Old 07-19-2005, 08:17 AM   #1
bdoss123
Member#: 19958
Default 105K - 1997 GT, CEL w/ no symptoms...?
Howdy folks,
My 1997 GT has been near problem free since I've owned it, and hopefully this will be a sensor as opposed to a problem. It through a CEL last week on the way to the mountains and the lights has been turning off, and then back on, intermittently since then.
Any ideas?
Thanks,
Brendan
bdoss123 is offline   Reply With Quote
Old 07-19-2005, 08:22 AM   #2
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
whats the code?
iamrazor is offline   Reply With Quote
Old 07-19-2005, 11:23 AM   #3
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
gonna guess it has to do with the cat(probably a sensor)...but we need to code pulled.
fibuz is offline   Reply With Quote
Old 07-19-2005, 11:52 AM   #4
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Any idea where you live? Lots of us don't mind pulling codes for fellow Subaru owners.
LetItSnow is offline   Reply With Quote
Old 07-19-2005, 06:01 PM   #5
kmin
Member#: 28968
1997 BG Outback Ltd
black riding on MR.
stop by a local autozone and ask them to scan the code for you - think they do it for free.
kmin is offline   Reply With Quote
Old 07-19-2005, 06:27 PM   #6
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I got a code pulled a few weeks ago free by Auto Zone/Schucks. I think Pep Boys does it for free also. Just ask at the counter to borrow their OBDII scanner.
fibuz
Old 07-20-2005, 01:08 PM   #7
Dobes
Member#: 164
2008 Exige S240
My guess is the O2 sensor if you're not feeling a difference in driving behavior. I had an O2 wire corrode and give me that type of CEL. Are you on the original sensors?
Pull the code and know for sure, it'll save you some headaches.
JD
Dobes is offline   Reply With Quote
Old 07-20-2005, 01:33 PM   #8
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
fibuz
Problems with the BE?
bhall is offline   Reply With Quote
Old 07-20-2005, 01:38 PM   #9
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
nah, un-fully tightened gas cap owned me
fibuz
Old 07-20-2005, 02:03 PM   #10
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
sweeeet I was waiting to hear "I had a bad O2 sensor so I went ahead and did an STI swap."
Old 07-20-2005, 02:19 PM   #11
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
fibuz
you? come on!
at least say the wife or gf did it! Thats what i would do
Old 07-20-2005, 02:57 PM   #12
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Originally Posted by iamrazor
you? come on!
nah, I'll take the blame...it was after about 25 hours of continuous driving from AZ up to WA...I was a bit out of it and neglected to tighten it as much as I should have.
fibuz
Old 07-20-2005, 07:53 PM   #13
lag
Member#: 34631
to live in fear
To the original poster... Mine has been doing the same thing for a while, the code always is miss fire in **random cylinder**. I've noticed it does this as my drivetran is shocked from decel to accel or vice vice. This is a known limitation of knock sensors of not being able to tell an engine knock from drivetrain shock.
For me I just chalk it up to transmission loosness/wear.
Yes I've replaced my plugs and wires
lag is online now   Reply With Quote
Old 07-21-2005, 03:07 PM   #14
bdoss123
Member#: 19958
Thanks for the replies, been a few days since I had time to check here. I still haven't had time to mess with the car either but will this weekend. My tranny feels like the most probable cause, as it's a bit worn, but I need to go ahead and pull the code. I'm in NC - Chapel Hill area.
- Brendan
Old 07-26-2005, 02:39 PM   #15
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
Any autozone or advance auto parts should pull the code for you for free.
My experience this weekend was:
Autozone: came outside and scanned the car with a scanner that displays the code directly, then printed it out in-store. They didn't clear the code and I didn't think to ask.
AAP: gave me a scanner and said 'follow the prompts and bring it back'. I scanned the car (it didn't display the code) then cleared the code out. When I brought it back inside they plugged it in and printed the code.
My GT is throwing a P0325 (Knock Sensor 1 Circuit Malfunction) code at the moment, which I'm going to hopefully look at this week. After I cleared it, it took ~100miles to come back so hopefully it's just a bad connection in the circuit.
Dan Cech is offline   Reply With Quote
Old 07-26-2005, 04:19 PM   #16
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
lag - you can reposition the knock sensor to avoid the excessive vibrations as being interpreted as engine knock. Too much will retard your timing...
Huffer is offline   Reply With Quote
Old 07-26-2005, 04:25 PM   #17
gt_drifter
Member#: 61907
1998 2.5 GT
spruce pearl
what was the code?
gt_drifter is offline   Reply With Quote
CEL code P1507 with no symptoms dlong27 Normally Aspirated Powertrain 2 11-05-2008 10:27 PM
P1507 CEL, no symptoms opious Service & Maintenance 4 01-13-2006 12:35 PM
CEL...then no CEL RStoR Newbies & FAQs 2 07-06-2004 10:34 AM
gutted uppipe, cel or no cel? recursian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-17-2002 03:57 PM
CEL or no CEL? chuglobal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-25-2002 03:23 PM
