Old 08-07-2012, 11:03 PM   #1751
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Originally Posted by ...CHUCKLES... View Post
Im getting there now I need to install it
MF'n tight.
Is that ss tubing or aluminum?
Old 08-07-2012, 11:15 PM   #1752
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
It is Stainless Steel, it has to be for me. I will be running E98 mixed with VP AutoImport.
...CHUCKLES... is offline   Reply With Quote
Old 08-12-2012, 02:19 PM   #1753
MrSlowbaru
Member#: 129231
2005 wrx
cgm
And I still have cruise control, and AC
MrSlowbaru is offline   Reply With Quote
Old 08-12-2012, 05:13 PM   #1754
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Sweet setup, looks sexy as hell.
Its pretty easy to keep cruise control with a dbw throttle though
SCRATCH THAT, I SEE YOUR CABLE THROTTLE.
did you get custom cables made?
Old 08-12-2012, 05:56 PM   #1755
cineris
Member#: 263329
2011 Impreza WRX
I really like that color manifold. You should make correlating pipes a matching color .
cineris is offline   Reply With Quote
Old 08-13-2012, 08:25 AM   #1756
MrSlowbaru
Member#: 129231
2005 wrx
cgm
Factory cables, my module for cruise is so close to hitting the turbo. Its hard to tell, but my pipes are painted Cgm to match the exterior of the car. I need to paint my strut tower brace red to match now.
Old 08-13-2012, 08:34 AM   #1757
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Is that Johan's old setup?
Zee Biker is offline   Reply With Quote
Old 08-18-2012, 08:34 AM   #1758
MrSlowbaru
Member#: 129231
2005 wrx
cgm
Nope, I made it all myself.
Old 08-18-2012, 01:22 PM   #1759
mywrxspeed
Member#: 154050
2004 wrx wagon
i know this was probably covered in here somehwere throughout the 70 something pages of posts, but has anyone run into a problem with only running one of the stock cooling fans? im looking at my setup and seeing that if i put the drivers fan back in im going to have to route the piping up and around rather than a direct shot from intercooler to tb. any advice will help. thanks
mywrxspeed is offline   Reply With Quote
Old 08-22-2012, 05:39 AM   #1760
tanxunhong
Member#: 329855
07 subaru sti
Default Small Setup for ideas
im new here. am from singapore.
Here is a photo of the setup done by my mechanic.
just to share some idea.
Give me some feedbacks.
tanxunhong is offline   Reply With Quote
Old 08-22-2012, 08:46 AM   #1761
02RexWI
Member#: 165141
Looks good! I like the brake master cylinder brace built into the strut tower brace.
02RexWI is offline   Reply With Quote
Old 08-22-2012, 10:21 PM   #1762
tanxunhong
Member#: 329855
07 subaru sti
thanks bro. this setup was in feb. got a new setup nothing much different.
but just new turbo, wastegate n extractor. unable to push out big powers from there but respond wise, nothing to complain.
Old 08-22-2012, 10:31 PM   #1763
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Im running 2.75 piping on the cold side with no problem running both fans, many people in here are running both fans also.
scby rex is offline   Reply With Quote
Old 08-24-2012, 07:57 PM   #1764
bmw325ix
Member#: 204652
My setup in the works, got to love short intercooler pipes
bmw325ix is offline   Reply With Quote
Old 08-25-2012, 05:44 AM   #1765
tanxunhong
Member#: 329855
07 subaru sti
omg. the intercooler is some cool ****. i wish i can do so.
so much restriction in sg. not even any exhaust manifold. power restricted.
Old 08-28-2012, 09:22 PM   #1766
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
REVERSED 2.5I intake manifold preview.
Kept AC
wrxsubiemod is offline   Reply With Quote
Old 08-29-2012, 12:39 PM   #1767
rextech255
Member#: 247116
2007 Impreza WRX STi
Kept AC
What are your plans for it?
rextech255 is offline   Reply With Quote
Old 08-29-2012, 12:47 PM   #1768
monkiboy
Member#: 202958
2008 wrx
Kept AC
not enough of these set up like you are doing - nice job, ruben!
oh and thanks for all the amazing porting and polishing work. you're prices were much better than grimmspeed. i got a turbo coming your way for your special touch.
looking forward to seeing that car when it's done. no hood clearance issues?
monkiboy is offline   Reply With Quote
Old 08-29-2012, 12:49 PM   #1769
rextech255
Member#: 247116
Dream I/C setup ^ looks great man.
Old 08-29-2012, 12:54 PM   #1770
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Plans for now are just trying to get this hood to close.
Its all bolted down and the hood closes without the throttle body but once I go to attached the TB the IAC hits.
Removed the IAC and everythings fits but I really dont like the idea of bypassing the IAC and just using the idle screw to keep the car on lol.
I assume DBW guys could just turn the TB and not have to deal with my issues.
I already cleared the AVCS and the rails fit so I'm half way home
Old 08-29-2012, 12:57 PM   #1771
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Thank you sir! I plan on being one of the first to reverse this thing, clearing AVCS and keeping my AC lol
Old 09-03-2012, 03:33 AM   #1772
Monkey king
Member#: 209401
2005 Sti
I'm considering doing the reverse intake since I have friend that can weld nicely and a Perrin FMIC but will most likely be keeping my stock turbo. I'm only considering doing the reverse intake because I will be going forged pistons maybe even rods since I now have low compression on cylinder 3 and will be going the blow thru MAF route since it makes more since to have the ecu reading the true temp and volume of air going in to the throttle body.
My main question is has any of you seen a stock location turbo with reverse mount intake and a blow thru MAF done? Also any direction to where I can find more info on this would be appreciated.
Monkey king is offline   Reply With Quote
Old 09-03-2012, 10:11 AM   #1773
scby rex
Member#: 104878
02 wrxbastardchild
Yeah, its been done. I recommend you ditch the maf and go speed density.
Old 09-03-2012, 12:07 PM   #1774
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Try again. Maf's DO NOT like to see boost. That's why they are before the turbo, yes it can be done but no one likes to tune them. Do some more reading and loose the maf as suggested.
bue car is offline   Reply With Quote
Old 09-03-2012, 04:03 PM   #1775
03sportwagon
Member#: 252943
2003 wrx sport wagon
I cant wait to go this mod. way to much turbo lag with a big perrin fmic.
03sportwagon is offline   Reply With Quote
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
