Old 03-31-2013, 01:23 PM   #1876
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
ams/fullrace kit with a custom intake?
scby rex is offline   Reply With Quote
Old 03-31-2013, 01:41 PM   #1877
funk32
Member#: 245787
2004 STi
kinda, AMS fmic with custom pipe from the manifold and that's a KStech intake
funk32 is offline   Reply With Quote
Old 03-31-2013, 11:24 PM   #1878
Swifty504
Member#: 342656
06 Subaru AW STI
F-R TS EFR 8374 IWG
Anybody try the full-race reverse intercooler kit with a cosworth intake manifold?
Swifty504 is offline   Reply With Quote
Old 03-31-2013, 11:26 PM   #1879
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Yea, any lotto winners here?
bue car is offline   Reply With Quote
Old 03-31-2013, 11:29 PM   #1880
funk32
Member#: 245787
2004 STi
no reason why it wouldn't work, I had my stock manifold on during the first test fit then I tried again when the cossy one came in and there was barley any difference, biggest difference came when I removed the 8mm spacers.
Old 03-31-2013, 11:46 PM   #1881
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I had the Full Race FMIC kit and can tell you it barely fits with the stock manifold flipped. If you look at my updated pics I ended up getting new hotside and coldside pipes fabbed up locally that fit 1000 times better for about the same price. I don't know of many others running their kit but if you have the manifold spacers, the TB spacer, a shorter ALT belt, and a slimline radiator fan, the piping part is pretty easy if you have a local fab shop.
Old 04-01-2013, 12:01 AM   #1882
Swifty504
Member#: 342656
06 Subaru AW STI
F-R TS EFR 8374 IWG
Just went and checked out your build. Your build is very nice man great job. So you pretty much wasted money on the full race kit in a way? I see it had fitment issues with the covers and as for local people around here it's pretty dead and they would charge an arm and a leg to do it.
Old 04-01-2013, 12:34 AM   #1883
kellygnsd
Member#: 32669
LINK G4 hybrid STi
They were cool about taking back the pipes. I kept the core and I have nothing but good things to say about the turbo kit they just need a little work on their FMIC kit production and instructions with all of their kits.
Old 04-02-2013, 10:45 AM   #1884
TickTack
Member#: 100353
I have a few more of these spacers left. Just picked up 10 this morning and will be shipping most of them today. Let me know if you want one. Not sure if I'll ever do another run after this.
TickTack is offline   Reply With Quote
Old 04-02-2013, 05:41 PM   #1885
Aphex28
Member#: 11506
2015 WRX
this thread is om nom!
Aphex28 is offline   Reply With Quote
Old 04-05-2013, 11:22 AM   #1886
sidewayz
Member#: 5810
2001 S366 2.5RS
My 2.5RS..
sidewayz is offline   Reply With Quote
Old 04-07-2013, 01:41 AM   #1887
808-wrx
Member#: 151703
2002 wrx 6speed son!
Are you guys running into clearance problems with the hood hitting the ic pipe?
808-wrx is offline   Reply With Quote
Old 04-07-2013, 02:01 AM   #1888
arisking
Member#: 245282
04 JBP STi
I've not run into any issues yet.
arisking is offline   Reply With Quote
Old 04-07-2013, 03:21 AM   #1889
reid-o
Member#: 103631
2004 STI
I can confirm that rotating the DBW only 90 degrees will cause issues when using heavy water/methanol and a fast spooling turbo. It wouldn't be a huge issue if I had an EBC and allow full boost only at 100% tps, but with an MBC I can hit full boost at part throttle, and cylinder 2 takes a beating at anything lower than 70% throttle. My gtx3071 hits 20 psi at part throttle if I hold it at 50% long enough.
I have per cylinder knock raw showing 2 spiking. With the throttle at 100, everything is a-okay. I know it's a duh, but I had to test it to confirm.
reid-o is offline   Reply With Quote
Old 04-07-2013, 09:37 PM   #1890
reid-o
Member#: 103631
2004 STI
I ended up grinding the manifold down instead of getting a thicker spacer and plugged the MAP sensor. Yes intercooler pipe was rubbing sigh...
Old 04-08-2013, 07:48 PM   #1891
kidrage
Member#: 134880
2005 WRX
Out with the old:
In with the new:
Few things to clean up including a weld where the coupler is now after the TB but this is what I have so far. Any suggestions?
kidrage is offline   Reply With Quote
Old 04-08-2013, 08:20 PM   #1892
scby rex
Member#: 104878
02 wrxbastardchild
Shave the manifold and retape the brake booster on the driver side, fill hole..repolish. Looks good. If it were mine Id weld a 90 to the compressor so I could use a straight, less chance to blow off.
Old 04-08-2013, 10:51 PM   #1893
kidrage
Member#: 134880
2005 WRX
What is the wire attached to the piping right after the tb?
Old 04-08-2013, 11:06 PM   #1894
reid-o
Member#: 103631
2004 STI
On to do list for me too.
Old 04-08-2013, 11:09 PM   #1895
reid-o
Member#: 103631
2004 STI
If you're talking about the white line it's the water injection line preturbo jet.
Old 04-09-2013, 12:28 AM   #1896
kidrage
Member#: 134880
2005 WRX
Yes that was it. So if i was to get a meth kit that would be the prefered placement for the jet?
Old 04-19-2013, 12:07 AM   #1897
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
bump. lets see those reverse intake mani setups!!
Excision is offline   Reply With Quote
Old 04-23-2013, 02:52 AM   #1898
Kermatt
Member#: 350148
Question
FYI, this doesnt work on EJ18 motor/manifold. I tried today with using an 8mm phenolic spacer and it does NOT clear the TB. Not even close. Any suggestions? I'm not positive, but I dont think the 2.2 manifold is the same at the base where it meets the head?
Kermatt is offline   Reply With Quote
Old 04-23-2013, 07:52 AM   #1899
25rsti
Member#: 166324
I've posted mine a few years ago and it's old but here ya go
Old 04-23-2013, 06:45 PM   #1900
chris keefe
Member#: 270312
2005 WRX STI
CGM
Subscribed.. working on mine now.
chris keefe is offline   Reply With Quote
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
