Old 01-22-2013, 08:48 PM   #1826
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Yep, just a cheap oem manifold. lol
bue car is offline   Reply With Quote
Old 01-22-2013, 10:27 PM   #1827
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Yeah, and theres no point what so ever to flipping the plastic manifold around. Its not easier to work on, the piping isnt any shorter and looks like poo imo. Theres plenty of GCs out there with reversed metal manifolds. If your going to do it..do it so it doesnt look like a giant pos plastic manifold is your engine.
CBrodie14..theres one of those manifolds on your 09 wrx!!
scby rex is offline   Reply With Quote
Old 01-22-2013, 11:12 PM   #1828
bludism
Member#: 344576
Do you have problems tuning your MAF with it so close to the compressor of the turbo?
bludism is offline   Reply With Quote
Old 01-22-2013, 11:49 PM   #1829
Impressed wagon
Member#: 64413
1995 Impreza Outblak
Flat Black full WRX swap
Not for sure on that, mine was just in for mocking up and now tuning for speed density.
Impressed wagon is offline   Reply With Quote
Old 01-28-2013, 11:37 AM   #1830
kidrage
Member#: 134880
2005 WRX
I have an 05 WRX. When I dropped the alternator to its lowest setting in an attempt to get the 34" belt on, the alternator housing was pushing down on the A/C belt.
Anyone else run into this issue and if so how did you fix it?
kidrage is offline   Reply With Quote
Old 01-28-2013, 11:51 AM   #1831
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Common issue. Just grind the alternator case to clear it.
06rexwagon is offline   Reply With Quote
Old 01-28-2013, 12:01 PM   #1832
kidrage
Member#: 134880
2005 WRX
Ok I guess I misunderstood it to grind the top of the alternator for the TB but its the bottom by the belt too that needs it. Got it, thanks.
Too many pages of reading made brain confused.
Old 01-28-2013, 12:09 PM   #1833
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I ground down the alternator case and a portion of the bracket it attaches to to get my alternator to go as low as possible. Get creative and remove material as necessary.
Old 02-04-2013, 02:10 PM   #1834
bmw325ix
Member#: 204652
bmw325ix is offline   Reply With Quote
Old 02-04-2013, 02:23 PM   #1835
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Impressive
Old 02-20-2013, 04:43 PM   #1836
onurba32
Member#: 203150
1996 gf8
red
[IMG] Uploaded with ImageShack.us[/IMG]
onurba32 is offline   Reply With Quote
Old 02-20-2013, 05:18 PM   #1837
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
i wanna do this sooner than later dammit. I am tired of down time with the car though.
Old 02-20-2013, 05:56 PM   #1838
kidrage
Member#: 134880
2005 WRX
Originally Posted by onurba32 View Post
[/url] Uploaded with ImageShack.us[/IMG]
I like that intake manifold. Did you take it apart and powdercoat the exterior of alternator or just spray it while it was all together?
Old 02-20-2013, 10:26 PM   #1839
scby rex
Member#: 104878
02 wrxbastardchild
onurba32, nice setup, Im using the same throttlebody but not on a wrc manifold.. Dont forget to put the check valve in the brake booster hose.
Old 02-21-2013, 05:01 PM   #1840
onurba32
Member#: 203150
1996 gf8
red
thanks for your help to find tps and good words
I put oem check valve into red house
how is your idle without idlecontrol valve?
thanks kidrage,I remove all the parts of alternator then cover was powdercoated, bolts nuts shims were yellow zinc coated I didnt use sprey because it has no resistent to physical damage
Old 02-21-2013, 08:02 PM   #1841
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
maxpowr is offline   Reply With Quote
Old 02-21-2013, 09:09 PM   #1842
scby rex
Member#: 104878
02 wrxbastardchild
I have the idle set at 1k.
Old 02-21-2013, 11:15 PM   #1843
Impressed wagon
Member#: 64413
updated with new bumber and v-mount finished fabricating
Old 03-13-2013, 11:14 AM   #1844
kidrage
Member#: 134880
2005 WRX
I cant get the throttle body to close. I have cables as far back as they can go. I am using a 1/2" spacer. Any suggestions?
Old 03-13-2013, 11:34 PM   #1845
scby rex
Member#: 104878
02 wrxbastardchild
If the spacer is on the tb then ditch the spacer. You should cut off those coolant pipes on the tb too, it will give you some more room.
Old 03-14-2013, 03:43 AM   #1846
Kermatt
Member#: 350148
Default EJ18 question
Hey guys, im new to the site, and sort of new to Subaru engines, but I'm a welder by trade and have a fair amount of general mechanical experience. Ive read thru as much of the 74 pages of this thread as i can stand...so i have a few questions
So...I'm building a vw bug rat rod with a freshly built n/a EJ18. I want to reverse the intake so it faces the rear of my car. So my question is a simple one, if I use a 8mm Phenolic spacer, do i still have to flip the ALT, or can I leave it centered? Also, im not using A/C, p/s, brake booster, ect...so I was hoping someone could give me a basic rundown of how the procedure should go, so I know I'm not missing something.
Ive changed the coolant manifold to face the opposite side of the motor, I was thinking of cutting back the hardlines to clear the coolant manifold bolts and re flaring them or eliminating them into high psi rubber. Advice?
Also, my buddy that built me the motor kinda got busy with work and left me with trying to figure out the details here, so if someone has a good diagram of the manifold lines that would be killer.
Im running a Halteck E6K ECU and would like some advice as to how to figure out my 'new' injector order, or the change rather. Any map settings tips would be great too.
Thanks in advance, its my first post!
Kermatt is offline   Reply With Quote
Old 03-14-2013, 03:45 AM   #1847
Kermatt
Member#: 350148
sorry, this post was an error
Old 03-14-2013, 11:36 AM   #1848
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Glad I could direct you here. Check out my photo bucket album for a ton of ej1.8 build pics, maybe you can find what you need for the lines in there.
http://s146.photobucket.com/albums/r.../95%20Impreza/
Old 03-14-2013, 03:08 PM   #1849
kidrage
Member#: 134880
2005 WRX
I would like to keep the spacer so I thought about taking the bracket that holds the cables to the manifold to a machine shop and having them extend it by 1/2". Any other suggestions out there I should think about?
I should cut them off but there not really in the way. Besides I may return to stock one day so one less part to replace.
Old 03-14-2013, 08:00 PM   #1850
scby rex
Member#: 104878
02 wrxbastardchild
remove the spacer. Its not doing you any good and is causing more problems. Why would you take a bracket to a machine shop?
If you return to stock, there still no need for coolant to pass through the tb.
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
