Old 07-19-2005, 10:41 PM   #1
TexRex2002
Member#: 36303
06 Evo IX
Default Boring the 257
Given the difference in opinion over the strength of the 257's stock sleeves, what are some of your thoughts on boring it oversize to accept forged pistons?
I'm thinking the 100mm pistons, so I guess that would be a .020" overbore or so...
Is the cylinder liner already to thin, or is a mild overbore ok?
Anyone have experience with a bored block?
TexRex2002 is offline   Reply With Quote
Old 07-20-2005, 02:04 AM   #2
Javier
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
I'm not really sure of this answer, but I've heard that the sleeves aren't as thing as originally thought... However, I have heard of some ovaling to them. I'm in the middle of doing a 2.5L buildup and opted to use crawfords long pauter rods to reduce the stress on the cylinder walls...
Javier is offline   Reply With Quote
Old 07-20-2005, 02:10 AM   #3
02Toyowrx
Member#: 56520
100mm is the limit. another option would be to go to darton dry sleeves, so you would just about retain the same OEM cooling properties and have the strength.
02Toyowrx is offline   Reply With Quote
Old 07-20-2005, 01:22 PM   #4
TexRex2002
Member#: 36303
06 Evo IX
hmmm... I wonder if I could just hone the walls out and then order custom pistons from Axis or Crawford. Maybe that would be a better option? I wonder if the pistons would be more expensive...
Old 04-02-2006, 03:08 AM   #5
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Does the STi EJ257 actually have sleeves in them? Are they iron sleeves? I thought it was all aluminum with some kind of coating. Can someone confirm this? I am wanting to replace my pistons with 100mm ones but I am not sure what the cylinder wall material is. I was told you cannot overbore the coated walls (all aluminum bore) as simply as you can cast iron sleeves.
Boostup! is offline   Reply With Quote
Old 04-02-2006, 10:00 AM   #6
import111
Member#: 24447
2016 Mustang GT w/PP
Red
I am pretty sure they are iron sleeves in the ej257
import111 is offline   Reply With Quote
Old 04-02-2006, 10:11 AM   #7
nimblegimbal
Member#: 91120
06 WRX ImpWag
Batmobile Black
ha...
nimblegimbal is offline   Reply With Quote
Old 04-02-2006, 11:12 AM   #8
Starkiller
Member#: 82741
2007 350Z Silver
I've confirmed iron sleeves in bores. Aluminum doesn't rust.
Starkiller is offline   Reply With Quote
Old 04-02-2006, 11:39 AM   #9
railguy
Member#: 53756
100mm is the max that you can bore the stock block with even a close idea of being able to handle power. You can get 100mm sleeves from darton that are very strong. They say you can bore those out to 102mm but if your motor goes boom so does your sleeves and everything. And at 102 it will still be much weaker.
railguy is offline   Reply With Quote
Old 04-02-2006, 12:45 PM   #10
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Aluminum doesn't rust is a good observation. I feel stupid now because I DO remember seeing some light rust in my bores after they were washed and I even put some WD-40 in there to stop any further rust.
So the Darton sleeves require the stock sleeves to be completely machined out, I assume? Any precautions needed to prevent the new sleeves from settling more after engine start up and losing compression load on the head gasket? I remember that being a problem for some people here.
Old 04-02-2006, 01:16 PM   #11
bboy
Member#: 56468
04 Improved STI
Dirty White
Steel liners on all Suby blocks that I know of. The 2004 manual states that 0.020 overbore is the limit. I overbored to fit Mahle 100 mm pistons, can't say what the effect is long term, but short term it's fine.
Old 04-02-2006, 01:44 PM   #12
Javier
Member#: 19346
2003 MBP WRX
Well, I'll let you know how my 100.5mm pistons work out then...
Old 04-03-2006, 10:49 PM   #13
Division By Zero
Member#: 7555
^^ +2
100.5mm here as well. For you guys making guesses on the max bore size, just take a look in the iron liner where the wrist pin hole is and you can clearly see the thickness (or lack there of). After inspecting the block liners, my machinist said it had enough wall thickness so that's what we went with. Although, he mentioned the iron liners weren't perfectly uniform in the cast outter sleeve portion so each block may be a different case. 100.5 is the absolute max though!
Division By Zero is offline   Reply With Quote
Old 04-03-2006, 11:00 PM   #14
bboy
Member#: 56468
04 Improved STI
Dirty White
Well, that's good to know. Maybe this block will see even more miles if I can bore to 100.5. Where are you getting those pistons?
Old 04-03-2006, 11:11 PM   #15
Division By Zero
Member#: 7555
Custom through Wiseco. Next step for me is sleeved though, which I don't plan on doing for a LONG time (knock on wood).
Old 04-04-2006, 12:03 AM   #16
Javier
Member#: 19346
2003 MBP WRX
^^ Same. I don't plan on needing to sleeve this thing, but it's the next and only viable option if something should ever happen to the motor as it sits...
Old 04-04-2006, 02:31 PM   #17
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
The thing to ask is, have you ever seen someone crack a 257 sleeve?
TypeC is offline   Reply With Quote
Old 04-04-2006, 03:59 PM   #18
Division By Zero
Member#: 7555
I have not but anything is possible I guess. Aside from the iron liner, the aluminum casting that encases it is pretty hefty looking. I think it would take some extreme pressure to split it. And as far as ovalling, it has the aditional semi closed support at the top.
Improving the 257 scrankshaft Starkiller Built Motor Discussion 71 04-02-2009 05:38 PM
Sleeve vs Bore the ej257 which one is better? Jimmy168 Built Motor Discussion 2 08-03-2008 06:50 PM
Boring the manifold? IBO Normally Aspirated Powertrain 6 07-10-2001 03:10 PM
Bore the throttle body.. jacktam1 Normally Aspirated Powertrain 4 02-13-2001 10:59 AM
i was bored the other day... solomrus Technical Forum Archive 1 09-10-2000 08:43 PM
