Old 07-19-2005, 06:17 PM   #1
diazaspam
Member#: 75559
2003 wrx
Default Leaking Anti Freeze
There is a small dia. metal pipe on top of the engine between what I think is the ac comp. and the oil dipstick. It contains hi press anti freeze.To cap this pipe subaru uses a rubber cap and a spring fitting like a pipe clamp. The rubber cap sprung a leak. No dealer in my area stocks them.
Does any one know the part I'm refering to? I.E help!
diazaspam is offline   Reply With Quote
Old 07-19-2005, 07:00 PM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Don't even know what car you are referring to.. This forum covers pre-2002 USDM subaru turbo cars.. there are at least 3 distinct configurations in that category
Calebz is offline   Reply With Quote
Old 07-19-2005, 08:25 PM   #3
turbo2ner
Member#: 89385
many most all
WRB/blk/blk/blk/slvr/wht
Does not matter what motor you are talking about. I know what you mean. Those lines are return lines from the heater core, and the turbo coolant. They go down to behind the thermostat and coolant always flows thru that even with stat closed. Go to any auto parts store and look in the Help section, with red cards. They will have an assorted pack of ends to seal with, then use a real hose clamp. Thats a great place to burp air when filling. That rubber gets the heat first diring warm up, and the whole time motor is running, and will crack even befor the upper hose, which will be next on your list. Have you serviced the system recently? Throw in a Crucial fail safe stat!
turbo2ner is offline   Reply With Quote
Old 07-19-2005, 09:28 PM   #4
diazaspam
Member#: 75559
2003 wrx
Thanks. I made it to complicated. The auto store had the caps and hoses.
Your an f...in genius!
Old 07-21-2005, 04:44 AM   #5
Calebz
Member#: 54398
1980 CB400 Hawk
Eh? I don't have anything even remotely resembling his description on either of my 'pre-2002' turbo motors... thats why I asked.
Old 07-22-2005, 05:48 AM   #6
turbo2ner
Member#: 89385
many most all
I'm sure your thermostat housing is in the same place as every other Subaru motor, all our cars have the heater core return going back down there. And most of our turbo cars also have a hard line going back there. Thats the only coolant lines around the drivers side head. Black hard lines. You got em somewhere. I've never owned a pre-2002 Suby, but I own aEJ22.
Old 07-22-2005, 11:22 AM   #7
Calebz
Member#: 54398
1980 CB400 Hawk
Yes, the Tstat housing is in a similar place on most soob motors. But enough other things are different on the Pre EJ motors (EA82T in my case)that the original description didn't make sense if applied to them . Thats why I asked for a specific motor. For example, "between the AC compressor and the oil dipstick tube" could be anywhere, as on my motor, they are on opposite sides of the motor. Also, regardless of the placement of things, I still don't have a 'rubber cap' on any of my coolant lines. I know, I have had a number of these old turbo motors out and just got done rebuilding one. Theres even a generation of turbo motors before mine that is a bit different (OHV-EA81T), so again, thats why I asked.
Old 07-31-2005, 12:10 PM   #8
snowjob
Member#: 59357
2009 Forester XT
Picture if you please
snowjob is offline   Reply With Quote
Rad is leaking anti-freeze help wawawrx Newbies & FAQs 9 03-24-2009 10:32 AM
Great Timing: Anti-Freeze Leak During Finals Week! JohnnyWas Tri-State Area Forum 5 12-18-2007 09:48 AM
Leaking Anti-Freeze Cards2323 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-04-2007 06:37 PM
Anti-freeze leak 907racer Alaskan Impreza Club Forum -- AKIC 52 09-29-2006 07:12 PM
02 Impreza leaking anti-freeze?? Procharged lm7 General Community 4 01-31-2005 07:53 PM
