#1 |
Member#: 63546
Vehicle:1995 Legacy LSi white |
Hey guys one day i noticed my car was leaking coolant i found it to be out of the lower radiator hose on the right side which goes into the water pump. So i toook it of and reattached it that fixed the problem for a while but now it started doing it again when i was at subaru not to long ago i was told it was leaking and going bad. If its totally bad would it leak like real bad like pour out or is that jus the hose lose again.
#2 |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed |
It likely gets progressively worse as its failing. But you say it stopped recently when you replaced a hose?
ss |
#3 |
Member#: 11216
Vehicle:1991 SS 1998 BG 1996 BD |
If it's not coming from the hose....it's definitely the water pump. Look at it closely and see if it's leaking above the hose.
#4 |
Member#: 30727
South East
Vehicle:2000 Legacy B4 RSK *Formerly subyluvr2212* |
I had to replace a water pump on a 92 Legacy when the gasket started leaking. It would only leak occasionally though.
#5 |
Member#: 90610
Vehicle:1996 Legacy L 5MT Brown |
I believe the water pump has a little "weep hole" which will start to leak coolant as the water pump is failing. If there is coolant coming out, it is time to change the pump...
P.S. If the pump seizes up it can damage the timing belt, and cause a much bigger headache, so don't put it off too long. Matt |
#6 |
Member#: 30756
Vehicle:2006 Legacy GT SpecB Artic Silver |
BigMattyD is on point here. Depending on milage, you may just want to bite the bullet and do your water pump and your timing belt.
Cheers, Ryan |
#7 | |
Member#: 5039
South East
ss |
| Thread Tools | |
| Display Modes | |
| has anyone gone to a electric waterpump on their impreza? | cvcsmkr | Normally Aspirated Powertrain | 27 | 05-01-2006 05:20 PM |
| 98 Subaru Impreza 2.5RS OEM Clutch, waterpump... | FatCatTurbo | Private 'For Sale' Classifieds | 1 | 10-08-2003 12:32 PM |
| Waterpumps | scoobyimprza | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 05-14-2003 01:47 AM |
| WRX Waterpump Bypass Pipe questions... | latinskllz | Factory 2.0L Turbo Powertrain | 1 | 04-14-2003 11:32 AM |
| Help! dead waterpump on the road | minix42@ | Normally Aspirated Powertrain | 21 | 06-22-2001 02:40 PM |
