Old 07-18-2005, 02:11 PM   #1
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default Harden-your-own bushings
I'm [hopefully] in the final stages of getting my 2.5RS-T project back on the road. Instead of ordering STi hardened bushings, has anyone tried pouring their own?
A friend of mine has a Celica GT4 and did just that. The design of the subaru's engine and transmission bushings are a bit different than his, but I was thinking I could just make a mold out of clay and then pour in the 80A urethane.
What do you guys think?
-Simon
Really_Soaked is offline   Reply With Quote
Old 07-18-2005, 02:24 PM   #2
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
fill them with 3M Window Weld (do a search). I did my engine, tranny and rear diff mount like this. I feel more connected to the car now.
djerickd is offline   Reply With Quote
Old 07-18-2005, 02:59 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
hope i dont sound like some richbitch but hardened mounts are only like 175 for group-n stuff
wouldnt u rather have something thats proven for under 200 than attempting to make your own?
Old 07-18-2005, 03:07 PM   #4
ripvw
Member#: 27790
Originally Posted by djerickd
(do a search)...
http://scoobymods.com/forums/showthr...6203#post16203
http://www.honda-tech.com/zerothread?id=672359
http://importnut.net/motormount.htm
http://www.superhonda.org/forum/showthread.php?t=204274
the superhonda thread is the most interesting one - and worth reading in my opinion before trying it.
thanks for the suggestion - I had no idea people were doing this...
ripvw is offline   Reply With Quote
Old 07-18-2005, 03:18 PM   #5
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
wow, I should have got a slap in the face and a "RTFM!"
Ignorant me after being on the board for a long time had just never seen a thread pass. I'm going to follow the scooby mods procedure for the transmission mount and I think I'll give it a shot with making the clay molds.
Thanks guys.
Old 07-18-2005, 04:17 PM   #6
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
My Window Weld urethane was $13...
Old 07-18-2005, 04:18 PM   #7
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
^^ Exactly my thinking.
Old 07-18-2005, 04:18 PM   #8
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
oh one thing, you have to let it dry for about a week, so try to get someone's stock mounts then mod them, then swap them out after week of drying time, then give your OEM mounts back.
Old 07-18-2005, 04:19 PM   #9
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Plus you get the satification of doing it yourself!
Old 07-18-2005, 04:20 PM   #10
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Old 07-25-2005, 11:47 AM   #11
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
So I didn't follow any procedure directly, but here's what I came up with:
First I cut all of the rubber out of the mounts and then cleaned thuroughly:
Then I took 1" strips of modelling clay and formed around the edges.
MAKE SURE IT'S WATER TIGHT - Actually pour water in. And then let dry.
When you sit them down, have the bottom resting on the bottom of a container. You can see in this photo the one in the nail bucket is suspended. Eventually it sprung a little bit of a leak from the weight of the urethane.
Looks pretty good to me.
Old 07-25-2005, 01:07 PM   #12
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Looks really messy, did they harden up yet?
Old 07-25-2005, 01:11 PM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I think that I am wondering if they are going to seperate from the plates easily or not.
Old 07-25-2005, 07:53 PM   #14
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I welded steel plates onto the sides of my tranny mount. I can hear everything even startup!
FuJi K is offline   Reply With Quote
Old 07-25-2005, 08:23 PM   #15
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
I did a test with two pieces of roughed up steel. 1X1 inch with loops on the ends. I "glued" them together with a 1/4 inch of the same epoxy and they held more weight than I had lying around.
Crappy ascii rendering of the test:
J
They've hardened a lot, I did the same test with these as the originals by squishing them in a vice. Very noticable improvement.
-Simon
04 STi LCA into a GC....PART 1...Press your own FRONT bushings....Alu. LCA differeces psyber_0ptix Brakes, Steering & Suspension 51 05-09-2012 03:12 PM
Note to all: Dont press your own bushings unless you have bushing pressing skills... Kostamojen Brakes, Steering & Suspension 14 07-03-2006 09:11 PM
Install Help: Whiteline Hardened Steering Rack Bushings Padge Brakes, Steering & Suspension 2 05-23-2005 03:12 PM
Make your own Bush Speech..... ZMANNH25rs Political Playground 18 03-21-2004 10:29 PM
Make your own Bush Cheney 04 Campaign Poster! amp5 Off-Topic 35 03-15-2004 04:20 PM
