Old 06-01-2012, 11:54 PM   #1726
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
No IAC on DBW cars
Old 06-02-2012, 03:22 PM   #1727
reid-o
Member#: 103631
2004 STI
Does anyone know if there are different types of phenolic and if there's a certain type I need to use.
reid-o is offline   Reply With Quote
Old 06-03-2012, 08:41 PM   #1728
samson05
Member#: 278836
2005 wrx,wrb
2005 forester xt,psm
Grimmspeed makes different sizes if thats what your asking.i believe they are 3mm & 8mm thickness.if you are gonna keep your ac I would use the 8mm.
samson05 is offline   Reply With Quote
Old 06-03-2012, 09:06 PM   #1729
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
kstech makes some too, bigger ones.
bue car is offline   Reply With Quote
Old 06-03-2012, 11:43 PM   #1730
stiser
Member#: 189774
2004 STI
Ya i got 16mm on mine. Ks techs
stiser is offline   Reply With Quote
Old 06-04-2012, 03:00 AM   #1731
reid-o
Member#: 103631
2004 STI
I was asking in reference to a throttle body spacer.
Old 06-04-2012, 09:26 AM   #1732
smitty5788
Member#: 267886
2011 STI
There are a bunch of different types of phenolic sheet. Idk what grimmspeed and ks tech uses but I would guess its a glass fabric version from looking at it. There is a bunch of stuff you can use.
smitty5788 is offline   Reply With Quote
Old 06-04-2012, 04:38 PM   #1733
reid-o
Member#: 103631
2004 STI
Thanks. I just ordered some on Ebay. I plan to have a friend cut out on a few on his router. I just want to rotate the throttle body back to 180 and collect data.
I've never used a standalone on a stock block before, so I've never really logged knock per cylinder (normally just culled knock raw). I don't know what to make of the data in terms of adjusting trims, as I've never given it much thought. But now that I can parse the data and I'm on a stock block, it's clear that cylinder 1 is louder right now than the rest. Also cylinder 1 is showing less voltage with the meth turned off, so I'm just assuming at this point it's a distribution issue.
Old 06-13-2012, 08:14 PM   #1734
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
Originally Posted by synolimit View Post
had to change the adaptor, it did hit the alternator. i cocked it up a bit and turned it slightly to the right to clear more. the right lower TB bolt now is about 1-2mm from hitting the alternator but everything clears and no grinding was needed !! also made my 3" hard inlet fit in OEM form
im selling all this FYI!! JDM spec-c long runner IM, GS 8mm spacers, TXS FMIC, 3" CAI and 3" hard inlet pipe, TXS BPV now running into the inlet pipe.
synolimit is offline   Reply With Quote
Old 06-14-2012, 02:04 PM   #1735
meat_WRX
Member#: 96919
2004 sti
black
Originally Posted by NW2TONE View Post
that forester is effin official.
meat_WRX is offline   Reply With Quote
Old 06-14-2012, 03:36 PM   #1736
Timmy2k5
Member#: 323209
Wow. Thats cool
Timmy2k5 is offline   Reply With Quote
Old 06-17-2012, 10:46 PM   #1737
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
scby rex is offline   Reply With Quote
Old 06-18-2012, 06:59 AM   #1738
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
For best effect, as somebody posted, you would have an extractor opening, like the WRC cars, for the high-mount FMIC in some of the reverse manifold setups and the V-mount ones.
Now, Prodrive had made a very small run of FMIC Sti in 2004-2005 and they did something with the hood scoop. They deleted it, but created something to replace it, and I think it was reversed to work as an extractor, a very clean solution.
That car was the Sti WR1. I never saw a clear picture of how that scoop thing they designed worked. If someone was to find or have one, would be nice to see it...
Old 07-01-2012, 09:52 PM   #1739
scby rex
Member#: 104878
02 wrxbastardchild
Couple updated pics from today. I shortened my throttle cable, I just need to go buy the end. Also still waiting on one coupler to arrive.
Old 07-02-2012, 11:44 PM   #1740
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Clean setup. Nice work.
06rexwagon is offline   Reply With Quote
Old 07-19-2012, 09:36 PM   #1741
scby rex
Member#: 104878
02 wrxbastardchild
Thanks^Couple updated, updated pics. I removed my ac as it didnt work anyways.
Old 07-22-2012, 09:37 PM   #1742
meat_WRX
Member#: 96919
2004 sti
black
bro your car is full of great mods. Thats a fantastic engine bay.
Old 08-02-2012, 01:59 AM   #1743
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
I can't exactly be like josh, but dammet im tryin!!!!!
em1bugeye is offline   Reply With Quote
Old 08-02-2012, 08:30 AM   #1744
02RexWI
Member#: 165141
Do you have problems tuning your MAF with it so close to the compressor of the turbo?
02RexWI is offline   Reply With Quote
Old 08-02-2012, 08:36 AM   #1745
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
+1^^^^^?
rexworx is offline   Reply With Quote
Old 08-03-2012, 01:48 AM   #1746
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
i have a built in air straightener within the intake i made. so its actually not too terrible. its a temp fix but the maf can scale a lot better than people give it credit for. i was able to run the car with no stalling on 280 cams. non avcs
Old 08-07-2012, 06:06 PM   #1747
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
Im getting there now I need to install it
...CHUCKLES... is offline   Reply With Quote
Old 08-07-2012, 06:08 PM   #1748
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
purdy
Old 08-07-2012, 06:19 PM   #1749
02RexWI
Member#: 165141
Nice! I'm loving the steel hardlines.
Old 08-07-2012, 07:05 PM   #1750
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Very nice
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
