#1 |
Member#: 59357
E. Canada
Vehicle:2004 Forester XT Silver |
So here is my ride, for about a year and a half now everyone has heard about this beast, but nobody has really seen it, Well she's finally done.
Here are the specs 1991 Legacy SS 1989 ej20g with AWIC - 3" custom exhaust with divorsed downpipe - V1 Sti ECU running 17LBS Boost at 5200RPM - 1999 RS interior - 1997 Legacy twin Turbo steering wheel - Various other JDM stuff, if you want to know what or where I got it just ask. -2004 WRX Struts, rear springs and tophats - 1998 Legacy H&R Lowering springs in the front - Various bushings and suspension components by whiteline - WRX Hoodscoop - WRX rims with re92's - 2 Donor Legacy SS's now crushed and probably in the pop can your drinking - Auto to manual conversion What's on the way VF-30 2004 STI yellow side feed injectors Now that it's done, I'm so happy, It's really fast, like scarry fast and handles like a dream. What can I say about the whole conversion, people who said that it's only like 4 wires, You all were wrong, it's about 15, repins an whatnot. Props to Richard and Guito here in ottawa for helping me get her going, these guys are swapping gurus who know thier stuff, Thanks guys. Big Thanks to Michael Hooper at Jarco Enterprises in Atlanta who sold me the ej20, and a year later when he heard it had rod knock, sold me a replacement 96 JDM WRX engine with Tranny at cost (that will be put in in Sept) So right now it knocks like a bastard, but runs o soooo good. Enjoy the Pics, let me know what you think, Mods, if you can figure out how to resize the pics let me know. Thanks Frazer Almost their ![]() ![]() She's Done ![]() ![]() ![]() ![]() ![]() ]
#2 |
Member#: 51282
Vehicle:98 RS black & blue from parking |
Looking very nice, it's apparent that you did your swap right. I like the AWIC.
Are you planning to tidy up those hose clamps? |
#3 |
Member#: 59357
E. Canada
Yes, I just need to cut the extra peice off.
#4 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
So what wiring is involved outside of converting to the coil on plug ignition, and all that that entails?
#5 |
Member#: 59357
E. Canada
Well not too much, Switching the pins for the Jegs Maf, eliminating the existing USDM ignitor and wiring. Their were afew other pins that needed swapping, I think my biggest problem was a large red squirel that decided to go to town one day in my barn. He particularily enjoyed the Pressure sensor wiring, as well as heater controls. He is now dead !
#6 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
what turbo are you running?
can't see how you would get a vf10/11/12 to 17 psi mine was maxed by 13 psi at 5000 rpm did you see how i used yellow side feed sti injectors on my ej20G? (modified 1.8 rail) |
#7 |
Member#: 59357
E. Canada
I'm just going on what my boost guage told me, I'll show you a pic of it next time I grab my camera. Iv'e got a VF-8 not the 10/11/12
I saw your install, but have heard the RS rails are direct fits, so I thought I'd go that route. - Did the injectors do anything for you? |
#8 |
Member#: 832
RMIC
VF-8's can handle that sort of boost. While they use an older bearing design, they do use the P-18 exhaust housing...
#9 |
Member#: 59357
E. Canada
Pics resided, Sorry about that, My VF-30 will certainly work with this ecu, It's on it's way to deadbolt for some service.
#10 |
Member#: 177
NWIC
intersting on the RS rails as in usdm imp RS or legacy RS they won't fit in legacy RS rails
change - yeah i had to completly change my fuel map 25% is a good size change usdm sti/ legacy RS/ imp 1.8 thread w/ pictures http://forums.nasioc.com/forums/showthread.php?t=777506 |
#11 |
Member#: 59357
E. Canada
USDM 1999-2001 is 2.5 RS
I'm going to stop buy a yard to check them out, but I'm fairly cirtain they'll fit. I'll let you know. |
#12 |
Member#: 177
NWIC
i know for sure what you posted is incorrect
the 99 uses a top feed rail and usdm wrx style injectors the 98 RS ... on the otherhand .. |
#13 |
Member#: 832
RMIC
I've got a '98 2.5RS manifold with rails, that I test fit to my Ej20G. It bolts right up. So even if the '98 injectors don't fit the Ej20G rails, the whole manifold will swap over...
#14 |
Member#: 177
NWIC
but will the 98 rs rails fit the G manafold?
#15 |
Member#: 59357
E. Canada
Yeah, that's it Matt was the one I had read about doing this it's the 98 ones, sorry I should get my facts straight before I post. My bad, anway how do they line up Matt?
#16 |
Visiting NASIOC Timeout
Member#: 9093
Vehicle:1995 RHD STi RA Ver2 swap starr |
hey snowjob. quite intersting work. could you write a write up on how the swap and wiring went? im intersted to know abojut the AWic conversion and wiring
h |
| Thread Tools | |
| Display Modes | |
| DIY wheel paint is done. check it out :) | Super_HKS | North West Impreza Club Forum -- NWIC | 34 | 11-26-2007 01:37 PM |
| 05 WRX rear diffuser "mod" 56K SOL!!!! FINALLY DONE AFTER 1.5 years!!! | DieselClown | Member's Car Gallery | 24 | 11-25-2006 01:32 PM |
| Swap Done Check It out!!!!!! | Ireneusz | Subaru Conversions | 14 | 07-12-2006 10:38 PM |
| Check it out new vid 56K | boricuajr | News & Rumors | 3 | 06-23-2005 08:47 AM |
| It is Done, Check it Out Flat Black and Blue 02 WRX | mrtrex | Member's Car Gallery | 24 | 07-11-2003 08:55 AM |
