Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 08-10-2001, 05:24 PM   #1
PKduck
Visiting NASIOC Timeout
Member#: 6563
2001 Forester S
black diamond pearl
Question one question.....please give advise
I want to get couple bags of cement....... 80 lbs per bag.....
how many do you think I can load each time in my Forester??? (I don't want to screw up the shocks and springs......thank you~
PKduck is offline   Reply With Quote
Old 08-10-2001, 09:12 PM   #2
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
PK.. I guess you need to look up max cargo limits... if it were me I'd figure the Forester can handle 5 people plus some cargo.
If you drive alone figure 4 pax plus a couple of hundred for cargo. This would equate to about 800 lbs or about 10 bags of concrete which I have done already !
Stanby for some difinitive opinions...
lakepop is offline   Reply With Quote
Old 08-10-2001, 09:19 PM   #3
PKduck
Member#: 6563
2001 Forester S
black diamond pearl
thank you , lakepop~
So, you loaded 10 bags of concrete in on Forester before ??
I'll standby for your advise~
Old 08-10-2001, 09:42 PM   #4
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
PK..yes I have. Obviously I put the back seat down and spread the load out over the area. Only had to drive about 1 mile back to my house and had no problems.
The Forester probably handled the load as well as I did...loading/unloading the 80# bags from the back is not an easy chore and I would recommend that you be mindful of your back to prevent injury.
I would also recommend that you avoid large bumps/high spe
eds other than that .....it worked for me.......
As an aside how did your window visor instal go ?...I am well pleased with mine.
Old 08-10-2001, 10:04 PM   #5
PKduck
Member#: 6563
2001 Forester S
black diamond pearl
Oh, they fit GOOD on my car, but I did a stupid thing.....I wipe
my car with the pad that came with it .....and my piant is not gloss no more , but it got back to shinny after I wax it .......lucky~
Yeah.....80 lbs is pretty heavy man......I am still deciding to borrow a van from my work place or using my own car ......
BTW, thanks~
Old 08-10-2001, 10:16 PM   #6
Ken S
Member#: 1895
05 Leg GT Ltd. W
Talking
PK,
Never, ever dry wipe your paint! Try some 3M Imperial Hand Glaze -- it works wonders on removing fine scratch marks.
Ken
Ken S is offline   Reply With Quote
Old 08-11-2001, 10:51 AM   #7
PKduck
Member#: 6563
2001 Forester S
black diamond pearl
yeah......I know after I see what happened..........too late..... haha
Old 08-11-2001, 03:16 PM   #8
Imprezard
Member#: 3016
CBA GH8
WR Blue
Question
Ken, what's 3M Imperial Hand Glaze?
Imprezard is offline   Reply With Quote
Old 08-11-2001, 05:47 PM   #9
Ken S
Member#: 1895
05 Leg GT Ltd. W
Thumbs up
It's a very mild glaze that does a great job in removing fine scratches and swirls. You can find it at most auto parts stores in the wax section. Works great on dark paints.
http://properautocare.com/3mimhanglaz.html
Ken
Old 08-11-2001, 05:55 PM   #10
Imprezard
Member#: 3016
CBA GH8
WR Blue
Thanks Ken, is glaze similar to wax? or shold I wax after glaze is applied?
Old 08-14-2001, 04:45 PM   #11
juice
Member#: 1424
1998 Forester
Acadia Green Metallic
Payload varies, but it's up to 1050 lbs. So if you're 200 lbs, you could haul 850 lbs of cement, or about 11 bags evenly distributed.
If you have a hitch, borrow a trailer and you can more than double that.
And if you need more than that - call a cement truck!
-juice
juice is offline   Reply With Quote
Old 08-14-2001, 09:27 PM   #12
tahrndt
Member#: 1315
Glaze and rubbing compound are both liquids that contain fine abrasives that when used properly will finely polish you pait/clear coat removing any small surface scratches. Think of them as ultra fine sand paper. (dont ever use sandpaper unless you plan on doing alot of refinishing) but after thier use you will want to apply a good wax job.
Another good product is Maguires, they make some waxes with alittle compound that will remove very small scratches or swirl marks.
TIm
tahrndt is offline   Reply With Quote
Old 08-15-2001, 04:40 PM   #13
Ken S
Member#: 1895
05 Leg GT Ltd. W
Imprezard,
Pretty much what tahrndt said.
What a glaze/rubbing compound does is strip an ever so fine layer of clear coat to smooth out imperfections. It will most likely remove any wax in the process.
FYI, the 3M Glaze is a very mild product and is easy on your paint. I use it once a year to reduce stubborn swirl marks and get rid of mild oxidation.
Ken
Old 08-16-2001, 02:52 PM   #14
AWMIII
Member#: 3980
2004 SVT Focus
Screaming Yellow!
I've had close to 1500lbs in my Forester before. They were cement paving blocks. It felt really heavy, but there were no lasting effects. I drove about 10 miles home from the Depot. I did not exceed 50 mph with the load. I also had 4 adult passengers, my dog and like 450 lbs of gear on the roof and in the car for 16 hours of driving. I might try to post some pictures of that one.
Bill
'02 wrx
99 Forester L
AWMIII is offline   Reply With Quote
Old 08-16-2001, 05:01 PM   #15
Crashton
Member#: 3808
2005 Forester XT!!!
Crystal Gray Metallic
I would think 10 bags of concrete will be no problem. I would pump up the tires to max inflation with that load in the back.
Chuck
Crashton is offline   Reply With Quote
Quick question, please advise!! sfwrx Brakes, Steering & Suspension 4 03-10-2007 11:56 PM
I hate my job. Somone please give me another one! EnforcerPSU Off-Topic 45 08-08-2005 09:17 AM
please give me advise? ride123 Brakes, Steering & Suspension 9 08-26-2004 12:30 AM
Brake questions, please advise - ZMANNH25rs Brakes, Steering & Suspension 1 03-29-2002 01:48 PM
Please give me advises.... PKduck Bay Area Impreza Club Forum -- BAIC 5 10-19-2001 12:01 PM
