Old 07-18-2005, 07:10 PM   #1
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Inexplicably rusting.....
Default body roll in the corners
is it the crappy stock tires that make the car feel like it rolls in the corners, or is it the suspension?
hendo2.5 is offline   Reply With Quote
Old 07-18-2005, 07:17 PM   #2
STIgeorge
Member#: 22040
12 FJ Cruiser
Rent-a-car White
suspension
STIgeorge is offline   Reply With Quote
Old 07-18-2005, 07:20 PM   #3
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
On an RS, it would be a combination of all three: shocks/springs, sway bars, tires.
Evil STI is offline   Reply With Quote
Old 07-18-2005, 08:51 PM   #4
kcook
Member#: 78074
2005 STi
^ thats because its an rs... on my car... if i take a corner at a reasonable speed... i screech my tires a tad.
kcook is offline   Reply With Quote
Old 07-18-2005, 10:07 PM   #5
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
i thought the wrx and rs were identical in terms of everything but the engine.
Old 07-18-2005, 10:11 PM   #6
-Kevlar-
Member#: 82378
no...
-Kevlar- is offline   Reply With Quote
Old 07-18-2005, 10:47 PM   #7
WRXdriver04
Member#: 72560
04 WRX (stg. II)
java black prl
i thought coilovers would eliminate some.. but it didnt eliminate as much as i thought it would.. because i still feel some roll. i believe sway bars would make it alot more solid in terms of body roll
WRXdriver04 is offline   Reply With Quote
Old 07-18-2005, 10:57 PM   #8
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Originally Posted by wrxblubayou
no...
okay, so...
Old 07-18-2005, 11:00 PM   #9
Call_me_Tom
Member#: 60972
Originally Posted by hendo2.5
okay, so...
I know that the swaybars are smaller on the RS and the damping is different (softer) too. I don't know about the springs.
Call_me_Tom is offline   Reply With Quote
Old 07-19-2005, 03:14 PM   #10
Back Road Runner
Member#: 60082
2004 Forester STI
Swaybars would be the biggest influence as it will resist the roll. Stiffer springs do as well. Springs control front/rear roll and springs+swaybars control side-to-side roll. Swaybars only affect side-to-side movement, so they're usually the one that gets upgraded for controlling roll. As well, they don't influence ride comfort like springs would(except very uneven surfaces).
Stiff swaybars will do a lot. Springs will also influence roll, but it also affects dive and squat and overall ride quality(better or worse depending on how you like your car to ride). Swaybars are the most specific tool to target roll as it very few other side effects that come with it.
Still, you will notice a difference between tires as well, not so much roll(a little) but rather crispness of handling and side-to-side car flex/movement.
The RS and the WRX are two different classes of the same car. One shouldn't expect the same suspension tuning between the base trim and a performance trim version of the same car, same with STI or even my Forester. They're all set up in their own way.
Old 07-19-2005, 05:31 PM   #11
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
oh. it looked like they were in the specs. oh well.
Removing body roll in the Bay Area... boka Bay Area Impreza Club Forum -- BAIC 16 04-22-2002 01:43 AM
eliminating body roll in a 2002 wrx sedan moojamboo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 04-18-2002 01:37 AM
Eliminating Body Roll in WRX Wagon gpxl Brakes, Steering & Suspension 1 05-09-2001 06:56 PM
Gauge pods in the corners of Instrument cluster?!?! Dan_E General Forum Archive 17 12-08-2000 06:18 PM
