Old 07-18-2005, 04:47 PM   #1
sandsubaru
Member#: 91357
Subaru Stars 2.2na heads with turbo block
i have a 90' turbo 2.2 short block and 93' 2.2na heads and i want to run a subaru turbo, the catch is even with a low comp. turbo block, will the 93' ecm put too much timing in and what of the mas on the air intake, will the non turbo ecm not care? the good news is even with 270cc(or something) injectors on the 2.2na heads, i will run a fuel management (fmu) 10psi to 1lb of boost. i only plan on 4lb or so of boost with this ecm. thanks
sandsubaru is offline   Reply With Quote
Old 07-18-2005, 07:20 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Look in the conversions forum for Natoe's Ej22t thread. That should answer most of your questions...
Upgraded 2.0 heads with 2.5 block MS WRX Built Motor Discussion 3 01-11-2008 08:21 PM
2.2NA compatible with WRX tranny? LatentWagen Legacy Forum 7 08-22-2006 01:16 PM
2.5 block, 2.0 heads, FP18g turbo WRX BrettS Subaru Conversions 5 10-24-2005 01:08 PM
99 2.2 vs 2.5 heads on EJ22t block mikeje Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-21-2001 12:28 AM
What happens: 2.2l block with 2.5 heads, no turbo Jessie James Normally Aspirated Powertrain 6 02-16-2001 10:38 PM
