Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 07-19-2005, 10:42 AM   #1
Suberman
Member#: 82487
2007 WRX STI Spec C
Default Very little lag with 9:1 CR jdm EJ205
with 9:1 CR on a JDM EJ205, i'm willing to bet it would give better mileage than a usdm/uk EJ205?? i'm just not too happy with the power to gas mileage ratio on my stock wrx. my civic might be marginally slower, but its alot more frugal. I get around 20 mpg now compared to almost 30mpg with the civic, although my wrx is faster, but its probably only about 1 sec quicker at the dragstrip.
Also, a jdm wrx uses a vf35, but with much higher CR, it has less lag and hits boost easier and earlier. Would i be able to get the same kind of response (less lag) if i do v34, a tune, TB?? considering the ball bearing design of the vf34 as compared to a vf35. will i overcome the lower CR with a ball bearing turbo??
Suberman is offline   Reply With Quote
Old 07-19-2005, 11:27 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
huh??
Old 07-19-2005, 12:03 PM   #3
Suberman
Member#: 82487
2007 WRX STI Spec C
let me rephrase that then.
would a jdm ej205 with 9:1 CR give much better gas mileage than a usdm with 8:1??
A jdm wrx has less lag and gets boost faster and easier than a usdm because of avcs, higher CR etc etc....would a usdm with a vf34, supporting mods and a tune be able to match a jdm motor in terms of response (as little lag)?? considering the vf34's ball bearing turbo.
Old 07-19-2005, 12:20 PM   #4
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
JDM Wrx does not use a vf35..
Dave-
Kingpin is offline   Reply With Quote
Old 07-19-2005, 12:24 PM   #5
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
While it is true that a higher compression engine will in fact use less fuel than its lesser compressed twin, I'd venture to say that going from 8:1 to 9:1 would not make a substantial difference.
n2xlr8n is offline   Reply With Quote
Old 07-19-2005, 12:45 PM   #6
Suberman
Member#: 82487
2007 WRX STI Spec C
Dave-
what does it use then?? thought i read it somewhere which said it used a vf35.
Old 07-19-2005, 12:53 PM   #7
cronic
Member#: 9749
Td04..
Dave-
cronic is offline   Reply With Quote
Old 07-19-2005, 12:53 PM   #8
Panic
Member#: 48699
2008 Evo X GSR
Apex Silver
I would also add that all easily perceptible earlier spool on a jdm EJ205 is from AVCS not from a change in CR.
I believe that euro spec sti use or used the vf35 and perhaps a special edition wrx also euro spec but my memory may be failing me.
_Peter
Panic is offline   Reply With Quote
Old 07-19-2005, 12:54 PM   #9
Suberman
Member#: 82487
2007 WRX STI Spec C
i don't see why it shouldn't be more fuel friendly, 1 point more compression coupled with avcs should make quite a difference especially during off boost driving.
what about power delivery?? with a good 9to1, its gonna be alot nicer and faster getting boost than a usdm. will i be able to get close to that kind of response with a BB turbo (vf34)??
so BB bearing turbo VS 9to1 CR and avcs. who wins in response??
Old 07-19-2005, 12:55 PM   #10
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
If you're getting into boost sooner, you'll be burning more gas (more air = more gas). Now, that's simplified quite a bit, because timing has a lot to do with it, but a Civic will inherently get better gas mileage.
gjhsu is offline   Reply With Quote
Old 07-19-2005, 12:57 PM   #11
Suberman
Member#: 82487
2007 WRX STI Spec C
any jdm EJ205 users here?? tell me what you think.
Old 07-19-2005, 01:02 PM   #12
Suberman
Member#: 82487
2007 WRX STI Spec C
but it would be more efficient if i'm just cruising on the highway.
so that gives the best of both worlds in a way....early boost when u need it (which u would burn more gas) but fuel efficient when u cruise.
Old 07-19-2005, 01:04 PM   #13
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Here in the caribbean, the higher compression cars will drive more like a na car, before boost.
Thats all the high compress will allow, but for all out power, you will need to lower it.
I think the new STI JDM does it on 9 or 8.5.
west_minist is offline   Reply With Quote
Old 07-19-2005, 01:08 PM   #14
cronic
Member#: 9749
Yup i have one in my gc.. It is a fun motor, no real complaints.
Dave-
Old 07-19-2005, 01:17 PM   #15
Suberman
Member#: 82487
2007 WRX STI Spec C
Dave-
so its a td04 then?? i'm assuming the extra 25 hp and 30lb/ft comes from higher boost and the higher CR, cams, etc etc??
how is off boost driving feel?? does it respond much faster than a usdm? because if find the usdm rather laggy without much punch even on boost.
have u compared it with a vf34 powered wrx?? if so, hows it??
Old 07-19-2005, 01:17 PM   #16
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I was speaking strictly of the differences static CR produce in regards to fuel consumption. Will it use less fuel? Certainly. Will you notice it? Probably not.
Will it be "peppier"? Yes. I do not have AVCS, so I can't comment on that.
Old 07-19-2005, 01:25 PM   #17
cronic
Member#: 9749
Well you are talking vf34 vs tdo4.. Keep in mind my car is a GC so it is light.. At 227whp i was pulling on friends 280whp stg 4 cars from a roll..
Dave
Old 07-19-2005, 01:53 PM   #18
YumGTR
Member#: 63779
1989 BNR32
in comparing gas mileage between a civic and a wrx, you need to look at the obvious difference between the two cars in terms of weight. of course you're going to get better gas mileage in a civic, regardlss of the difference in motors, or CR, because the WRX is a heavy pig in comparison to the light weight civic.
YumGTR is offline   Reply With Quote
Old 07-19-2005, 02:00 PM   #19
r0nzar
Member#: 78957
'06 Evo IX RS
White on white on salt
and it's also driving 3 more wheels
r0nzar is offline   Reply With Quote
Old 07-19-2005, 03:08 PM   #20
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
mostly from a more agressive tune than the usdm.. just look what a stage 1 AP does
but yeah
more boost+more avcs+more compression = more fun
Old 07-19-2005, 08:48 PM   #21
Zeglus
Member#: 54574
2003 Impreza WRX
WR blue
are you looking to save money here? cus its going to take a whole lot of mileage to make up for the money you dump on an entire new motor
Zeglus is offline   Reply With Quote
Old 07-21-2005, 11:40 AM   #22
Suberman
Member#: 82487
2007 WRX STI Spec C
i get where ur goin with this....i mean, i figured if a jdm ej205 is a much nicer to run motor, i might swap it it and call it a day, afterall i'm not after massive power. but then again, with the money involved with a swap, i might as well get a vf34 and a nice tune and have even more power.
so thats why i'm asking if a usdm with a vf34 could match a jdm ej205 in terms of response and driveability??
i'm after quick response and of course some power to match.
Old 07-21-2005, 11:44 AM   #23
Suberman
Member#: 82487
2007 WRX STI Spec C
i know its an unfair comparison, but the performance i'm getting isn't worth the extra fuel consumption. and yes, its a stock wrx.
Old 07-21-2005, 11:46 AM   #24
Suberman
Member#: 82487
2007 WRX STI Spec C
Dave
what u got under the hood?? ur pulling 227 with a jdm ej205 with a tdo4?? and ur beating stg4 cars??
Old 07-21-2005, 12:29 PM   #25
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
Yes, it is in a Gc, big weight difference.
2004 WRX hybrid - 2.5L 9:1 CR GT35R Topspeed tuned CoolRex Proven Power Bragging 61 02-16-2011 09:23 PM
Break-in tune: 2.5L 9:1 CR EJ257 + GT35R = 430whp @ 15-16psi jays05 Proven Power Bragging 96 03-05-2010 08:36 AM
Find me this movie trailer with very little info rogue Off-Topic 40 10-28-2009 10:24 AM
FS: VF39 & Sti Intercooler with very little miles on it. mingstersol Engine/Power/Exhaust 3 09-10-2007 12:33 PM
JDM WRX 9:1 CR Piston Design wackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-10-2003 06:39 PM
