Old 07-20-2005, 02:27 AM   #1
949
Member#: 58906
Default How do you remove rotors?
is there a link on how to take off sti 04 rotors?
front and rears.
949 is offline   Reply With Quote
Old 07-20-2005, 02:58 AM   #2
deegan42
Member#: 69312
2002 WRX Sport Wagon
Blue Pearl
I think there may be something on scoobymods about wrx rotors but i am not sure about sti rotors. think it should be the same. Put the car on jack. Remove the bolts behind the calipers that bolt it to the hub. Then you thread a screw into one of the holes around the center of the rotor untill it pops the rotor off. It is pretty easy. Hardest part is breaking the bolts loose to get the caliper off. Just know that whatever screw you use to break to rotor free from the axel will probably be busted at the end, so have 4 screws ready.
Ryan
deegan42 is offline   Reply With Quote
Old 07-20-2005, 03:02 AM   #3
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
No link but easy to explain:
1.raise the car using floor jack and jack stands
2.take of front wheels
3.look at the inside side of the caliper and yuoll see 4 bolts, 2 of them have a little rubber sleeve that they screw into, dont touch those. Take the other two off.
4. once you take those off you can remove the caliper (dont let it hang on the brake line though)
5. pull off the rotor
Same for the rear.
EDIT: wait Sti brembos dotn have the rubber sleeves, forgot its 4 pot for a min.
~Leor
WRC1 is offline   Reply With Quote
Old 07-20-2005, 03:09 AM   #4
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Same for the rear.
~Leor
That basically sums up how to remove calipers in one piece. I use a short bungee cord to hold the calipers to the springs, works beautifully.
eltrouble is offline   Reply With Quote
Old 07-20-2005, 03:18 AM   #5
949
Member#: 58906
isnt there a large screw bolt that holds in the rotors?
Old 07-20-2005, 03:20 AM   #6
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
....no....
It's held on by the lug nuts...and the rust that's built up after awhile. After you remove the caliper it can come off, now depending on when the last time those rotors came off, it might be a huge PITA
The rust might REALLY have a hold on them. If you're having a tough time, you could use a ball-peen and give the rotor several raps to help break the rust loose, or you can use a bolt to screw into those two empty slots to help push it off the surface. I THINK it's a 8mm or 10mm standard pitch bolt...but don't take my word for it.
Old 07-20-2005, 03:24 AM   #7
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
living in souther california you shouldnt have to much trouble with rust. I usually pull mine off with no problems but if its giving me trouble i get a mallet and hit the rotor a couple of time top bottom then side side.
Old 07-20-2005, 03:31 AM   #8
949
Member#: 58906
wow thanks guys. i wish there were pics here for this. i do hope it comes off easily as you all say.
Old 07-20-2005, 03:32 AM   #9
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Well normally we don't...but...rust can develop quite easily after a long drive. Drive around a lot, park the car for a little bit, come back, and you'll be guaranteed to find some oxidation on the rotors. And remember that rain we had half a year ago? That stuff definitely built up some rust.
Old 07-20-2005, 04:59 AM   #10
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
True.
Old 07-20-2005, 06:29 AM   #11
Stiguy247
Member#: 69301
2xx5 STi-R..
Crystal Grayish Metallic
soft face mallet works wounders on rusted rotors....except Ford Trunks and SUVs...got to get the wiz wheel out
Stiguy247 is offline   Reply With Quote
Old 07-20-2005, 07:18 AM   #12
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Don't forget that brakes create a lot of HEAT, that always speeds up chemical reaction.
Old 07-20-2005, 08:51 AM   #13
Siper2
Member#: 1134
2007 BMW 328xi wagon
Definitely use the bolt-hole removal method. It's absolutely the easiest way. I don't remember the size either, though.
I think the one that holds the wiper arm on, can be used in a pinch....
Siper2 is offline   Reply With Quote
Old 07-20-2005, 09:27 AM   #14
edmundu
Member#: 54672
It uses an 8mm 1.25 bolt. Can find these at any decent hardware store, Home Depot, etc... I would also buy a few extra. I also have used Pb Blaster on the threads of the bolt to help it thread into the rusted rotor, makes things alot easier.
edmundu is offline   Reply With Quote
Old 07-20-2005, 01:09 PM   #15
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
I think the jack bolt method is a waste of time. PB around the hub - wait 1 minute then tap the rotor - that has never failed me and I live in the NE
infantsam is offline   Reply With Quote
Old 07-20-2005, 01:23 PM   #16
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
front and rears.
Link to the 2004 Impreza WRX STi Service Manual:
http://www.cl50.com/xweb/STi%20Manual/
Good luck!
AndyH is offline   Reply With Quote
Old 07-20-2005, 01:29 PM   #17
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
also you can check out the stoptech technical docs on how to install their kits. It will show you how to remove the stock calipers and rotors with pics.
http://www.stoptech.com/technical/installation.htm
Arnie is offline   Reply With Quote
how do you remove really stuck rear rotors? jimmijames Brakes, Steering & Suspension 5 05-07-2004 10:36 PM
removing defi pod -- broken tabs, how do you remove whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-23-2003 01:49 AM
('93-'01) How do you remove cup holder? Alex RS Impreza Forum 1 06-13-2001 07:53 AM
('93-'01) How do you remove the corner lamps? GooseMan Impreza Forum 2 05-03-2001 11:48 AM
Help! How do you remove the needles? EaStErN RS New England Impreza Club Forum -- NESIC 5 04-01-2001 07:08 PM
