Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-17-2005, 01:44 AM   #1
Joey_WRX
Member#: 61371
2002 BMW 330ci
Alpine White
Default Hydra not getting power?
any reasons for this?...fuel pump not priming, and Hydra not interfacing with PC.......
Joey_WRX is offline   Reply With Quote
Old 07-17-2005, 11:22 AM   #2
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
It SHOULD just work... make sure everything is plugged all the way in, and if it is call Phil... leave him a message on his machine, sometimes he checks them during the weekend. Definitely send him an email as well....
DarthChicken is offline   Reply With Quote
Old 07-18-2005, 09:12 AM   #3
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Any other info? Like is this a brand new install or did it just seemingly die on you? Did you doublecheck all of your connections including the vacuum hose?
offset
offset is offline   Reply With Quote
Old 07-18-2005, 11:43 AM   #4
nester
Member#: 49839
2002 WRX Wagon
It's a brand new install.
We've checked all the wiring, all the fuses, all the relays, and yes, the vacuum line is hooked up.. Although I wouldn't know why that would affect the Hydra coming on.
Known good serial port on the laptop, no palm software or anything like that locking the port.
We haven't actually checked for power in from the harness plug, but we know the ignition line from the fuse box is live.. We've also checked our ground connections and found nothing missing.. Unless the Hydra is DOA, I'm fairly stumped.
nester is offline   Reply With Quote
Old 07-18-2005, 01:44 PM   #5
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Joey,
It sounds like you could have the wrong or a bad Hydra harness. I'll have Andrew at Hydra EMS contact you to verify the main power wire and take if from there.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 07-18-2005, 03:33 PM   #6
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Sounds like Phil is trying to get you squared away, but please post back here and let us know what the resolution turns out to be.
offset
Old 07-18-2005, 09:01 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Problem solved. It turns out one of the ecu pins in the OEM portion of the harness was bent so it wasn't making contact.
Thanks,
Phil
Old 07-19-2005, 12:28 AM   #8
nester
Member#: 49839
2002 WRX Wagon
Sweet.
Old 07-19-2005, 09:44 AM   #9
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Cool, thanks for that update. Now of course I am waiting on his impressions of the Hydra.
offset
tgv question...not getting power??? 5ub13 Built Motor Discussion 5 07-21-2009 12:54 PM
more ej20g swap problems, not getting power slowscoob Pre-2002 Factory Turbo Powertrain 1 09-25-2007 12:07 AM
not getting power to my head unit stormsubaru Car Audio, Video & Security 20 03-06-2007 05:09 PM
Help! SMJ not getting power supermoose Subaru Conversions 2 08-01-2005 03:56 AM
Amp not getting power? elemental Car Audio, Video & Security 4 09-09-2001 07:14 PM
