Old 07-20-2005, 12:41 PM   #1
WebWizard
Member#: 78979
2013 WRX
Crystal Black Silica
Default Looking for Larger Injectors
Just like the title says.. Looking for larger injectors. I have decided to do away with the 2 extra injectors, as they havent done what I want them to do. And that is to stop the car from running lean when in boost. So I am now in the hunt for larger injectors to put in my car. I already have a Walboro Fuel Pump, and I am getting a SAFC2. So the last thing I think I need is the injectors...
Anyone know where I can pick up a good set for a decent deal? Before I forget, my car is a 98 Subaru Impreza 2.5 RS-T. I was looking into 550cc, but what do you guys think? Thanks in advance...
-Dave
WebWizard is offline   Reply With Quote
Old 07-20-2005, 03:46 PM   #2
WebWizard
Member#: 78979
2013 WRX
bump bump
Old 07-20-2005, 06:56 PM   #3
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
a little more information is needed.
setup?
Engine management?
whats currently powering your 2 extra injectors?
how are you controling them?
what is their max duty cycle and what is your max boost?
please explain
Hitokiri is offline   Reply With Quote
Old 07-20-2005, 07:40 PM   #4
WebWizard
Member#: 78979
2013 WRX
I am currently running a TSi TurboKit on a stock 98 2.5RS Block at 5 psi, a piggy-back computer came with the kit. The extra 2 injectors came with a control unit, that adds fuel directly into the throttle body when I hit boost. Not sure about their duty cycle...
I dont plan on keeping the extra 2 injectors. I am ditching the extra 2 injectors(as well as my stock injectors), and injection control unit. I want to instead go with 4 larger injectors (i was thinking 550cc). I am revamping my entire fuel system after finding out that even with the extra 2 injectors, my engine was still running lean.
So heres what I plan on doing... Putting in my Walboro 255 LPH fuel pump, Larger Injectors (when I can find some), and an SAFC 2. I also dont plan on running more than 5 psi of boost, until I swap out engine components.. Just trying to find out where I can get the larger injectors for the best price. I was looking at STi Pink injectors, but it didnt say that they would fit the 98 2.5RS. If anyone has any info on where I can get some larger injectors, that would be great....
Sorry I didnt give out enough info the first time...
Old 07-20-2005, 09:26 PM   #5
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
Follow this link for more info and knowledge. You might find it helpful given your situation.
http://forums.nasioc.com/forums/showthread.php?t=796978
Joncas2 is offline   Reply With Quote
Old 07-20-2005, 11:21 PM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I do not know if they bolt onto your manifold (but I think they do), but if you can score some 92-94 NA Legacy fuel rails, they accept nissan srd20 injectors and these are commonly available in 370 440 550 and 820 cc sizes.
Old 07-21-2005, 01:40 AM   #7
WebWizard
Member#: 78979
2013 WRX
Joncas2,
Thanx man.. I was looking at RaceComp Engineering an saw a set of STi injectors, that they say will fit MY98 RS (the STi 440cc Ver.5/6 Side-Feed injectors). My only question is, is anyone currently running these injectors or has anyone run these injectors. I also checked outbackmotors and I am gonna call them later on a few things I liked... So thanks for the link bud..
-Dave
Old 08-06-2005, 03:08 PM   #8
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
I'm about to run those 440cc injectors. I am assembling my car (taking a long time) and they will grace my modified fuel rails. They drop right in and the fitment is excellent. BTW, the only thing modified about my fuel rails is the Outbackmotorsports fuel lines and fittings.
I will have (2) 1200cc secondaries, but I have to mill some aluminum first.
Good luck.
trade sti pinks for larger injectors and some cash moorebl Private 'Wanted' Classifieds 2 02-04-2005 12:06 PM
Looking for sti injectors (pink)!! titanium wrx Private 'Wanted' Classifieds 3 03-28-2004 12:28 PM
looking for 800cc injectors and turbo wrxben Private 'Wanted' Classifieds 2 02-24-2004 05:58 AM
looking for larger diameter oil filter.. joostin420 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-02-2002 11:16 AM
What are 98RS-Ts using for larger injectors? Impreza25RS Normally Aspirated with bolt-on Forced Induction Powertrain 14 11-07-2002 08:06 AM
