Old 04-04-2006, 12:38 PM   #151
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
heres my work in progress
using an sti ver8 intake manifold, bolted up perfect. Switching the fuel lines was a little harder than a tgv manifold, becuase since its all 1 piece, i couldnt just lift up on the manifold, i had to bring the fuel lines out with the manifold (because theres metal between the manifold runners, its kinda trapped in the middle).
Had to undo the fuel lines from the side, then pull it out and reverse it back to the normal position and slide it back in from the side.
And since my sti engine came with no a/c, i had no a/c brackets to mount the alterantor in the new spot. Luckily i found someone parting out a wrx and got them.
ImprezaRSfan! is offline   Reply With Quote
Old 04-04-2006, 12:55 PM   #152
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Dave, you're gonna need to move that coolant reservoir, or the intake won't fit.
Capt Crunch is offline   Reply With Quote
Old 04-04-2006, 01:19 PM   #153
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
it should just barely fit, its the angle its in the pic.
if not, ill move it forward a couple inches
Old 04-10-2006, 09:38 PM   #154
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
so the bracket to the right of the alternator, is it only found on sti's and not wrx's ? Im having a very hard time tracking down that piece of sheet metal.
Old 04-10-2006, 10:49 PM   #155
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
No, it's the standard bracket that holds the AC compressor. But it's been cut up to turn the bracket into the belt tensioner. The yellow lines on the picture show you how I cut mine (kinda).
SloRice is offline   Reply With Quote
Old 04-11-2006, 12:38 AM   #156
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Does anyone have that bracket they can sell me, guys that ditched their ac compressor/ac setup?
Old 04-11-2006, 12:30 PM   #157
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
ya seriously, i need that black piece so bad. I got the one that mounts it on the left, but not the one on the right.
i think wrx's have a differnt mounting system than sti's, especially on the right side
Old 04-19-2006, 08:17 PM   #158
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Has anyone found a hookup for the pulley?
im about to buy a pulley off of mcmaster carr and find a nice bearing and bore/press it in
Old 04-20-2006, 12:36 AM   #159
SloRice
Member#: 44351
2004 Mitsubishi Evo
I said this in a PM to you, but I wanted to post it for public knowledge also.
I am using a timing belt idler pulley for my setup. Make sure to get the dual ball bearing one. So far, I have about 1000 miles on my setup and no problems yet.
Old 04-29-2006, 11:53 AM   #160
herewegoagain
Member#: 107778
2006 Legacy GT Sedan
Obsidian Black
I posted this on LegacyGT.com, but I wanted some opinions here too.
What if you aren't going to push more than 300-320whp, how about the Injen FMIC on a reversed LGT intake manifold? If you rotate the cold pipe coming up from the core, it looks as if it would flow right into the throttle body.
herewegoagain is offline   Reply With Quote
Old 04-29-2006, 12:11 PM   #161
herewegoagain
Member#: 107778
Obsidian Black
Of course, you'd still have to go rotated seeing as there is no room for the intake. And no rotated kit is meant for only 300-320whp, sooo.... Nothing to see here kids, move along.
Old 05-03-2006, 11:45 AM   #162
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
im pretty happy with my piping, its nice and short, and very affordable too. As i bought an ebay fmic core for 250, a bunch of pipes for 150, and all in all spent <= 800 bucks for it including labor.
i didnt wanan pay 65 bucks for that black bracket thats supposed to go on right side of alternator, so i made my own. And i guarentee its about 10x stronger too, i used really thick metal.
a progress pic:
semi-done:
i still need to find a better way to mount the coolant reservoir. I moved it forward some so i could fit a 4 inch inlet filter on the turbo(which has yet to come).
Old 05-03-2006, 11:55 AM   #163
M3GTR
Member#: 21965
V-mounted 40R...what
IMprezaRSfan, Thats how I have my pully set up, and it squeeks like all hell, kills my ears. I think it is because of a lack on contact on the crank so it slips when its cold, at throttle blips, and when making sharp slow turns. Let me know how it works out for you, but I can tell you its not working great for me. I don't have another solution right now however.
M3GTR is offline   Reply With Quote
Old 05-03-2006, 03:19 PM   #164
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
mine squeeked too, cuz it was too loose. When i would tighten it more, the old bracket i had would slip down some and i woudlnt raelly be tightening the belt.
So i made a new bracket and its super strong. The belt is TIGHT, its not going anywhere, have had 0 squeeks since then.
so now i dont have to mess with finding a pulley.
Old 06-07-2006, 06:23 PM   #165
HEKTIC
Member#: 116919
1989 Legacy RS
Heres a pretty sweet setup -
HEKTIC is offline   Reply With Quote
Old 06-07-2006, 07:50 PM   #166
jaywrx
Member#: 16254
'02 WRX WRB
'07 Tribeca OBP
Just thought I'd share a few pics of my reversed manifold setup. I did this about six months ago and am still working on this and that. I cut and re-welded a Greddy FMIC kit for the IC pipes. I'm using a Precision Turbo GT3255E turbo. It seems to be pretty good for the price. I'm using a 2.2T block with Wiseco pistons. I made all of the exhaust from scratch, up-pipe, down-pipe, everything. I still have work to do but I like what I've done so far.
jason
Don't you love this Subaru paint?! That bumper is clean and has already been repainted once.
jaywrx is offline   Reply With Quote
Old 06-07-2006, 07:56 PM   #167
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Remember, I have access to the pulley he used, if youre intersted PM me.
Alex
Old 06-07-2006, 07:57 PM   #168
traction issuez
Member#: 86559
2005 RS Wagon
the yellow one looks like the same setup as JUNs time attack WRX, maybe it's the same?
traction issuez is offline   Reply With Quote
Old 06-07-2006, 08:16 PM   #169
HEKTIC
Member#: 116919
1989 Legacy RS
Yea seems to be similar,here are some more pics,as you can see its still in the build,got a few other things hes got to do-
Old 06-07-2006, 08:25 PM   #170
traction issuez
Member#: 86559
2005 RS Wagon
too damn showy for my taste, but definately a really nice setup. i was looking into something like that before i bought my magnus version xx manifold.
Old 06-08-2006, 09:50 AM   #171
herewegoagain
Member#: 107778
Obsidian Black
I wish I could get those wheels for my LGT.
Old 06-08-2006, 09:53 AM   #172
herewegoagain
Member#: 107778
Obsidian Black
That car really needs some ITBs.
Old 06-20-2006, 05:38 PM   #173
HEKTIC
Member#: 116919
1989 Legacy RS
Heres a pic of my reverse setup,still havent finished yet.
Old 06-20-2006, 07:01 PM   #174
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
^^Same way I'm doing mine!
But I've got the WRX PS pump and custom resorvoir
Old 07-12-2006, 11:07 PM   #175
HEKTIC
Member#: 116919
1989 Legacy RS
yeah I was planing to get a custom resorvoir...but decided to leave it till later on once car is running
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
