Old 07-20-2005, 01:27 AM   #1
whitey2815
Member#: 89683
2005 2.5 RS
Carbon Grey Metallic
Default 20mm OEM sway bars??
Hey, I have an '05 RS sedan and was wondering if upgrading to the subaru 20mm sway bar would fit/be worth it
thanks in advance!
whitey2815 is offline   Reply With Quote
Old 07-20-2005, 08:08 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Yes it would fit (make sure you get the bushings, too), and yes it would be worth it
Old 07-20-2005, 08:27 AM   #3
Siper2
Member#: 1134
2007 BMW 328xi wagon
Absolutely. Best $80 you'll ever spend.
www.subaruwrxparts.com
(Or get a used takeoff for less...)
Siper2 is offline   Reply With Quote
Old 07-20-2005, 09:14 AM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
The only problem is they are harder and harder to come by. If you're talking rear swaybars, 20mm only came on the 2002 and early 2003 WRX Sedan. The STI's have 20mm bars but they won't fit the RS.
If you're talking front swaybar, the 2005RS already has a 20mm front.
nhluhr is offline   Reply With Quote
Old 07-20-2005, 09:38 AM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
How do you figure that? Pretty much every online vendor who is actually a dealer in disguise (www.subaruparts.com, www.subaruwrxparts.com, etc.) have them for $80 or so.
If he's looking for a used bar, you are correct (since they were only on the 02 and early 03 sedans)
Old 07-20-2005, 02:30 PM   #6
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
i got mine from subiegals website
www.subarugenuineparts.com
svek is offline   Reply With Quote
Old 07-20-2005, 03:22 PM   #7
Siper2
Member#: 1134
nhluhr,
Isn't the front bar 19mm? Think so.
Old 07-20-2005, 03:32 PM   #8
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
do you absolutely need the bushings? stock bushings won't work?
- andrew
AndyRoo is offline   Reply With Quote
Old 07-20-2005, 03:59 PM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Originally Posted by Siper2
nhluhr,
only on select STIs.
Old 07-20-2005, 06:09 PM   #10
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
you might be able to get them to go on there - however, the bushings are sized to the swaybar - you want ones which fit.
Old 07-21-2005, 07:02 PM   #11
PA_02RS
Member#: 82225
2006 VW Jetta GLI
Reflex Silver
Yeah, he's right - I have an '02 RS sedan and I just did the WRX 20mm rear swaybar upgrade (big difference - noticeable reduction in body roll), and learned the hard way. The OEM bushings for the RS are way too big (RS bar is puny - 13mm). Just go to your local scooby dealer and order the two rear sway bar bushings from a 2002 WRX sedan - these will fit perfectly.
Oh, and don't forget to lube the crap out of everything before reassembly, or your car will be squeaking like an old rocking chair over every bump... I used Mobil 1 synthetic all purpose grease, but pretty much any heavy duty grease will work.
PA_02RS is offline   Reply With Quote
FS: OEM 20MM Front Sway bar & 17mm rear sway bar ReiGn_52 SCIC Private Classifieds 2 02-23-2010 11:14 AM
OEM Sway bars, 20mm WRX Rear, OEM WRX wagon front abqkid Suspension/Brakes/Handling 5 09-13-2008 10:24 PM
Rear 20mm OEM Sway Bar to fit '07 WRX Wagon St3fan Private 'Wanted' Classifieds 1 11-07-2006 10:09 PM
SoCAL: WRX Whiteline Rear Strut Bar, OEM 20mm Rear Sway Bar, OEM Boost Gauge, Joe MBC YinUCSD Private 'For Sale' Classifieds 18 03-16-2004 12:42 PM
OEM Subaru 20mm rear sway bar JDMSubaru Private 'For Sale' Classifieds 6 10-17-2003 08:12 PM
