Old 07-21-2005, 01:47 PM   #26
pux888
Member#: 8356
02 STi swap
12 WRX limited
Originally Posted by cronic
Well you are talking vf34 vs tdo4.. Keep in mind my car is a GC so it is light.. At 227whp i was pulling on friends 280whp stg 4 cars from a roll..
Dave
gotta agree w/ you there, a friend of mine has one w/ a nice setup and its like tearing around in a go cart compared to my rex.
pux888 is offline   Reply With Quote
Old 07-21-2005, 02:41 PM   #27
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Rallispec used to say that the VF35 came in JDM WRX's. Don't know why they say that. I can't personally say they are wrong, but many others can.
garface is offline   Reply With Quote
Old 07-21-2005, 04:23 PM   #28
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Cronic had a Ver7 RA and a JDM WRX motor. What does he think between the two with response relating to compresion. Both have AVCS. One had 8:1 one had 9:1.
ebeck is offline   Reply With Quote
Old 07-22-2005, 02:35 PM   #29
Suberman
Member#: 82487
2007 WRX STI Spec C
yes!! thats where i read that jdm wrxs came with vf35. thanks for refreshing my memory.
Suberman is offline   Reply With Quote
Old 07-24-2005, 01:39 AM   #30
Suberman
Member#: 82487
2007 WRX STI Spec C
what kinda boost are we limited to with 9to1 CR?? so can i safely say that, with a 8to1, i'll ultimately get more power with mods than a 9to1, considering a higher boost is possible??
cronic, so whats ur view on CR with relation to response?? what is your set up on the 227whp??
finally, can anyone comment on a vf34 usdm vs a jdm ej205 in regards to response??
Old 07-24-2005, 02:08 AM   #31
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
20# of boost with 8:1 is less energy than 20# of boost with 9:1. The tuning is a bit harder though and you need 2 steps colder plugs or you will get no where. If you get it right you will make more power. Ver8 Sti is 9:1 as well.
Old 07-24-2005, 03:16 AM   #32
Suberman
Member#: 82487
2007 WRX STI Spec C
hmm...looks like a jdm ej205 will definitely make more power than a usdm with same mods then. btw we get up to 98 octane gas over here!!
www.subaru.co.jp states that the jdm wrxs get something like almost 27-28mpg!! cronic, is yours that efficient??
doesn't ver8 sti come with 8to1 as well?? just checked it out at www.subaru.co.jp
vf34 usdm vs jdm ej205. some opnioins?? what i wanna know is that, if a tuned usdm can match a jdm in response.
Old 07-27-2005, 02:40 AM   #33
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Originally Posted by Suberman
so its a td04 then?? i'm assuming the extra 25 hp and 30lb/ft comes from higher boost and the higher CR, cams, etc etc??
Don't forget those numbers are on fuel from japan. And I dont think they run higher boost.
These motors can be had for very cheap, about 2k shipped. My JDM EJ205 had less then 500 miles. However if you want to use AVCS you will need a new ECU thats capable of AVCS. Overall its not a good mod in terms of value. However if you toasted your WRX motor, or are looking for a cheap turbo motor to swap into a n/a car then its a great idea.
Heres a pic of my JDM EJ205 that I'm putting into my 95L.
RS_to_WRX_swap is offline   Reply With Quote
Old 07-27-2005, 07:25 AM   #34
Suberman
Member#: 82487
2007 WRX STI Spec C
damn!! that looks Cleeeannn!! it isn't that cheap over here, once u factor conversion rates, shipping etc etc.
Old 07-27-2005, 09:51 AM   #35
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
I drove on this engine and it really strong. It really makes me wonder how the STI gets on in the JDM, since the USDM STI is slow in stock trim.
Also, JDM engines performs better with mods compare to the USDM.
RS_to_WRX_swap, where did you get your engine from?
What was included in the order? Harness, turbo and so on...
west_minist is offline   Reply With Quote
2004 WRX hybrid - 2.5L 9:1 CR GT35R Topspeed tuned CoolRex Proven Power Bragging 61 02-16-2011 10:23 PM
Break-in tune: 2.5L 9:1 CR EJ257 + GT35R = 430whp @ 15-16psi jays05 Proven Power Bragging 96 03-05-2010 09:36 AM
Find me this movie trailer with very little info rogue Off-Topic 40 10-28-2009 11:24 AM
FS: VF39 & Sti Intercooler with very little miles on it. mingstersol Engine/Power/Exhaust 3 09-10-2007 01:33 PM
JDM WRX 9:1 CR Piston Design wackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-10-2003 07:39 PM
