Old 07-18-2005, 11:11 PM   #1
fastXT04
Member#: 78663
04 WRX STi
Default HELP 235/40/17 Tires on stock 04 STI rims
can i fit 235/40/17's on stock sti rims? the 17 by 7.5 04 bbs wheels? would that tire size fit safely and provide any peformance gain?
please let me know soon i am ordering some new tires
fastXT04 is offline   Reply With Quote
Old 07-19-2005, 05:58 AM   #2
ripvw
Member#: 27790
every tire manufacturer recommends a minimum of 17x8 wheel size for the 235/40x17. having said that - lots of people on this board are running them on 17x7.5 including our own lovable guru Uncle Scotty. Is it safe - your call. If you're worried about it, call an insurance company (not yours) and ask them if they will still insure the car if you have an accident and they find out you're running a "non-approved" wheel/tire combo. they'll probably say "no".
...provide any peformance gain?
on that size wheel, the 235/40x17 tire will be a bit wider than the 225/45x17 and have a lower profile for better dry grip - probably a little worse in the rain. even more important for some people is the fact that the 235/40x17 size is smaller in diameter than the 225/45x17 size - it is "underdriven" by 2% and that gives you a favorable gearing advantage through all gears for quicker acceleration.
finally, the 235/40x17 size is often a pound or two lighter than the equivalent 225/45x17 tire.
ripvw is offline   Reply With Quote
Old 07-19-2005, 06:51 AM   #3
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
235/40-17 will be fine on that rim. It will be a bit shorter though than the stock size. The speedo on the STi's are already too fast with the stock tires, that size will make it a bit slower. The 235 tire might be a pound lighter in some cases, but it is a pound heavier in others. Not enough to make a difference. There will be no difference in performance in the rain as well for that little a difference. Never known of anyone having insurance problem with larger tires either.
rankink is offline   Reply With Quote
Old 07-19-2005, 07:22 AM   #4
fastXT04
Member#: 78663
04 WRX STi
thanks alot for your help so this is not recommended except maybe to look a little cooler meaning wider which is really why i want to do it
Old 07-19-2005, 07:59 AM   #5
rankink
Member#: 12901
2005 STi/95 VX
Will be a bit wider, and like I said you will not have a problem. I run 255/40's on my 8 inch wide wheel with no problems.
Old 07-19-2005, 08:53 AM   #6
ripvw
Member#: 27790
no, it's really a performance mod - better handling in the dry, quicker acceleration - which is why people are willing to "risk" doing it with smaller than recommended wheels.
but it does look cooler...
Old 07-19-2005, 11:09 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....d00d.....on an STi, you should go with a slightly TALLER tire to get a bit more gear out of it....THAT would be choice for an STi......the WRX needs a bit of help the OTHER way, gearing wise.....and I'm really diggin' the slightly smaller tire, on the WRX, as far as that goes
I'd do a 235/45 on an '04 STi wheel...
Old 07-19-2005, 12:11 PM   #8
rankink
Member#: 12901
2005 STi/95 VX
Agreed. My next street tire for my 05 STi will be a 235/45, which will help with the gearing and the speedo. I believe that is the stock size the JDM models have on them.
Old 07-19-2005, 05:57 PM   #9
ripvw
Member#: 27790
.....d00d.....on an STi, you should go with a slightly TALLER tire to get a bit more gear out of it....THAT would be choice for an STi......I'd do a 235/45 on an '04 STi wheel...
Hey Scotty, I understand the gearing argument for the STI when autocrossed, but does it really apply to a street driven car? I'm sure you've got more experience driving STI's than I do (one quick run in a dealer car), but it seems to me that for the street underdriven is always a good idea.
Originally Posted by rankink
..I believe that is the stock size the JDM models have on them.
showing 225/45x17 for the "global" 2.0L STI:
http://www.subaru-global.com/lineup/...eet/index.html
Old 07-19-2005, 08:06 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
...there has been some discussion between some local peeps----subaru parts dept/performance enthusiast guys and it seems that, on the '05 STi's, the 225/45 gives an incorrect spedometer reading......the 235/45 makes it spot on.....the S203 has 235/45's, stock....go figure.
...and the STi could use a bit longer 1st and 2nd gear...less shifting--stay in boost ....and a bit taller tire does just this.....go figure.
Old 07-19-2005, 08:07 PM   #11
rankink
Member#: 12901
2005 STi/95 VX
I must have mistaken it for something else. Maybe because the EVO comes with the 235/45-17. As for the gearing a little extra is always good for autocross, but it is so minimal between 225/45 & 235/45 that you would not even notice the difference on the street. The positive side would be that it would correct the speedo.
Old 07-19-2005, 08:09 PM   #12
rankink
Member#: 12901
2005 STi/95 VX
The 225's do, and I have confirmed that it is about 3-4 mph off at 70 mph on a GPS. Maybe it was the S203 that I saw with the 235/45 size.
Old 07-20-2005, 05:45 AM   #13
ripvw
Member#: 27790
was not aware that the S203 ran 235/45 - thanks for the info!
will 235/40-17 rub on stock 03 WRX Sedan WRXINXS Tire & Wheel 11 10-13-2007 03:13 PM
235/40/17 tires on 17x7 rims. cinemaster Tire & Wheel 9 05-03-2006 11:36 AM
Is it okay to mount 235/40/17 tire on a 17/7.5 wheel?? WRXinEffect Tire & Wheel 17 05-30-2005 08:56 AM
Looking for pics of a 235/40/17 tire on 7.5 STi wheel rich728 Tire & Wheel 7 06-29-2004 12:47 PM
does anyone have 235/40 17 tires on 7.5" wide wheels? rex n effect Brakes, Steering & Suspension 0 02-03-2003 01:22 AM
