
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
Originally Posted by arisking View Post
All done!!!
What did you use to mount the alternator?
buddsautoparts.com is offline   Reply With Quote
Old 05-10-2012, 11:26 PM   #1713
arisking
Member#: 245282
04 JBP STi
I used the old AC bracket:
Old 05-11-2012, 07:56 AM   #1714
25rsti
Member#: 166324
02 V8 Spec C 03
V9 Limited 2013 Legacy
That pulley is awfully close to the pipe. Are you worried it be rub once driving around?
Old 05-11-2012, 11:20 AM   #1715
arisking
Member#: 245282
04 JBP STi
Haha, it has more clearance now. That was before anything was welded or clamped in place.
Old 05-20-2012, 10:47 PM   #1716
clean 93
Member#: 181440
1993 wrx
Doing a hybrid build with reverse manifold. Here is my phase 1 with deleted iac passage.
clean 93 is offline   Reply With Quote
Old 05-21-2012, 01:19 PM   #1717
scby rex
Member#: 104878
02 wrxbastardchild
Looks real good. I'd love a phase one wrc manifold, just need someone to make me adapter spacers so i can have phase two heads.
Old 05-25-2012, 12:25 PM   #1718
wrxsubiemod
Member#: 165104
E85 bug-i sti swap
Phatron tuned
OK so my throttle cable finally broke. No luck sourcing a shorter replacement and subaru wants $55 for a new one. I came across a post the other day where someone modified their own and I came to the conclustion that if they could do it, so could I
and I will teach you!
the only part youll really need are some cable stops. I found these at O'reillys for 3 bucks. You can also find them at NAPA. I also got some heat shrink for the bling bling effect.
Remove the throttle cable from the car. I actually removed the pedal along with it. It was actually faster removing the 2 12mm bolts holding everything together inside the car. Inside the engine bay the cables held on the manifold with 2 12mm nuts. Loosen those and pull the assembly out.
Before doing any cable work, measure the end length of the cable. Pull the cable (throttle body end) until there is no more slack and measure the distance from barrel end to cables shielding. MY cable was broken but i was able to get a reading of 5 1/4IN. These cables are adjustable so even if your new cable length is off by a little you will be able to adjust it.
I then cut the barrel end of the cable and pulled it out of the shielding.
once you have the shielding in hand, the cable adjustment end will need to come off. This is easily done by pulling and twising the cable and the end until the coils start to come apart inside the crimped housing. here is a picture of what im talking about.
you will then need to measure how long you will need your new cable.
I measured from fire wall to the intake manifold cable mount and gave myself enough slack to route the cable how i liked. This was 20in
i measured from the shieldings firewall plug to the end of the cable, then cut. strip the plasting shielding to explose the metal coils. 1/2in would be enough. at this point you can put put the cable back inside the shielding, slip some heat shrink on the cable and crimp on your adjustment end.
Again, remove the slack from the cable and measure out the distance you will need for the barral end. I cut this cable at 5 1/4in and installed the cable stop using two set screws found at LOWES. Torque them down with loctite. Get them nice and tight. I didnt like the phillips screws this kit came with
reinstall everything and make sure to use the adjustment nuts on the cable to take the slack out. Test and enjoy your shorter cable.
all done. excuse the mess, im actually trying my best to clean the engine bay up.
Old 05-25-2012, 06:43 PM   #1719
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
Old 05-25-2012, 07:00 PM   #1720
scby rex
Member#: 104878
02 wrxbastardchild
Theres a how to vid on youtube and he does it to a eg33 motor.
Old 05-26-2012, 02:01 AM   #1721
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
NW2TONE is offline   Reply With Quote
Old 05-27-2012, 01:36 PM   #1722
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
i bet shes a dirty girl
Old 06-01-2012, 09:34 PM   #1723
reid-o
Member#: 103631
2004 STI
I've enabled my methanol injection on my setup and have started tuning. I think there's some merit clocking the throttle body 180 as everyone is suggesting, at least if you're doing wet spray. Perhaps this is less of an issue without some type of wet cooling going on. I show cylinder 1 as the noisiest right now (not on stock ecu), and I'm trying to figure out a way to pull more data. I guess I won't know for sure without individual o2 or 4 channel EGT, which I'm not going to spring for.
I'll fab a thicker throttle body spacer and mount the throttle body 180 and report back. I don't have much evidence other than raw knock from the 4 cylinders with the passenger side showing a bit more noise, which is normally the opposite.. This could also just be mismatched injectors too. But if I clock throttle body so it's vertical and it goes away, at least there can be a stronger correlation.
reid-o is offline   Reply With Quote
Old 06-01-2012, 11:38 PM   #1724
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
nvmd you are dbw
Old 06-01-2012, 11:38 PM   #1725
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
double ftw
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain 1 04-20-2003 10:58 AM
Message Board Statistics All times are GMT -4. The time now is 09:48 PM.
