Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 07-18-2005, 07:33 AM   #1
boobiewoo!
Member#: 91132
1998 impreza RS....T
brittish racing green
Default Need Help With 98 Impreza
WELL, SATURDAY I WENT AHEAD AND CHANGED MY SYSTEM BACK FROM A PARALLEL FUEL RAIL TO A SERIES FUEL RAIL, AND WENT AHEAD AND TOOK OUT MY 550CC INJECTORS, AND PUT THE STOCK ONES BACK IN W/ AN FMU.
I DID THIS BECAUSE I KNEW MY INJECTORS WERE LEAKING, BECAUSE I HAD TO J-B WELD THEM INTO THE RAIL....YEA, YOU HEARD RIGHT! THEY WERE ORIGINALLY FROM AN SR20 MOTOR....AND I THOUGHT THAT THEY FIT BECAUSE THATS WHAT EVERYONE ELSE DOES , I HEAR....BUT IT DIDNT WORK FOR ME....SO I MADE IT WORK! WELL ANYWAYS, THAT LASTED A YEAR....AND WITH THE PRICES OF GAS IT WAS JUST KILLING ME. SO, I CHANGED THEM OUT AND PUT THE STOCK IN, ALONG WITH PUTTING IN THE FMU. WELL, I GOT IT TO RUN.....AFTER A COUPLE MINUTES OF TURNING AND SOME THUNKING AND ROUGH NOISES....BUT ANYWAYS, NOW I GOT WHITE SMOKE PUFFING OUT MY EXHAUST, AND SPLASHES OF GAS. THIS IS GOING TO KILL MY TURBO ...ISNT IT? ANYWAYS, IM SURE ITS GAS.. IT CAUGHT ON FIRE WHEN I HELD MY CIGARETTE BACK THERE. NO CHECK ENGINE LIGHT OR ANYTHING. SO, THEN I THINK ONE OF MY INJECTORS ARE BAD...THEYVE BEEN SITTING IN THE TOOL BOX A YEAR...SO I HAD AN EXTRA, AND I CHANGED OUT EACH ONE, AND TRIED TO START AFTERWARD....STILL SAME RESULT. I DID NOTICE THAT IT GOT HARDER AND HARDER TO START. I TURNED ALL MY S-AFC SETTINGS BACK TO ZERO EARLIER. IM THINKING MAYBE IT JUMPED TIME ON THE TIMMING BELT OR SOMETHING....I GUESS THATS THE ONLY WAY IT COULD THROUGH GAS OUT THE EXHAUST, OR IF THERE A VALVE BROKEN OR SOMETHING. WELL, I GUESS I SHOULD HAVE JUST SUFFERED WITH THE PRICE OF GAS , HUH!? I ORIGINALLY GOT THIS HAIR IN MY ASS TO DO THIS BECAUSE I GOT MY EGT GAUGE FINALLY INSTALLED, ON #4 , AND I CHANGED BACK TO SERIES FUEL RAIL SO I KNEW IT WOULD BE THE LEANIEST CYLINDER, AND THE INJECTORS WERE LEAKING, (I DISCOVERED THAT WHEN I PULLED THE INTAKE MANIFOLD). BUT NOW, IT WONT START AT ALL. IT GETS SPARK, BUT WHEN I PRESS THE SCHRADER VALVE I INSTALLED ON THE RAIL FOR A FUEL PRESSURE GAUGE, THERES NOTHING. TODAY IM GOING TO GO AND LOOK AT ALL THE INJECTOR O-RINGS, AND PULL OFF THE PLASTIC TIMING BELT COVER, AND CHECK IT ALL OUT AT THE TIMING MARKS. IF ANYONE HAS SOME SUGGESTIONS OR ANYTHING, ITS APPRECIATED VERY MUCH.
boobiewoo! is offline   Reply With Quote
Old 07-18-2005, 12:40 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
whoa caps and hit the enter key once in a while
the best way to use the sr injectors in a subaru is to get a 1.8 fuel rail they drop in (as do usdm STI injectors) and the 1.8 rail will bolt to most manafolds
Old 07-20-2005, 12:26 PM   #3
boobiewoo!
Member#: 91132
no ****? ive never heard of that! well, i finally got everything straightened out. i re-jb welded them ****ers, and put them back in. my guess is the the stock injectors went bad sitting in a toolbox; undisturbed ; for a year.
anyways, thanks, and my apologies for all the smoke out there on I-95!
Old 07-20-2005, 06:11 PM   #4
VTsuby
Member#: 81369
2007 STI
I would just hate to think that an injector got stuck open flooded the engine and washed the bores so bad causing oil to slip past explaining the white smoke
VTsuby is offline   Reply With Quote
need help with my impreza psilo22b Newbies & FAQs 0 04-03-2007 05:35 PM
NEED HELP with stock Impreza strut problem!!!! subby00 Brakes, Steering & Suspension 7 10-22-2006 02:30 AM
Need help with my impreza (western mass) veowsaku New England Impreza Club Forum -- NESIC 3 02-05-2005 02:15 PM
('93-'01) Need help with 95 Impreza L SubaruImpreza_power Impreza Forum 8 08-17-2004 12:37 PM
I need help with my Impreza Mun General Community 4 09-21-2002 08:35 PM
