Old 07-19-2005, 04:45 PM   #1
Kensubguy
Member#: 84082
Default Multiple leak
My subaru legacy I noticed is wet at the front of the engine between the oil pan and the second rectangular pan ( I am not sure what it holds, I assume transmission fluid). The oil change guys say it might be the oil pan gasket and posibly other multiple sources. The leak is not substantial to wet the floor but I worry too some of it is presure related while driving. Anyone with a take on this.
Kensubguy is offline   Reply With Quote
Old 07-19-2005, 04:50 PM   #2
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
What kind of fluid? it's wet, yes, but is the fluid colored? Black? Red?
What does it smell like?
Huffer is offline   Reply With Quote
Old 07-19-2005, 09:17 PM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
What year? Probably the famous oil seperator plate.
ss
subysouth is offline   Reply With Quote
Old 07-19-2005, 09:18 PM   #4
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
ss - on his other post he talks about a 99 2.2L... Probably the same car?
fastenova is offline   Reply With Quote
Old 07-19-2005, 09:25 PM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I had some great replies to my thread on the same topic(looking for it.) Mine's a 97 2.5 and the seperator was definitely the problem. 99 2.2L I dont know. At some point Subaru changed the part from plastic to metal.
ss
Old 07-19-2005, 09:29 PM   #6
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Here ya go:
http://forums.nasioc.com/forums/show...oil+pan+gasket
Thought it was the oil pan gasket, it was the seperator.
ss
Old 07-20-2005, 08:07 AM   #7
Kensubguy
Member#: 84082
It is a 99 subaru legacy 2.2 L.
Old 07-20-2005, 08:19 AM   #8
Kensubguy
Member#: 84082
The leak seems to have the feel of something smoother than oil. I will take some pics of the area and post later today. I wonder if the transmission can leak at that point especialy presure leak. I looked up the separator plate link from subysouth but the pics would not load. I am still studying the post to understand it.
Old 07-21-2005, 12:17 PM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
In my case Ken it was definitely oil. And remember used oil is a little thinner(more watery) than fresh oil. The leak from the seperator occurs at the seam where the tranny meets the engine. It also spreads forward and back from that seam. I initially thought my car was leaking at the rear of the oil pan gasket.
The oil seperator is only accessible with tranny pulled. I bolts to the back of the engine block inside the tranny bellhousing and is a seperate issue from the rear main seal. Of course if you have to go in, replace them both. Failure of the seperator and the subsequent leak is common on the older BD/BGs because they made it out of plastic.
I wish the pics were still there, they were excellent. Maybe you could PM wrx_driver_2002 for them.
ss
Boost Leak Help EJ20G clean 93 Pre-2002 Factory Turbo Powertrain 5 06-08-2010 08:48 AM
Shock leaking. 2009 WRX evo_mx5 Warranty Issues & SOA Problems 1 06-02-2010 08:25 PM
leak or no leak..that is the question polobee69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-31-2003 08:29 PM
leak or no leak? blaznasn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-14-2002 07:56 AM
First it's radiator leaking, then clutch master cylinder resorvoir leaking, and then. davidm_sh Warranty Issues & SOA Problems 1 03-24-2002 01:43 AM
