Old 07-16-2005, 04:56 PM   #1
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
Default 3rd gen Legacy/baja radio bezel HELP!
OK Im at work(ford stealership) and we got a baja at an auction(sweet!) I need to get the nicew cd player out and the stock one in. I don't see how to get it apart(the trims around the radio). Can somebody give me pointers?
biggreen96 is offline   Reply With Quote
Old 07-16-2005, 05:35 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
there are 2 screws at the bottom of the din pockets, in plain view, then you have to remove the ash tray(push down tab and pull out) then there are two screw holding that to the frame also but you cant see them, you have to get down with you head on the seat and look up or feel for them. there are like 6 screws around the outside, 2 on the left side and i think 4 on the right including the ones holding the security module. then the last tricky one is the one WAY in the back against i think the firewall or some frame. you will also be able to see it if you put your head on the seat and look back you will need a long phillips.
hope that helps.
Ben
Old 07-16-2005, 05:59 PM   #3
biggreen96
Member#: 12535
vf39 06 5MT XT
ok thanks ben I got it. that was easy. I'm feeling retarded right about now. I didn't see those 2 screws under the ashtray, thats what was hanging me up.
Help on buying a used Legacy Outback. Head Gasket Help. Tirpitz56 Normally Aspirated Powertrain 3 06-03-2010 12:01 AM
Vendors! GB for 2nd/3rd gen Legacy rainguards kmin Private 'Wanted' Classifieds 1 01-10-2006 12:37 AM
BAJA RADIO REMOVAL help Baja Dan Baja Forum 3 08-09-2005 09:15 AM
1st Gen EJ20 into 2nd/3rd Gen Legacy? Bagheera85 Legacy Forum 1 06-04-2002 10:58 AM
2nd or 3rd gen Legacy with Impreza turbo motor? KooshDogg General Forum Archive 4 08-17-2000 06:10 PM
