Old 07-17-2005, 02:38 PM   #1
Jamestiggs
Member#: 83418
Default New Exhaust System Please help!!
Hey all i am new i dont post alot. I just bought borla headers, high flow cat, stromung mid pipe and exhaust. Sounds great i had a professional mechanic install it. The thing backfires like crazy. sometimes on the shift mostly when i let off the gas and get back on it lighlty. only in the 1200 to 3000 rpm range. I called boxer 4 racing where i bought it and they said that it will do that. I was wondering if anyone else had this problem. What do u guys think i should do about this. Ohh yeah before i forget. This is for a 2002 2.5rs. Thanks guy
Jamestiggs is offline   Reply With Quote
Old 07-17-2005, 04:17 PM   #2
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
put a resonator in the midpipe. its going to quiet down your exhaust and make it less likely to backfire. can be done at a local muffler shop for very cheap
svek is offline   Reply With Quote
Old 07-17-2005, 04:29 PM   #3
Handsdown
Member#: 29355
yeah the 2.5rs likes it's fuel and always runs a little rich.
we here in the subaru community like to call them "rally burps"
it's going to do that, you can either put a resonator in the midpipe like svek said or you can put the stock catalytic converter back into the piping and that will quiet it down a lot.
i'll trade you exhaust systems if you can't take the rally burps
Handsdown is offline   Reply With Quote
Old 07-17-2005, 05:01 PM   #4
quest
Member#: 42402
- Finder of Porn
-Bringer of tears...
yup, i just got a headerback (brullen EL headers, hi-flow cat, custom midpipe, magnaflo moofler) installed and my car (2002 rs as well) pops and backfires occasionally when i let off the gas too.
it never does it on the shift though...at least, not that i've heard.
quest is offline   Reply With Quote
Old 07-17-2005, 06:36 PM   #5
anonymous_wolf
Member#: 57780
2000 RS sedan, GC6
Blue Ridge Pearl
i just got headerback system (brullen and N1) and it pops like crazy, sometimes so loud it's like somebody's firing a gun...lol
my friend who has a full brullen headerback (which has 2 resonators) said he could make it back fire everything he shifts!
anonymous_wolf is offline   Reply With Quote
Old 07-17-2005, 08:46 PM   #6
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
May I ask how long you've had this exhaust setup? If you haven't had it for more than a coupla weeks u might wanna give the ECU reset a try so it can learn the mods a little bit quicker. Take the neg battery cable off and pump the breaks a few times then reconnect let the car sit for a few minutes and let it idle for 10-15 minutes then take it out and cover the entire RPM range. It seemed to help me out alot i rarely get pops now. Spark plugs make a difference.
I think stock plugs dont ignite all the fuel in the cylinder and a little tiny amount might be goin into the exhaust and igniting there... this is one theory i've heard that makes sense to me so i just went and purchased spark plugs installed and it reduced my backfire quite a bit. Oh yea and resonators do help but im not a fan of quiet.
Caplin 2.5 is offline   Reply With Quote
Old 07-17-2005, 09:25 PM   #7
piker28
Member#: 22664
i dont know where you guys get these things unless i just cant here em,
i hear there was a recall for the old ecus that they were to sensitive to A/F ratio changes so thats why they backfired so much
piker28 is offline   Reply With Quote
Old 07-18-2005, 01:15 AM   #8
Handsdown
Member#: 29355
umm... think about it... a spark is a spark... it's going to be the a/f ratio and the electronic fuel injection that decides how much of it gets burnt. not the spark plug...
if your old spark plugs were corroded or inefficient that could have been a cause but let me tell you from my own experience, if you don't get OEM or OEM REPLACEMENT plugs you WILL end up regretting it.
Old 07-18-2005, 03:52 PM   #9
Jamestiggs
Member#: 83418
Hey guys thanks for the info. Yeah i called that place again they said there could be a small exhaust leak so i will put it up on a lift and check. Also how do you reset the ECU. Maybe that will help it cuz i have only had this done for like 2 weeks now. Thanks alot guys.
James
Old 07-18-2005, 04:03 PM   #10
kaisersouse
Member#: 85900
2001 Forester S
James
As posted above:
kaisersouse is offline   Reply With Quote
Old 07-18-2005, 09:29 PM   #11
piker28
Member#: 22664
this is how i reset it cause im picky..
disconnect negative terminal on battery for like 30 mins(usually just do it and go watch a movie) come back and reconnect it then let it sit and idle for like 15mins or something i dunno till it warms up i say...
then go out and beat the living wee wee out of it haha
Old 07-18-2005, 10:13 PM   #12
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I do that, then turn off before touching gas at all, then restart and procede with the beating...
I look forward to the Pop between shifts
moogoob is offline   Reply With Quote
Old 07-19-2005, 01:25 AM   #13
Kyle 2.5RS
Member#: 79769
1999 Impreza 2.5RS
Rally Blue Pearl
i have the brullen EL headers and brullen catback... pops like a mofo! I love it mosly while decelerating... especially at high RPM's.
Kyle 2.5RS is offline   Reply With Quote
Old 07-19-2005, 08:54 AM   #14
zechsiw
Member#: 41791
2007 mkV GTI
ya...once you release the gas for few sceond and step on gas again, you will get a pop.
I'm practicing to make the pop sound.
zechsiw is offline   Reply With Quote
Data collection on WMI systems - please help aquamist... Aquamist Water/Methanol Injection, Nitrous & Intercooler Cooling 0 04-01-2010 05:54 AM
Invidia or APS exhaust system? Please help T3/T4 WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-21-2007 08:00 PM
what happened to my system?? ...please help ants wrx Car Audio, Video & Security 15 10-17-2003 07:00 PM
Looking for data on the WRX turbo system - Please Help MonkeyAB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-17-2003 09:44 PM
new system???????please help ATA Car Audio, Video & Security 7 10-26-2001 01:55 PM
