Welcome to the North American Subaru Impreza Owners Club Monday April 20, 2015
Old 07-16-2005, 09:56 AM   #1
bender
Member#: 1839
Question #2 cyl misfire
on a 2000 2.5 RS
got a CEL with a #2cyl misfire code
found that the valve cover was leaking oil into that cyl
replace valve cover gasket, wire set and plugs (NGK plats)
month later same CEL, no more oil leak, plug still look ok
replace #2 plug wire (had one sitting around) misfire gone
been 3 weeks and now it's back
could it be the coil pack?
is there anything else I should be checking?
please help
bender is offline   Reply With Quote
Multipull cyl misfiring problem... I've tested everything please help mxz155 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-15-2010 08:17 PM
cyl misfire on # 1 2 and 3 x04stix Newbies & FAQs 6 11-28-2009 11:14 PM
All 4 cyl misfire, oil on all plugs InfamousDX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-09-2005 01:12 PM
New engine, cyl misfires, and Knock! tmarcel Engine Management & Tuning 34 07-29-2005 10:00 PM
Can a bad cat cause cyl misfire? Prylex3 Normally Aspirated Powertrain 4 11-23-2004 05:48 PM
