Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 07-20-2005, 01:21 PM   #1
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
Default what is causing this CEL?
so this morning on my way to work my car began to bog really bad, then i got a CEL i scanned it when i got to work and it pulled a p301 p302 p303, all 3 cylinders misfiring. I installed TWE cams 2 saturdays ago and am wondering if that could be causing this. any ideas of what it could be?
Sharmin7 is offline   Reply With Quote
Old 07-20-2005, 01:58 PM   #2
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Might need to readjust the valve lash, which I think you are supposed to do a little while after installing cams, anyways. Also, check your plugs, plug wires, and coilpack. Also, have you done any other mods to the ECU? I have a piggyback ECU, and one of the tunes I got did a little tweaking to my ignition timing, and that causes some misfiring problems for me. But I think the valve lash is probably the most likely, considering you just recently installed cams.
HondaH8er is offline   Reply With Quote
Old 07-20-2005, 05:57 PM   #3
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
i had a similar problem once before when i installed my equal length headers because the front 02 is right in the header pipe and was reading too much exhaust so i got some spark plug defoulers and raised the 02 sensor out of the exhaust, i have a feeling that this is a similar problem, hopefully
what would cause... this is a strange one ncarn8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-06-2010 10:05 AM
What specifically is causing this oil leak? (w/pics) ExecNav Built Motor Discussion 6 09-30-2009 01:23 AM
What is causing this? flyinEyeball Brakes, Steering & Suspension 4 10-17-2006 01:37 PM
What do you think is causing this? (Computer/Battlefield 1942 question) bowenx Off-Topic 3 09-24-2003 08:44 AM
