Old 07-16-2005, 09:17 PM   #1
the2rz
Member#: 46033
2008 BMW 335i
Silver/Black
Default 17x7 wheel....225/45/17 okay?
Yes?
No?
For a sedan lowered 1 inch.
Thanks!
Manny
the2rz is offline   Reply With Quote
Old 07-16-2005, 09:55 PM   #2
blokespeed
Member#: 89228
02 WRX
blinding white
I had that size with eibach lowering springs, but when you had full steering lock going slow the front end of the car would bind up and felt draggy, this was on a 7" wide wheel, so I went to 215/45/17 as subaru recommend as an option size for the WRX.I think the 215 width feels better, but thats me.
blokespeed is offline   Reply With Quote
Old 07-16-2005, 10:53 PM   #3
WRX450
Member#: 20867
Default yep
I run 225 45 17s on my WRX sedan. They'll be fine. Besides, there are tons of choices for tires then...
WRX450 is offline   Reply With Quote
Old 07-16-2005, 11:20 PM   #4
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
What is the offset of the wheel you are running?
-Jason
jay25RS is offline   Reply With Quote
Old 07-16-2005, 11:51 PM   #5
deegan42
Member#: 69312
2002 WRX Sport Wagon
Blue Pearl
I am running ASA JS1 17 by 7 wheels on my 02 wagon. The tires i have are 225/45/17 potenza RE750s. They work great. I think that the offset is 50. The tires work great on the wheels. Never had a problem.
Ryan
deegan42 is offline   Reply With Quote
Old 07-17-2005, 05:28 AM   #6
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
As implied, offset is critical. The actual brand/model of tire can be just as critical: not all 225x45 tires are actually the same width (can vary nearly an inch iirc).
Combine a marginal offset, say below 48mm, with a really wide 225x45 and you could have a problem you wouldn't have with less extreme tire in the same size...though an offset of 52mm+ might allow you to use that wide tire.
My wagon example: Prodrive P1, 17x7, 52 offset, Michelin Pilot Sport 225x45/17. I have found some slight traces of light rubbing in the front, with no sound and no effect...but then the suspension has been "excercised" extensively on occasion and this is a wagon, not sedan.
Iirc there are lots of reports in this forum of people using a 225x45/17 with a 48 offset w/o problem...but then again "it all depends" when it comes to offset / tire combinations.
GravelRash is offline   Reply With Quote
Old 07-18-2005, 12:34 AM   #7
CGM_WRX
Member#: 66280
2005 WRX Sedan
Crystal Gray Metalic
I am running this set up with no problems but my wheels are OEM so offset is pretty much perfect.
CGM_WRX is offline   Reply With Quote
Old 07-18-2005, 02:16 AM   #8
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Should be no probs. A little more protection when parallel parking too.
ss
subysouth is offline   Reply With Quote
17x7.5, 5x114.3 ASA Wheels 225/45/17 Blizzak REVO1s AlBlueCar Wheels/Tires 15 01-13-2009 10:10 AM
FS: Rota Grid Royal Bronze 17x7.5 225/45/17 Kuhmo MX teamxmehow NESIC Private Classifieds 24 02-01-2008 10:30 PM
4 KOSEI K1 TS 17X7 WITH 225/45 17 BFG G-force T/A KDW 2's JZCWRXGT Wheels/Tires 1 05-25-2007 04:41 PM
18x8 225/40/18 regular setup with a 17x7.5 225/45/17 spare? pleue Tire & Wheel 5 03-03-2006 06:32 AM
GI:FS-Anthracite Superleggera's 17X7 W/225/45-17 P-Zero Nero M&S 1wrxsw New England Impreza Club Forum -- NESIC 13 08-18-2005 06:32 PM
